| Quote, originally posted by boraIV » |
| Everything looks good so far.. what's going on in the right side of this photo... something is crooked. |
Thanks. If your your talking about the wall around the furnace its a three sided cover not nailed to the wall. Its prob has debris under it making it crooked.
| Quote, originally posted by Rlyeezz2 » |
| where in portland is that, looks like outer se?? |
Yep almost towards Gresham.
| Quote, originally posted by overby » |
| Looks good! Quick one about the furnace though... does your furnace have 1 pipe that goes to the outside or 2? If its only one, you may need to create an opening in the wall/door to allow air in to ensure complete combustion. Just noticed there is a water heater there as well... if it is completely enclosed you need to make an opening to allow air to come in so it isn't producing carbon monoxide and aldehydes. |
Thanks for the info. It has two pipes going up but ill double check them. I left a 5 inch gap on the back side and a 2 inch gap along the top. Its a pull away false wall. Thanks for the info on the water heater too! there is a window in that room so ill prop it open.
Here are a few pics of the garage so far. Its taken with my Iphone so the color is off. Looks way better in person.
Im going to try to finish painting this weekend. Then next is lighting and flooring. I have a sample piece coming from floorjunkies.com Ill see how I like it.
This is where i got my inspiration from.
