Results 1 to 24 of 24
Thread: Project Caddy: The Never Ending Story....
  1. 04-22-2009 04:51 PM #1
    Here is were it all started:
    Note:
    The paint DID not look that good!!
    I paid $2750
    passenger Fender liner was rusted almost to the frame rail!!! Luckily I was able to salvage the
    Frame rail. The project almost lost its wind!
    Car is not for sale!
    Other than minor other body damage the car ran like a champ!
    The first Pic
    The second Pic
    Interior: This is after the FOX wheel and Corrado seats...Thanks Mark!
    Wheel Upgrade: Corrado Steel Thanks again Mark
    Next came the Engine Rebuild and the shell off to the body shop
    Modified by EPwerks at 2:16 PM 4-22-2009
  2. Member deathhare.'s Avatar
    Apr 1st, 2008
    Isle of Man
    2 stroke
    04-22-2009 04:54 PM #2
  3. Member mbg_euros's Avatar
    Feb 14th, 2008
    Mechanicsburg, PA
    mk6 mk3 mk1
    04-22-2009 05:00 PM #3
    nice
  4. 04-22-2009 05:11 PM #4
    Looking pretty good already IMO Spaced the wheels 10mm
    Before
    After
    Its amazing how much you will pick and clean at an engine when its out of the car and easily accesible
    The Bad
  5. 04-22-2009 09:53 PM #5
    My 81 is same color, original paint, no rust. Similar interior. Daily driver 150 or more miles per day. \
    Would be interested in your paint outcomes, my paint job won't last forever....
  6. 04-23-2009 05:00 PM #6
    Engine Rebuild
    Full Gasket/seal kit
    Cleaned/wire brushed/sanded/Painted/Etc...
    I kinda liked the camo look the old green paint gave the block.
    Gloss Black
    New Headers
  7. Member firewall's Avatar
    Jun 17th, 2008
    san diego, CA
    1998 BMW 750il, 1983 MK1 Rabbit RIP
    04-23-2009 06:22 PM #7
    nice.... headers hahahah
  8. Member deathhare.'s Avatar
    Apr 1st, 2008
    Isle of Man
    2 stroke
    04-23-2009 06:25 PM #8
    Um..those headers will never work.
    The diameter is too large for the 1.6.
  9. 04-24-2009 12:27 PM #9
    Quote, originally posted by deathhare. »
    To wide and one short
  10. 05-05-2009 05:33 PM #10
    The First Round of Body Work
    Before:
    After:
    I was pretty worried about the hole here but it turned out nicely....Hopefully I won't see any more rust form there
    Next was the decision to shave the body line or just fill in the holes.....This was a long process were about 20 long hours were wasted. The good news is that I am now an expert in body filler......DON'T DO IT!!!!
    Way back before I started messing with it....
    Modified by EPwerks at 2:39 PM 5-5-2009
  11. 05-05-2009 06:00 PM #11
    What not to do
    I looked into welding the body line and that was way tooooo MUCH $$$$ and too difficult
    Next I looked into the cheap way...I thought i would never say it....BONDO
    This was a very dirty and educational process. Unless you don't mind your garage covers in dust. Don't do it. Plus after all that work you have the potential of cracking. Besides I found out later that the body line was too deep to fill safely.
    More body work:
    The fender wells are very bad so getting these perfect is going to be hard...Here's the first try
    Modified by EPwerks at 3:02 PM 5-5-2009
    Mar 16th, 2008
    San Diego
    1981 1.6 Diesel VW Rabbit Pickup
    05-05-2009 11:37 PM #12
    Looks like a pretty good job... I bet its gonna turn out nice! Great work!
  13. Member SGLoki's Avatar
    Dec 12th, 2004
    The Ham
    88 fox RIP 86 jetta RIP 81 rabbit RIP, 1984 GTI RIP, 03Ranger RIP, (03 Legacy, 03 Allroad, 86 Jetta)
    05-06-2009 03:01 AM #13
    Yo bastian, you think I could get some BBS's or some ****in konigs up in this bish?
    1% defined: Lone wolf, no club. Duct tape it yourself. It is broken down 1% of the time, and work is always 1% completed.
    2% defined: I'm too old to drive broken sh*t and VW people are cool. DBVW!
    Quote Originally Posted by nsindel View Post
    May I introduce Senor SGLoki -
    the man, the myth, the slamdancer...
  14. Member VWJerm's Avatar
    May 5th, 2002
    Strathroy Ontario
    81 Pickup
    05-06-2009 07:07 AM #14
    truck looks good, but I wouldn't have shaved that body line, it is near impossible to make that look proper because that bodyline is at different angles from top to bottom. Its almost like you need a flat sanding board as long as the bed to do it proper.
    For Sale:
    - 2.5", 3", 3.5" rear drop plates, best price on the vortex
    - Rear Spindle spacers (1/2" and 3/8")
    PM me for more info.
  15. 05-06-2009 08:18 AM #15
    Quote, originally posted by VWJerm »
    Yep! You are Right! My next segment is me tearing all the F'n Bondo from the body line.
    I am now just going to weld the holes up and mess with edges a bit. It would have looked so clean but not worth the hassle at this point.
    your right about the different angles too! once I started sanding and saw the edge forming as I worked the bottom and top down.....I was worried
    About the wheels I was thinking of just keeping these and having them widened a few inches. on the other hand I would also like something with less Rotational mass....BBS is shi!
  16. Member VWJerm's Avatar
    May 5th, 2002
    Strathroy Ontario
    81 Pickup
    05-06-2009 09:14 AM #16
    Quote, originally posted by EPwerks »
    I am now just going to weld the holes up and mess with edges a bit. It would have looked so clean but not worth the hassle at this point....
    don't make the same mistake I did, keep that area where you are welding cool, hit it with water or a cold blast of air during and after the weld, if not you will warp that top bed surface. I did that and it was a biatch to get it straight again.
    For Sale:
  17. 05-06-2009 10:57 AM #17
    Right on for the advise
    It was the main concern when I talked to the welder...
  18. 05-06-2009 01:43 PM #18
    Just for kick here's how it turned out....About and hour later I was chipping it out with a chisel and hammer
  19. 05-06-2009 05:38 PM #19
    Body Shop Update
  20. Member Curt_pnw's Avatar
    Nov 27th, 2005
    Edmonds, Wa
    67 Square project, 68 Squareback, 85 Volvo 245
    05-19-2009 05:15 PM #20
    Lookin good! I love the rado steels on it.
  21. Banned
    Oct 16th, 2008
    05-19-2009 09:07 PM #21
    looks good.... i always wanted one. For future references, weld metal strips across the whole trim line when you decide to shave them.... that way you end up using less body filler.
  22. Member audindy's Avatar
    Jul 19th, 2007
    Indianapolis IN
    B7 Audi A4
    07-09-2009 10:09 PM #22
    i demand updated pictures!! i know they are out there lol
  23. 02-27-2011 08:56 PM #23
    what happened to this?
  24. Member MicroCADDY's Avatar
    Jul 21st, 2008
    Louisville, KY
    VW Caddy, VW THING & Audi A4 Quattro
    02-28-2011 07:49 AM #24
    Quote Originally Posted by EPwerks View Post
    What not to do
    More body work:
    O NO you didn't just fill that whole body line with bondo. This is the wrong way to shave that body line. Over time is WILL crack & pop out. That needed to have strips of sheet metal welded in & then have a thin coating on bondo
