Page 3 of 215 FirstFirst 1 2 3 4 5 6 7 13 53 103 ... LastLast
Results 71 to 105 of 7501
Thread: What did you do to your mk1 today?
  1. 05-09-2009 09:08 PM #71
    pushed my project outside so I could clean the shop
  2. Member 83mk2scirocco's Avatar
    Nov 12th, 2008
    StickenBurg,AZ
    84 scirocco,83 Scirocco(parts),76 scirocco"Sabine",85 ledgends turbo scirocco
    05-09-2009 11:39 PM #72
    The same thing I've been doing for the last week,Wire wheeled more surface rust,covered bare metal with primer.
  3. 05-09-2009 11:44 PM #73
    i drove 350 miles just to move another 5 sets of 4x100 wheels into my storage unit.
  4. 05-09-2009 11:56 PM #74
    Motor a-building
    There are some good hybrids.... The ones that burn gasoline and rubber!
    http://forums.vwvortex.com/showthrea...v-build-thread
    DCI until I die
  5. Member 83mk2scirocco's Avatar
    Nov 12th, 2008
    StickenBurg,AZ
    05-10-2009 09:43 AM #75
    The same thing I do every day attacking one rust spot at a time.
  6. Member 83mk2scirocco's Avatar
    Nov 12th, 2008
    StickenBurg,AZ
    05-10-2009 11:27 AM #76
    Ah I looked in the shed and found a shifter knob I salvaged of a 79 rabbit from the wrecking yard.Perfect fit.
    Who ever put that 79 in that yard should be drugged to death by a Rabbit. A 09 with a 2.0t for that matter!
  7. Member Austin_85'MKII's Avatar
    Jul 3rd, 2008
    Fo Co
    86 gti g60/85 gti-sold/82 rabbit- sold
    05-10-2009 01:05 PM #77
    Quote, originally posted by All VW All the time »
    Motor a-building
  8. 05-10-2009 01:30 PM #78
    bought these
  9. Member swedub-13-'s Avatar
    Sep 18th, 2006
    Avesta, Sweden
    1982 Golf GTi
    05-10-2009 01:44 PM #79
    I drove mine and it felt great
    I can bench press a car, I'm an ex football star
    with degrees from both Harvard and Yale.
    www.garaget.org/soilwork
  10. Member Road Boss's Avatar
    Jul 15th, 2004
    Woodbridge, VA
    84 VW Rabbit GTI, 84 VW Jetta Coupe
    05-10-2009 06:33 PM #80
    I washed it!
  11. Member wantacad's Avatar
    Apr 3rd, 2003
    Belleville,Ill
    I haz a bunnah
    05-10-2009 06:39 PM #81
    Replaced 25+year old axle (surprisingly with both ripped boots and bone dry it wasn't completely trashed, GO VW! )
    Quote Originally Posted by WackyWabbitRacer View Post
    You're new here but don't be a DORK.....
    Cheers, WWR.
    Quote Originally Posted by dsleggett View Post
    I have a great idea, upgrade to the big 3: periods, commas and capital letters! I realize I'm old but I cannot read some of this s**t.
  12. Member 83mk2scirocco's Avatar
    Nov 12th, 2008
    StickenBurg,AZ
    05-11-2009 11:25 AM #82
    Ah, a new day I'm going to make a 120 mile round trip to pick up a wheel bearing,and go to affordable german to brag about my rabbit.
    Oh I will be doing this trip in my 83 wolfie rocco.
  13. Member newfoundgti's Avatar
    Dec 23rd, 2002
    St. John's, NL Canada
    1982 Rabbit Black Tie Edition 1983 GTI 2009 Rabbit
    05-11-2009 12:00 PM #83
    Took it out for the first slalom event of the season and popped a brake line during tech inspection You can see the puddle of fluid under the car. Goodthing the event was just a Test & Tune and not part of the regular points season and better for it to pop a line during tech inspection. Time to replace all the lines.
    I need a new drivers side rear mudflap for my truck as well
    newfoundgti
  14. Member 83mk2scirocco's Avatar
    Nov 12th, 2008
    StickenBurg,AZ
    05-12-2009 01:03 AM #84
    Irealized how much work I got ahead of me.
  15. Member egranlund's Avatar
    Jul 21st, 2008
    Lafayette, CA
    1986 and 1987 Cabriolet
    05-12-2009 01:16 AM #85
    Got my 6th alignment in the span of a month of doing some front end work (wheel bearings, etc)
    Car still pulls, wheel still shakes and is not centered.
    I promptly yelled various swear words traveling home...thinking maybe my tires are screwed.
    Still out of money...really need suspension...
  16. Member 83mk2scirocco's Avatar
    Nov 12th, 2008
    StickenBurg,AZ
    05-12-2009 09:18 AM #86
    Quote, originally posted by egranlund »
    X2 minus the non centered rim it could very well a seperated tire.If you spent that much money on alighnments they should have checked that problem.
  17. Member chrisbmx68's Avatar
    Aug 14th, 2003
    Collegeville PA
    2004 r32, 1991 318is
    05-12-2009 09:24 AM #87
    worked toward getting this running the other day
  18. Geriatric Member JUS_GT_EYEZ's Avatar
    Nov 12th, 2001
    NY/NJ
    Green MK1, Red Mk2,White Mk3, Yellow Mk4
    05-12-2009 09:34 AM #88
    Motor a-building
    I can only think of one car this would be clearly at home in..
    did a bunch of little things last night... cleaned a braket or two, put in new valve cover gasket and freshly painted valve cover. R routed a few wires, few more zipties, a little paint here and there...
    "Its cool to spool, but I'd rather be blown.." - JUS_GT_EYEZ
    My FLickr <-- DUKEDLF
    Digital.Life.Form
  19. 05-12-2009 10:15 AM #89
    what did I do to my MK1 today....looked at it in disgust.
    A4 | 84 | FLHX | PVW 02/09
    For the Love of German Cars
  20. Member Rockhead261's Avatar
    Jan 5th, 2004
    Brewster, New York
    '75 Eldorado vert, '13 Sierra Denali CC D/A, '11 Outback 3.6R
    05-12-2009 12:20 PM #90
    1. Pulled various interior pieces for refinishing.
    2. Laughed/grimaced at the spray foam "insulation" job one of the PO's did behind the rear cards.
    3. Removed large chunks of aforementioned spray foam.
    4. Started tearing apart three driver seats to make one mint one.
    5. Admired my NOS flakes with brand-new P6's before putting it back in the garage.
    Rockhead
    '75 Eldorado 'vert, '13 Sierra Denali 2500 CC D/A, '11 Outback 3.6R, '12 FLHTCUI
    Quote Originally Posted by minibike hero
    Alternately, you could set his house on fire. Tall grass + leaking fluids + Lucas = plausible alibi.
    Necrospam!
  21. Member 83mk2scirocco's Avatar
    Nov 12th, 2008
    StickenBurg,AZ
    05-12-2009 11:10 PM #91
    Quote, originally posted by 83mk2scirocco »
    Put back to gether my RF spindle wuth new bearing and peace and quite.Now i can drive again.
  22. Member MadTextureYo's Avatar
    Jun 10th, 2006
    CT
    Mk4 Tdi, The Easter Bunny
    05-12-2009 11:12 PM #92
    just about finished up the rain tray, and did some work on lengthening the harness.
  23. Member Deaner's Avatar
    Dec 28th, 2004
    Alberta
    mk2 vr6 , scirocco, landcruiser
    05-12-2009 11:27 PM #93
    I picked it up !
    84' coupe, beige on beige !
    Doesn't run right now.. needs a starter, and a rad. Also needs wheel cylinders (and a brake bleed)
    Went and picked it up for the staggering price of $FREE
    Shell is in very good shape (considering it has 402,000kms)
    I'm excited to have an A1 . . . my first VW was a scirocco.. then I went to mk2's (i still have one). . should be a fun project
  24. 05-12-2009 11:51 PM #94
    great find man...coupes are the biz....
    and on another note...
    Quote, originally posted by MadTextureYo »
  25. Member Darth LE9C's Avatar
    Dec 5th, 2008
    East Coast till 2012
    05-13-2009 01:17 AM #95
    polished my antenna ...thought I was actually productive today till I see you guys shaving bays and re-building engines
  26. Member 83mk2scirocco's Avatar
    Nov 12th, 2008
    StickenBurg,AZ
    05-13-2009 01:21 AM #96
    Quote, originally posted by Darth LE9C »
    At least you dont have to thousands tiny rusty spots to wire brush Ive been doing it for a week and only got the roof done.
  27. Member
    Aug 4th, 2000
    Kailua, HI
    MK1 GTI, '95 Golf 2.0T
    05-13-2009 03:36 AM #97
    Washed car and pretended not to see all the rust bubbles on the roof rails.
  28. Geriatric Member JUS_GT_EYEZ's Avatar
    Nov 12th, 2001
    NY/NJ
    05-13-2009 08:09 AM #98
    Quote, originally posted by OLD-GTI »
    uh-ohhh
    made a to do list of things to do before the weekend... my to do lists never seem to get shorter.
    Digital.Life.Form
  29. 05-13-2009 08:19 AM #99
    5th. gear swap.
    Off this week without pay. Current economy
    Working all week getting Red Wow back together.
    DCI until I die
  30. Member 83mk2scirocco's Avatar
    Nov 12th, 2008
    StickenBurg,AZ
    05-13-2009 09:25 AM #100
    I get to drive my rabbit to work.Who care if it dont got floor boards its a Wabbit. It needs way more suspension work.WAY more.But its ok cuz I got a rabbit.A 77 rabbit.
    Modified by 83mk2scirocco at 3:53 PM 5-13-2009
  31. 05-13-2009 07:30 PM #101
    Got the A/C working and hooked up a boost gauge.
    Thursday and Friday I will be getting the Caddies ready for SOWO
  32. Member clintg60-16v's Avatar
    Dec 13th, 2002
    Fishers, Indiana
    '90 Corrado 1.9 16V Lysholm, '06 Passat 2.0T, '07 Passat Variant 2.0T, '75 Chrome Yellow Rabbit
    05-13-2009 08:33 PM #102
    I began gathering all the stuff up that goes with it...for the new owner...
    "Sense is something you can't even make sense of until you've been to the future, and spent time there..."
  33. Member deer_eggs's Avatar
    Oct 4th, 2006
    Salem County, NJ
    1986 VW Cabriolet
    05-13-2009 09:19 PM #103
    I drove it, like I do every day
    I did put the fender flares on, for the first time since 2006, this past weekend
    Click here to bother me on facebook...
    Check out mk1dubz.com,a better Mk1 site.
    KDI customs custom upholstrey shop in Joppa, MD. Check out the new website! He can seriously do anything.
  34. Member 83mk2scirocco's Avatar
    Nov 12th, 2008
    StickenBurg,AZ
    05-14-2009 12:02 AM #104
    Quote, originally posted by clintg60-16v »
    Man sorry to hear that I hope its not because of the economy.
  35. Member 83mk2scirocco's Avatar
    Nov 12th, 2008
    StickenBurg,AZ
    05-14-2009 12:05 AM #105
    Ok I put a hose clamp on my driver side mirror,And scored on a passenger side mirror.So I now can safely and easly change lanes.
    Last but not least i figured out why the speedometer does not work.
