Results 1 to 33 of 33
Thread: JB weld a cracked Oil pan...Good idea, or bad Idea
  1. 04-12-2009 09:58 PM #1
    I am assuming its a bad idea, but would like your opinions on it. The gash in the oil pan is about the size of a Band aid. Do you think JB weld or any of there other products would work??
  2. Member Hustlin's Avatar
    Nov 21st, 2004
    Stroudsburg PA
    E46 M, B5 1.8TQM Avant, GSXR 750
    04-12-2009 11:22 PM #2
    Not so much
    pm for air freshener installs. master certified, high rates.
  3. 04-13-2009 10:10 AM #3
    its far from a good idea but I have seen it work on more then one occasion.
    I doubt I'd do it to my car unless it was a "get it home" type repair
  4. Member Eric D's Avatar
    Feb 16th, 1999
    Tragic Kingdom, CA
    1943 Flugkreisel, 1945 VRIL-7
    04-13-2009 07:13 PM #4
    Get it TIG welded.
    The original Dub and Dubber.
    Manche VWs sind einfach schneller als andere.
  5. 04-13-2009 08:43 PM #5
    JB Weld is only good up to 150 degrees
  6. Member nubVR's Avatar
    Apr 24th, 2004
    Vancouver Wa
    '00 Tropic Orange VR6BT
    04-13-2009 10:13 PM #6
    bad idea.... send it my way, ill fix that ish
  7. Member mechsoldier's Avatar
    Aug 14th, 2004
    Auburn, WA
    71 Bus, 89 Golf, 98GLX, 97TDI Jetta, 66 Beetle
    04-14-2009 01:17 AM #7
    JB weld works on an oil pan. You can get it tig welded and that's optimal. But when I was younger I was swapping a 2.4 stratus motor into a 1st gen Dodge Neon and the engine fell and it cracked the cast aluminum pan. I JB welded it and it held fine, but leaked slightly.
    If you're lowered I'd forget this idea as it will likely completely fall apart if it hits just about anything.
    Dub Autowerks VW, Audi, Porsche, and BMW parts and service
    1723 West Valley Hwy E
    Sumner, WA 98390
    http://www.DubAutowerks.com
  8. Member Josein06GLI's Avatar
    Jun 28th, 2008
    San Diego, Ca
    2012 Audi A4, 2006 VW Jetta GLI, 1989 MK2 GTI 16v
    04-17-2009 11:10 PM #8
    a while back while doing an engine swap on one of my motorcycles i used some **** called aluma weld, i got it from ebay for like 20-30 bucks **** worked and held fine.
    2006 BMP VW JETTA GLI DSG some coils, some bolt ons and some wheels.
    1989 VW GTI 2.0 16v some coils, some bolt ons, and some wheels.
    2012 Audi all stock, its hers. she dont want me messing with it...yet.
    Jan 28th, 2009
    Syracuse, NY
    various old audi crapboxes
    04-18-2009 09:28 AM #9
    my friend used it once to fill a hole in the block of his dirt bike, i guess he hasnt had any problems with it for about a year or more now
  10. 04-18-2009 09:42 AM #10
    ive done it before and it held for maby 6 months or more but eventully the oil breaks it down and the patch fell out. so its def a good tempory option but wolnt hold up forever!!
  11. Member d-bot's Avatar
    Sep 6th, 2004
    Par 5 from the Space Needle, PNW.
    80 Storm 20vSC Syncro, 93 Corrado VR6
    04-23-2009 11:28 PM #11
    Bar of Soap in a pinch. otherwise get it properly welded or just flat out replaced.
  12. Member i4turbo's Avatar
    Oct 25th, 2006
    London, Ont
    '86 Jetta TDI
    04-24-2009 11:56 PM #12
    I have used JB Weld to fix a smashed cam lob in my 5hp briggs motor when i ran it without oil (long story)
    It still runs till this day and beat on all the time (go kart motor)
    and I have fixed my pan on my mk4 gti, worked like a charm (just make sure its clean and dry and you will be fine)
  13. Member gillano's Avatar
    Aug 4th, 2005
    Grand Rapids, MI
    '89 Golf 2.0T8v counter-flow project
    04-25-2009 12:13 PM #13
    just get a new pan
    its *always a good idea to cut corners on things that are critical like the engine lubrication system*
    why would you even consider this ??
  14. Member mechsoldier's Avatar
    Aug 14th, 2004
    Auburn, WA
    04-25-2009 10:42 PM #14
    Maybe he doesn't have the $150 to spend on a new pan. If you lose oil you'll no instantly, it's not like the motor is going to seize running 5 seconds without oil pressure. If you do it right it will work until you get the money for a new one.
    Sumner, WA 98390
  15. Member DustyGTI's Avatar
    Apr 16th, 2005
    Chelan
    04 .:R32, 02 Turbo S, 77 rabbit
    04-27-2009 06:14 PM #15
    I had to do this before. Get the JB weld putty. Drain the oil if you can. My pan slid on the ground too many times. Get a bunch of putty, clean it with brake clean and rags. spread putty over the crack wait for it to dry and put in some new oil. Worked for me. I fixed it correct when I got home
  16. Member ryanarchy's Avatar
    Nov 26th, 2008
    San Clemente, CA
    1990 Corrado 16vg60 6spd, 2005 Tundra
    05-10-2009 05:03 PM #16
    when i worked as a tech at a dealer a guy came in with a beetle oil pan that had the drian plug threads repaired with jb weld along with a heap more slathered over the pan. i showed the other techs and we all had a good laugh. it wasnt leaking though. the customer turned out to be my grandfather, i was embarassed. but i figured out where i got my ghetto fab skills from.
  17. Member xblueinsanityx's Avatar
    Nov 19th, 2005
    north ogden
    vrt corrado, smokey mid engine corrado.... various other vehicles
    05-10-2009 05:47 PM #17
    get it tig welded back together you can probably find someone to weld it allot cheaper than a new pan
    bend it , cut it , grind it, weld it....... drive it! ..... break it........
  18. 05-10-2009 06:13 PM #18
    We've done it SEVERAL times at my old job,it holds ALL THE TIME.
    If your not a ****ing retard over tighning your dp.
  19. Member X37's Avatar
    Dec 29th, 2007
    Sacramento CA
    1997 Jetta VR6 GLX
    11-14-2011 12:53 AM #19
    Glad I found this old thread. I have a hole the size of a straw tip. Don't see $150 in my budget for a new pan so I'll do this to hold me over for a few months.
  20. Member DUBBED-OUT's Avatar
    Mar 20th, 2008
    NJ
    01 GTi 20v BT, 03 B6 V6
    11-14-2011 11:44 AM #20
    I've done it before on my VR & it held up with no problems. I also used like 3 different kinds of epoxy. (Quick Steel & a pace) & let it sit for like 12hours before use.
    But as stated, if you can afford to replace your oil pan replace it. You'll have a peace of mind.
  21. Member 12veeRsix's Avatar
    Dec 14th, 2007
    Rockville, MD
    2001 Jetta VR6
    11-15-2011 08:48 PM #21
    that metal putty works pretty well actually. I drove probably 400 miles or so before it started to even show any sort of seepage through it. I used it only as a temp fix, and I had a hole a little smaller than a golf ball.
    I put it on the inside and outside
  22. 11-18-2011 12:16 AM #22
    I guess if you like half assing. I would never do it on any of my cars.
  23. Member _muppet_'s Avatar
    Aug 4th, 2004
    Clarion, PA
    11-18-2011 09:42 PM #23
    Quote Originally Posted by X37 View Post
    You have a steel pan, you should be able to get that fixed for next to nothing if you take it off and clean it up around the hole good enough to be welded. If you were local I would do it for free. Any small welding shop, or exhaust shop would probably only charge you like $10 to weld that up.
    Regarding aluminum pans, I cracked the pan on my s4 the day after I got it. At a local flea market I had picked up some aluminum brazing rods, but they were more like an aluminum solder. I have them out in the garage, I will get some pictures of them. You just heat the piece with a propane or mapp gas torch and work the rod like solder on copper pipes. They actually worked suprisingly well, it held me over until my new pan got here, along with my diesel geek skid plate.
  24. Member speed51133!'s Avatar
    Aug 5th, 2002
    alexandria va/milwaukee wi
    02 audi tt 225 / mk3 jetta /audi 5000s turbo
    11-22-2011 03:16 PM #24
    drain the oil, take off the pan. clean it out with brake cleaner.
    heat up the crack with a propane torch to get rig of oil in the crack, then clean again with brake clean.
    then jb weld it.
    it WILL hold or i will pay for your jb weld and your time!
  25. Semi-n00b
    Mar 4th, 2012
    douglas wy
    04 chrysler sebring, black 99 VW Jetta, 95 saturn SC2, super modified chevy 454 in a 1967 shelby 500
    05-22-2012 10:28 PM #25
    how hot would you say an intake mani gets. dumbsh*t me overtorqued the lower mani to head on my mk4 2.slow and broke it. my old man uses this stuff for lit repairs on heavy mining equipment(1000 tons gross loaded wieght) and he say it works great. but will it hold up to the vibration from an intake mani?
  26. Semi-n00b
    Mar 4th, 2012
    douglas wy
    05-22-2012 10:34 PM #26
    oh and the jb weld isnt a perm fix im waiting to get the money for a new mani. also the torque is only 15ft-lbs so its really not that tight either.
  27. Member Eganx's Avatar
    Apr 30th, 2004
    Poulsbo WA
    built 90 jetta coupe
    05-23-2012 12:26 AM #27
    a necro thread........resurrected form the dead for a second time.......
  28. Member speed51133!'s Avatar
    Aug 5th, 2002
    05-23-2012 12:28 PM #28
    ive done it on a turbo drain that i cracked. gobbed it all over and it held fine for years.
    to do a proper jb weld you wanna take it off, clean it, heat it to burn off any oil, and then jb weld it by using a flat piece of aluminum or steel to cover the crack and jb weld that little patch.
    for all the hasstle...just replace or get it real welded.
    what location are you in? im sure somoen can do it or reccomend where from here.
  29. Member
    Apr 6th, 2008
    1981 Jetta 16v ITB/CIS, 1982 Jetta ABA Turbo, 1977 Scirocco pile
    05-25-2012 01:58 PM #29
    i've seen JB weld hold together air cooled beetle steering rods
    i've also used JB to repair a bad weld on the inside of an intercooler under pretty significant boost
  30. Member irishmpls_2's Avatar
    Sep 23rd, 2005
    Dulloof, Minnesota
    1992 Volvo 240 Sedan
    05-31-2012 12:09 AM #30
    Just use juicy fruit.
  31. Member
    Dec 2nd, 2008
    Northern, Delaware
    96 Golf 2.0 GL
    06-01-2012 11:26 AM #31
    I used JB weld on the side of a block on the dip stick tube of a jeep and it has been fine for over 10 years and 25k miles now. I know it gets over 150 under there when Im wheeling.
  32. Member jegas6228's Avatar
    May 25th, 2012
    Edgewood Maryland
    03 GTI 1.8T / 85 S-10 421c.i. 10.08 @ 134.7 all motor
    07-03-2012 10:36 PM #32
    this is off a little, but same concept i guess... i bought a 2003 yamaha warrior quad, and upon getting it home i noticed right above the sprocket where the guard would bolt via a enraised boss was broken off and took part of the case with it, well whoever did it wadded up some type of epoxy puddy and crammed it in there and smoothed it over.... it works, it dosent leak oil at an alarming pace but there is a damp area around it where it has been seeping, i personally would not have went that route but until riding season is over, thats how its gonna stay, with the oil pan... what if it dosent hold, then what, oil everywhere but where it needs to be, and your out at least a bottom end, those pans are changeable with the motor still in the car, id swap it out before i drove mile one
    there is nothing subtle about a rod knock!
  33. 07-22-2012 03:16 PM #33
    Quote Originally Posted by speed51133! View Post
    Also make sure you use the 12 hour kind, not the quick dry, it holds a lot better.
