Page 1 of 39 1 2 3 4 5 11 ... LastLast
Results 1 to 35 of 1356
Thread: Home brewers CHECK IN please!
  1. Senior Member patrikman's Avatar
    May 10th, 2008
    La Baie des Puants
    moar wagons.
    04-08-2009 08:29 AM #1
    I have been brewing for a little over a year now, I am starting to get serious about it. I have done a few batches and I am starting to get bored with the ready made kits. Also, I have plastic secondary and primary fermenters and they are starting to get a brew funk to them. I scrub and scrub and scrub and sanitize, rinse and repeat and they still have a faint aroma of brew. Is this normal? I don't really want to switch to all glass carboys because I just got laid off and times are tight. Any thoughts?
    Bring back BLB and ban BHB!
    Jun 28th, 2001
    St. Louis MO
    04-08-2009 08:55 AM #2
    Yes, plastic will take on the smell of fermenting wort. Think about pickle buckets. Be careful when scrubbing out your buckets, you create scratches that can be the perfect hiding place for undesireable little monsters....beer spoilers.
    The easiest thing to do is just to soak in PBW or something like that over night, then spray out. The vast majority of trub and stuff stuck the sides with just wash out. Then you can wipe out any remaining stuff with a soft cloth or paper towels.
    I'll also add that you may want to buck up and buy one carboy to use as a secondary. Plastic breathes and is not the best thing for conditioning or aging beer.
    dan g
  3. Member SivNiz's Avatar
    Jul 14th, 2005
    5780ft above sea level
    04-08-2009 09:38 AM #3
    I would look on craigslist for used carboys, i found a whole extract setup, wtih two glass carboys, for $20.
  4. Member
    May 29th, 2003
    Long Island
    92 Taurus, 98 Cirrus, 2003 Maxima
    04-08-2009 04:38 PM #4
    Every 6 or so batches, I fill my fermenter up with baking soda/hot water mix and let it sit overnight....
    Gets out all the funk.
    Also, as mentioned above, I never use anything other than soap and very hot water to clean the plastic - a scour sponge will create places for the funk to hide in.
    Modified by nish65 at 4:39 PM 4-8-2009
  5. Member 5_Cent's Avatar
    May 22nd, 2007
    Hamilton, NJ
    04-08-2009 08:21 PM #5
    can anyone recommend a source, site, book, video etc on how to get started brewing your own beers? I've always wanted to try it, I remember seeing a brew kit machine of sorts at Macy's years ago but haven't seen anything like it since.
    I don't know if it matters but I am not really a fan of domestic beers anymore, although I will drink them if at a bbq or sporting event. I love IPA's
  6. Member ribguy's Avatar
    Feb 18th, 2008
    Lewiston, Idaho
    1980 Rabbit AAZ , 1984 Rabbit AAZ
    04-08-2009 11:42 PM #6
    I bet your local library has a selection of books on homebrew ours does. http://www.morebeer.com is a great place to surf.
  7. Member 5_Cent's Avatar
    May 22nd, 2007
    Hamilton, NJ
    04-09-2009 09:03 AM #7
    thanks just reading over some of that site I have a question.
    Are you guys boiling 6 or more gallons of water? If so where are you doing this? I don't think a regular gas stove could boil that? Cuz then if you are to use the wort chiller thingy you need running water right? So how many people have a setup where they can run a a propane stand alone burner to boil and have running water available for the chiller without doing it outside? Cuz I would assume outside you risk containments falling into the water.
  8. Senior Member patrikman's Avatar
    May 10th, 2008
    La Baie des Puants
    moar wagons.
    04-09-2009 02:50 PM #8
    ^^ I have been using the LD Carlson-Brewers Best Kits from my local homebrew store and they are incredibly good for getting your feet wet, most recipes call for starting the boil with 2-3 gallons usually. for a pot I have a turkey fryer 6.5 gallon kit (came with propane stand). the first time I boiled outside with gas and it took quite a while and didn't seem very efficient unless you start off with a smaller amount of water and add gallon by gallon. it seemed like more work then necessary and got my kettle full of soot. If you keep the lid (mine has a hole for thermometer) it will do a good job of keeping airborne debris out. I may switch back to outdoor boils in the summer because it allows me to enjoy a nice Punch or a Cohiba while I am boiling. Indoors seems easier, my current range in my duplex is electric and it works ok and it is near the sink so I can run wort chiller hoses a short distance.
    Jun 28th, 2001
    St. Louis MO
    04-09-2009 05:04 PM #9
    Milling
    Mashing
    batch sparge
    boiling
    whirlpool chill then pump to fermenter
    keg and enjoy
  10. Member 5_Cent's Avatar
    May 22nd, 2007
    Hamilton, NJ
    04-09-2009 05:16 PM #10
    wow you make it look so easy! lol
    everything looks so messy and dirty, not saying that your setup is a mess or anything just that I guess everything gets all gunky in the process.
    I'll have to start with a small beginner kit or something see if I am going to even like doing this.
  11. Senior Member patrikman's Avatar
    May 10th, 2008
    La Baie des Puants
    moar wagons.
    04-09-2009 05:21 PM #11
    Quote, originally posted by blksabbath »
    pimp a$$ setup
    wow man, how long have you been brewing? I would like to get into that stuff further down the line. I am especially into the small (soda?) kegs, a buddy and I are going to get into that this summer because bottling is just a huge hassle because you just pour it into a glass anyways. great stuff so far!
    Jan 27th, 2004
    York, PA
    ’04 R32 - '04 GLI - ’93 Corrado
    04-09-2009 05:45 PM #12
    I'm have an IPA fermenting right now. I'll be watching this thread
  13. Member SivNiz's Avatar
    Jul 14th, 2005
    04-09-2009 06:02 PM #13
    Quote, originally posted by 5_Cent »
    homebrewtalk.com
  14. 04-09-2009 07:36 PM #14
    Quote, originally posted by SivNiz »
    homebrewtalk.com
    x2
  15. Member 5_Cent's Avatar
    May 22nd, 2007
    Hamilton, NJ
    04-10-2009 12:44 AM #15
    thanks!
  16. Member
    Jun 28th, 2001
    St. Louis MO
    04-10-2009 08:59 AM #16
    "wow man, how long have you been brewing?"
    7 years...plus a few random times in college and stuff.
    Get the print version of John Palmers How to Brew. Here's the online version: http://www.howtobrew.com/sitemap.html
    Next time you go into a homebrew shop, ask if there's a club in your area. The best way to learn is to brew with others and see how it's all done.
    Modified by blksabbath at 6:01 AM 4-10-2009
  17. 04-10-2009 04:24 PM #17
    That's a dope setup.
    Anybody here grow hops?
    I've got some cascade to plant this season.
    Autocratic
  18. Member SSj4G60's Avatar
    Aug 12th, 2001
    LI/NY
    04-10-2009 06:01 PM #18
    wondering whats the oddest thing anyone here has tried to make, friend somehow got the idea to do a Pineapple Pilsner
    Another friend make an "Illegal Pale Ale" that was really good.
    Nevermind that it's fun to drive.
    A MkIV drives like someone put a bag of dicks on four wheels. Even worse if it's on bags.
  19. Senior Member patrikman's Avatar
    May 10th, 2008
    La Baie des Puants
    moar wagons.
    04-10-2009 07:47 PM #19
    Quote, originally posted by Moe Sizlack »
    the gf's mom is growing me some cascade too! from all of the recipes I readup on that seemed to be a common denominator in alot of styles I am into.
  20. 04-10-2009 07:49 PM #20
    homebrewtalk.com
    Quote, originally posted by A4J »
    x2
    x3
  21. Member zyntax's Avatar
    Sep 19th, 2006
    Malvern, PA
    95 GTi VR6(gone), 96 Cherokee, 97 Civic, 97 GLX, 04 TDi
    04-10-2009 09:17 PM #21
    My buddy just gave me John Palmers how to brew book. It gets very in depth...seems like a must have for home brewers.
  22. Member
    May 29th, 2003
    Long Island
    04-10-2009 10:11 PM #22
  23. Member ribguy's Avatar
    Feb 18th, 2008
    Lewiston, Idaho
    04-10-2009 10:37 PM #23
    Steer clear of mr. beer, brew it right with the proper equip.
  24. Senior Member patrikman's Avatar
    May 10th, 2008
    La Baie des Puants
    moar wagons.
    04-11-2009 03:50 AM #24
    Quote, originally posted by ribguy »
    unless you are still in high school or live in a dorm.
  25. Member SmithersSP's Avatar
    May 24th, 2006
    Charlotte, NC
    REVO STGII+ 06' PG GLI, C2 97' GLX
    04-11-2009 08:38 AM #25
    Say hello to my little friend!
    Chapter 11 Dubs
    Revo STGII+ Kegerator
    Quote Originally Posted by jhines_06gli View Post
    I fix Pete's car to keep cold, cheap beer flowing for the club at shows.
  26. Senior Member patrikman's Avatar
    May 10th, 2008
    La Baie des Puants
    moar wagons.
    04-12-2009 02:40 PM #26
    where do you guys get the barrels from? steal from a party/behind a bar?
  27. Member SmithersSP's Avatar
    May 24th, 2006
    Charlotte, NC
    04-12-2009 03:33 PM #27
    Any brewery will usually have damaged kegs that no longer hold pressure. They will let them go for like $10. Sometimes they'll give them away if they know you're using them to make kettles. Every pro brewer started as a home brewer...
    Chapter 11 Dubs
  28. Member
    Jun 28th, 2001
    St. Louis MO
    04-12-2009 05:11 PM #28
    Quote, originally posted by SmithersSP »
    Almost....Unless you work for one of the big three.
    Nice set-up SmithersSP! I see you are in NC, you wouldn't happen to know a brewer name Jim Yeager that moved to Mo about 5 years ago? I bought new house and moving in two weeks, so a new basement electric system is in the works. I'm still gonna have a gas fired system for the garage though. Once I start the build, I'll post pics.
    dan
    Modified by blksabbath at 2:13 PM 4-12-2009
  29. Member SmithersSP's Avatar
    May 24th, 2006
    Charlotte, NC
    04-12-2009 11:23 PM #29
    Good point regarding the BMC brewers.
    The name Jim doesn't sound familiar. I have a great webpage if you want plans for a great electric system.
    Chapter 11 Dubs
  30. 04-13-2009 09:02 AM #30
    Are those used kegs lined with SS or something?
    I'm really not familiar with kegs or kegging... only draining them.
    Autocratic
  31. Member
    Jun 28th, 2001
    St. Louis MO
    04-13-2009 09:06 AM #31
    Cool. IM me those plans or post a link. Thanks! I've got a bunch of builds bookmarked and lots of ideas, just gotta pull it together.
    Not sure if you were on the Homebrew Adventures GreenBoad before it crashed. Jim was a mod over there and i think they sold a couple of kits based on his recipes. Anyways...
  32. Member SmithersSP's Avatar
    May 24th, 2006
    Charlotte, NC
    04-13-2009 10:05 AM #32
    The kegs are made entirely of 304 SS.
    Chapter 11 Dubs
  33. Member SmithersSP's Avatar
    May 24th, 2006
    Charlotte, NC
    04-13-2009 10:08 AM #33
    The green board is actually owned by my local home brew shop. HBA is based out of Charlotte. I was talking with Jess the owner on Friday actually. The mods lost their minds and refused to enfore the rules so Jess had no choice but to shut it down. I personally have always been a loyal member to Home Brew Digest's forum. It is by far the best forum for advanced homebrewing. I was always of the opinion of that the green board was full of people that didn't let the fact that they didn't know what they were talking about stop them from running their yaps.
    Cheers!
    Chapter 11 Dubs
  34. Member SmithersSP's Avatar
    May 24th, 2006
    Charlotte, NC
    04-13-2009 10:09 AM #34
    Here is the link to Carl's system. Carl is my former manager. Paul Muth is the man responsible for the custom metal fab. Paul also did the majority of my metal work. He's crazy but a true genius...
    http://www.wortomatic.com/articles/Carl's-Electric-HLT
    Chapter 11 Dubs
  35. 04-13-2009 10:22 AM #35
    Awesome! For some reason I thought the were Al.
    Autocratic
