VWVortex.com - 2.0 TSI - Technical Service Bulletins.
    Results 1 to 16 of 16
    Thread: 2.0 TSI - Technical Service Bulletins.
    1. Forum Sponsor Arin@APR's Avatar
      Jul 29th, 2008
      Auburn, Al
      S4 3.0 TFSI 6MT & GTI 2.0T FSI DSG
      04-07-2009 07:40 PM #1
      Technical Service Bulletin Transaction No.: 2018652/2
      01-09-04 - MIL ON, DTCs P1545, P0121, P0123, P0221 or P0222 Stored in ECM Fault Memory
      Release date: Feb 18, 2009
      Condition:
      Malfunction indicator lamp in instrument cluster is illuminated.
      A number of incident memory entries with regard to the throttle valve are stored in the ECM. In most cases, the entries are sporadic.
      DTC Description:
      P1545 Throttle valve control system malfunction
      P0121 Throttle/Pedal Position Sensor/Switch “A” Circuit Range/Performance
      P0123 Throttle/Pedal Position Sensor/Switch “A” Circuit High
      P0221 Throttle/Pedal Position Sensor/Switch “B” Circuit Range/Performance
      P0222 Throttle/Pedal Position Sensor/Switch “B” Circuit Low
      Technical Background:
      Contact resistance in the ECM wiring – throttle valve.
      Production Solution:
      Optimized wiring and contacts.
      (IE, take it to the dealership)
      GoAPR.com | Facebook | YouTube | Twitter | Instagram
      Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
      Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    2. Forum Sponsor Arin@APR's Avatar
      Jul 29th, 2008
      Auburn, Al
      04-07-2009 07:41 PM #2
      Technical Service Bulletin Transaction No.: 2020241/2
      87-09-01 - DTC 00819 Stored in AC Control Module, Engine Cooling Fan ON Continually
      Release date: Apr 1, 2009
      Condition:
      At temperatures below - 5°C (23° F) the following DTC may be stored in the AC control module along with the cooling fan operating continually.
      DTC Description:
      00819 High pressure sender **-G65- disruption/short circuit, sporadic
      Tolerances of high pressure sender -G65-.
      Final production countermeasures pending.
      Note:
      Replace no parts for this condition.
      The condition as described has been identified, and is currently under investigation. The condition has no effect on the function of the air conditioning, and if DTC 00891 has been recorded in the AC control module at temperatures below - 5°C (23° F) it may be ignored.
      Modified by Arin@APR at 4:43 PM 4-7-2009
    3. Forum Sponsor Arin@APR's Avatar
      Jul 29th, 2008
      Auburn, Al
      04-07-2009 07:41 PM #3
      Technical Service Bulletin Transaction No.: 2019394/1
      01-08-32 - DTC P2015 (2968) Stored in ECM Fault Memory (U.S. Only)
      Release date: Nov 21, 2008
      Condition:
      DTC will set with or without MIL ON
      DTC Description:
      P2015 (2968) Intake Manifold Runner Position Sensor/Switch Circuit Range/Performance Sporadic
      • Intake manifold tumble flaps sporadically stick.
      • Engine performance is not affected.
      Production countermeasure implemented.
      Modified by Arin@APR at 4:47 PM 4-7-2009
    4. Forum Sponsor Arin@APR's Avatar
      Jul 29th, 2008
      Auburn, Al
      04-07-2009 07:41 PM #4
      Modified by Arin@APR at 4:51 PM 4-7-2009
    5. Forum Sponsor Arin@APR's Avatar
      Jul 29th, 2008
      Auburn, Al
      04-07-2009 07:41 PM #5
      Modified by Arin@APR at 4:52 PM 4-7-2009
    6. 04-08-2009 02:53 AM #6
      How would one know if these have been addressed with their vehicle?
    7. Member mercavius's Avatar
      May 16th, 2002
      Aberdeen, MD
      2011 Tiggy
      04-08-2009 07:56 AM #7
      I guess we just wait to see if we get a CEL for them.
    8. Member BAD SNaCKY's Avatar
      Jun 15th, 2004
      Eagleville, PA
      2016 Mazda CX5
      04-08-2009 10:08 AM #8
      what's the repository so we can look this kind of stuff up? goverment website? voa site?
      I still miss her </3
      Formerly ShippensburgGTI
      Jun 3rd, 2003
      SF Bay Area
      2015 Subaru WRX
      04-08-2009 10:37 AM #9
      Probably the Bentley online, which i get weekly downloaded updates from. It has TSBs.
      2015 Subaru Fortester XT
      2015 Subaru WRX Limited
      190+ Video GTI Modding/DIY Library /
    10. Member ViRtUaLheretic's Avatar
      Aug 16th, 2008
      Kansas City
      2009 GTI
      04-08-2009 10:46 AM #10
      Thanks for posting these Arin, please continue to post them as they show up.
      I am going to add a link to this in the FAQ
      :APR -stage 2 :BSH -Intake,Mounts,RSB,TB Pipe :Whiteline -A.L.K. :Porsche 17Z BBK
      :Devils Own -DVC-30+Direct Port Injection :BC Racing -BR Coilovers :Flik-FTD :OSIR
      :Eurojet -Ceramic Coated TBE :DEFI :Unibrace :Tyrolsport :Bildon :Hawk :034
      TSI FAQ: http://forums.vwvortex.com/showthread.php?4042736
    11. Member EngTech1's Avatar
      Nov 30th, 2008
      Easten - TN
      2015 CC, V50 Volvo , T-Bird - Gone , MG - Gone , Volvo 122s , Volvo 144 , Volvo 242 , 245 GL
      04-08-2009 10:44 PM #11
      I Once had an Issue where If the - Bolts that Held the Component Contact
      In Place Were Loosened , One could Actually - Change the resistance in the ECM wiring – throttle valve - Reading - By A Slight Movement and a Re-tightening. Hence there Should be a High and Low - Reading.
      It Would be Great If We could Get those Spec's ?
      Thanks
      Dan
      We Uses Two Thin Bare Copper Leads and Measured the Resistance .
      Some Times , there is a Certain Threshold - say 1 Volt or 100 Ohms
      Once the Reading Goes Over the Threshold the ECU , Starts Tracking It
      Which Uses Up ECU - Buss Traffic or CPU Power sort of Speak .
      To Much ECU Buss Traffic and Poor Performance - will Accure .
      Hence If a Data Logger is Being Used to Load Data from say 8 Different
      Area's , and You Request Info every 1/25 of a Sec. on all 8 Items , You Will See or Feel the Difference in the Motor . Then back Down to tenth of a Sec. on all 8 Readings and It will Go away . Better to go 1/4 on say H2O -Temp & 1/4 sec. on Say Oil Pressure - as that's Fast enough Reads for those Items.
      Wow , Sorry Got side Tracked:
      I'll do My Best to Help You: ** Fall Sale is On ! ** -
    12. Member BAD SNaCKY's Avatar
      Jun 15th, 2004
      Eagleville, PA
      2016 Mazda CX5
      07-27-2011 04:12 PM #12
      Anyone discover any new TSB's? Post'em up!
    13. Member ViRtUaLheretic's Avatar
      Aug 16th, 2008
      Kansas City
      2009 GTI
      08-15-2012 09:57 PM #13
      any more updates? anybody?
    14. 08-16-2012 03:13 PM #14
      Quote Originally Posted by BAD SNaCKY View Post
      What about this one?
      The TSB number by the way is: 2028302/4
      http://www.golfmk6.com/forums/showth...t=43654&page=7
      http://www.golfmk6.com/forums/showthread.php?t=43654
    15. 08-17-2012 10:51 AM #15
      Quote Originally Posted by piston View Post
    16. 10-01-2012 03:58 PM #16
      I use Edmunds to look up relevant recall and TSB information.
      http://www.edmunds.com/car-maintenan...50317&type=tsb
