I feel like swapping my Rtails for red ones. Anyone in DC.MD.VA area interested?
#1506
#1507
#1508
#1509
2011 CC VR6 4Motion Executive, CW, Unitronic Stage I, 20" Q7's, Eibach Pro's, Gold Coast Kit, R steering wheel, 25% tint
Previus: 09 CCVR6 Sport - 04 GLI - 97 Jetta VR6
#1510
"Never Drive Faster Than Your Guardian Angel Can Fly"
Selling my 2010 CC with only 9000+ miles
http://forums.vwvortex.com/showthrea...-miles-DC-Area
#1511
'13 BMW M-Sport 328i 6mt Estoril Blue II
'98 M Roadster Dinan/RMS stage 2 13psi nearly 500hp@crank
http://i164.photobucket.com/albums/u...en/MTSLsig.jpg
#1512
#1513
Like I've posted before....they pair up perfectly with the OEM dampers while keeping an OEM like ride still
They're linear like the stock springs, but shorter (obviously) and slightly firmer to compensate for the shorter length (instead of a longer, softer OEM spring)
This is probably the best suspension setup for most of the guys on here....looking for a mild drop on their daily driver....and at only $220 for the springs it's a good deal considering you won't need new dampers
I was even paranoid when I bought the Pro-Kit springs (since I had a bad experience with the H&R's) and bought the Pro-Kit Dampers to go with them as well....without even trying them with the factory ones first
That ended up being a waste of $500. It rode like crap....it was rough and not smooth at all. It was too stiff.
Took them off and paired them up with the factory dampers instead....rode waaaay nicer.
From when Eibach introduced the springs:
"For those looking for the ultimate balance of ride comfort and response, The Pro-Kit lowered springs work in harmony with the factory damper units to lower the car by approximately 30mm"
'13 Passat VR6
#1514
'13 Passat VR6
#1515
Concept One RS-55 20x8.5 et38 front 20x10 et43 back.
Hankook Ventus V12 225/30/20 and 245/30/20 on Koni Coils
#1516
^Looks excellent... OEM + perfection
DubsOfQueens.com | Tyrol Sport | BSH Street Team
#1517
Beatiful, wash......
Mine's gonna look similar:
Koni coilovers going on with the month, with 20 x 8.5, 20 x 10 Lexani LSS-5 wheels (split 5-spoke)
Just got "chipped" (GIAC) on Tuesday.
Can't wait to get LOWER........
TM
#1518
#1519
#1520
^Definately not. He was on 22x9 front and 22x10.5 out back if i remember correctly. You'll find his specs on one the teen pages
#1521
Been looking at alloys for when my suspension arrives.
I like the OEM look, but want to make sure the increase in size is noticeable.
I viewed these today, they are available in 19" and 20", but think I will have to go with the 20's.
I have seen pics of these in 19", but has anyone ever seen them in 20".
They are 20" x 8" et35 so should be about right with spacers up front.
VW Passat CC 2.0TDI 170 GT
#1522
Question for those with KWv1 / ST Coilovers.
Did you need to add spacers to have enough clearance for the wheels?
(I did with MK4 GTI and wanted to make sure)
#1524
I have the stock 18s, and just wasn't sure if they would rub against the coilivers.
How do you like the ST? Is the ride firm/harsh?
#1525
First mod on the CC4M was to tint the windows today, but as soon as the PSS10s come in, getting the ride height to the the desired level and then spacing the Sagittas to fill the arches.
The final note - "The pursuit for a Passat/CC 4Motion performance exhaust"
'Ein Trottel nicht an der Tat zu hören"
#1527
Well i too worry about winter. But ST are same as KW V1, minus the stainless part.
Galvanized steel is ok, plus it has the anti-corrosive coating on it.
Michigan is a bit different than DC though, i hope it will be okay.
I had the KWv1 on my 03GTI, and they were great, but i got them for $850 at waterfest from HPA stand.
Doubt i'll ever a see a deal like that again.
#1528
I was torn last year between the V1's and the ST's. And due to my budget, I went with the ST's and just planned on removing them for winter anyways.
But I just took them off in the fall and sold them instead.
The V1's were ~$1050-1100 IIRC ($300 more than the ST's)
If I had to do it all over again, I should've gotten the Koni's to begin with for $980 SHIPPED:
http://www.redline-motorworks.com/pr...0.htm?CartID=1
COUPON CODE: GETKONI4LESS
They go lower than the ST's/V1's, are adjustable, and are cadmium plated and will hold up as good as the stainless
Needless to say, I just bought a used set of Konis in good shape
'13 Passat VR6
#1529
#1531
I work for a steel fab shop, and salt water from the road will corrode galv pretty quick, SS is the way to go. Just sayin....
I am here: http://tapatalk.com/map.php?2bz0bp
#1533
| Mark | 2011 CC R-Line DSG |
#1534
Bilstein PSS10s came in today. Now it is a matter of getting them installed.
#1535
'13 Passat VR6
#1536
20" Q7 reps wrapped on Falken 452's 245/35/20
Lowered on H&R springs
Front ET 40, rear 45.
#1537
Absolutely stunning with those new shoes on it and the drop.
I am here: http://tapatalk.com/map.php?vn33xb
#1540
Hey guys
After this:
Now ATHEO (Touareg) 19x9 with 225/35/19
