Hi, could you help me with my error codes ? I have my Golf MK4 Break for a month, and i still haven't found a way to correct my door problem.
Here's my scan result.
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 038 906 012 FB
Component: 1,9l R4 EDC 0000SG 3350
Coding: 00002
Shop #: WSC 01317
WVWZZZ1JZ2W115352 VWZ6Z0A3450112
1 Fault Found:
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-10 - - - Intermittent
Readiness: N/A
"This one is ok"
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 E
Component: ESP FRONT MK60 0104
Coding: 0019458
Shop #: WSC 01317
No fault code found.
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1J0 920 806 E
Component: KOMBI+WEGFAHRS. RB8 V06
Coding: 01112
Shop #: WSC 07950
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 01317
Address 46 -------------------------------------------------------
Controller: 1C0 959 799
Component: 1F Komfortgerát HLO 0001
Coding: 00259
Shop #: WSC 01317
45 Faults Found:
01358 - Internal Central Locking Switch: Driver Side (E150)
27-00 - Implausible Signal
01362 - Close Switch for Tailgate/Trunk (F124)
29-00 - Short to Ground
01032 - Central Locking Key Switch: Passenger Side: Lock
01030 - Central Locking Key Switch: Driver Side: Lock
01359 - Internal Central Locking Switch: Passenger Side (E198)
01389 - Tailgate Open Switch (F124)
01033 - Central Locking Key Switch: Passenger Side: Unlock
01031 - Central Locking Key Switch: Driver Side: Unlock
01134 - Alarm Horn (H12)
77-00 - Internal Supply Voltage
37-00 - Faulty
01330 - Central Control Module for Central Convenience (J393)
52-00 - Supply Voltage Too High
53-00 - Supply Voltage Too Low
01038 - Central Locking Thermal Protection
35-00 - -
01336 - Data Bus for Comfort System
80-00 - Single-Wire Operation
00952 - Signal: Drivers Door Open
28-00 - Short to B+
00948 - Signal: Close sliding Roof
28-00 - Short to B+
37-00 - Faulty
00949 - Central Locking Motor - tailgate (V53): LOCK
25-00 - Unknown Switch Condition
00950 - Central Locking Motor - tailgate (V53): UNLOCK
00928 - Locking Module for Central Locking: Front Driver Side (F220)
00929 - Locking Module for Central Locking: Front Passenger Side (F221)
00930 - Locking Module for Central Locking: Rear Left (F222)
00931 - Locking Module for Central Locking: Rear Right (F223)
01131 - Control Circuit for Turn Signals
01334 - Door Control Module: Rear Right (J398)
49-00 - No Communications
01333 - Door Control Module: Rear Left (J388)
01332 - Door Control Module: Passenger Side (J387)
01331 - Door Control Module: Driver Side (J386)
01299 - Diagnostic Interface for Data Bus (J533)
00849 - S-contact at Ignition/Starter Switch (D)
00954 - Starter Inhibitor Relay (J433)
28-00 - Short to B+
54-00 - Incorrectly Equipped
00945 - Crash Sensor (G190)
00946 - Interior Light (W)
28-00 - Short to B+
00953 - Interior Light Time limit
00951 - Tailgate Central Locking Motor Relay (J398)
28-00 - Short to B+
01141 - Luggage Compartment Unlocking Switch (E165)
00947 - Trunk Lid remote Control Switch (E188)
01483 - Control Circuit for Rear Lid Remote Unlocking
End -------------------------------------------------------
Digging in VAGCOM, i found that my rear left door is in "SAFE" mode. There's so much error, I don't know where to start.
