VWVortex.com - Removal for 2004 Jetta Monsoon Radio
    Results 1 to 4 of 4
    Thread: Removal for 2004 Jetta Monsoon Radio
    1. 04-12-2009 07:45 PM #1
      I have the four removal keys in place, but for some reason, it won't lock into the bottom right. The other keys are in correctly and I can start to pull out the left side, and the top, but the bottom right isn't budging. Any ideas what I can do? Is there another way to get the radio out without removing the entire dash?!
    2. 04-13-2009 03:24 PM #2
      It's very common for the radio key release latches to break. Try putting the key in at a slight angle to see if it'll grab. If that doesn't work you might have to go in from the glove box and push from behind.
    3. 04-13-2009 11:17 PM #3
      Okay. How might I do that?
      Thanks.
    4. Member blazerpounds's Avatar
      Mar 19th, 2008
      Greeley, CO
      02 GTI 1.8t
      04-15-2009 02:19 AM #4
      just pry t face off. especially if your deck already doesnt work.
      if youre actualy careful with it you can reatatch the face easilly. otherwise you gotta pull the underdash, both sides, glovebox and then you can get to the clips that hold the dash and radio together.
