VWVortex.com - What size speakers fit on a jetta??
    Results 1 to 15 of 15
    Thread: What size speakers fit on a jetta??
    1. Member exile213's Avatar
      Mar 24th, 2009
      Los Angeles
      1999 Gti Vr6
      04-09-2009 01:41 AM #1
      The jetta I bought didn't come with any speakers. What size speakers do I need to get??
    2. 04-09-2009 01:52 AM #2
      I'm not quite sure myself but they look like 6.25''
    3. 04-09-2009 01:54 AM #3
      I correct myself...6.75
    4. 04-09-2009 01:55 AM #4
      The tweeters however don't have stock replacements...I forgot what most people use but there's slight modification required
      Sorry for the multiple post...i'm drinking with a few friends right now
      May 24th, 2008
      Woodbridge, VA
      2001 Golf GLS 2.0 AVH
      04-09-2009 05:36 AM #5
      What do you mean by "The tweeters however don't have stock replacements"? Do you mean you cant get aftermarket solutions in their place?
    6. 04-09-2009 05:41 AM #6
      6.5" speakers front and back. They're also a 3" recess, so they've got to fit that depth if you want to use them with the OEM speaker grills. As for the tweeters, not sure.
      Modified by tylergreenwood at 2:45 AM 4-9-2009
    7. Moderator vanaman's Avatar
      Aug 26th, 2003
      OhiO
      97 Jetta GLX, 99 Cabrio, 03 Sierra SLE, 97 tracker, 84 ATC200X, 78 CB750F, 66 S90
      04-09-2009 10:20 AM #7
      the front tweeters are about a 3" hole. so the best bet for speaerks is a set of components afor thefront and a set of full ranges for the rear.
      steve
    8. Senior Member Dan J Reed's Avatar
      Jul 26th, 2004
      NJ - AKA - Earth's armpit.
      Too many
      04-09-2009 12:06 PM #8
      May 24th, 2008
      Woodbridge, VA
      04-09-2009 05:15 PM #9
      God dammit I cant believe I forgot about Dans site! I forget do you have specs/dimensions of the tweeters though?
    10. Member jorge r's Avatar
      Apr 27th, 2006
      Los Angeles, 5&110
      vw
      04-09-2009 05:25 PM #10
      You can double check and find outfits with Crutchfield.
      http://www.crutchfield.com/cgi....aspx
    11. Awaiting Email Confirmation FlatlanderSJ's Avatar
      Oct 3rd, 2007
      97 GLX, 92 LC3U Corrado VRT
      04-09-2009 07:19 PM #11
      I fitted 1 inch tweeters into cut out stock/non-Bose bases
    12. 04-09-2009 07:20 PM #12
      FYI Infinity Kappa Series With the external crossovers sound GREAT in the rear in a 6.5"
    13. Member Venkman's Avatar
      Jun 24th, 2005
      Harrisburg, PA
      94 Golf, 96 Wagon, 16 GTI
      04-09-2009 07:34 PM #13
      One thing you may want to consider if you have a rear deck you cannot reuse the stock speaker grills so if you don't want some goofy looking speaker grill that most aftermarkets come with look for some that come with normal looking ones.
      COYS!!!
    14. 04-09-2009 10:55 PM #14
      I run MB Quart 4" with tweets on the dash They have a set just for Euro's. And a set of 6.75 Quart Mid Woofers in the doors on a 3 way cross-over. The sound is just incredible.
    15. 04-10-2009 01:17 AM #15
      Quote, originally posted by OldEliminator »
      MB Quart is an EXCELLENT speaker brank. Crystal clear, esp when properly powered.
