VWVortex.com - What did you do to your mk1 today?
    Page 4 of 379 FirstFirst 123456781454104 ... LastLast
    Results 76 to 100 of 9463
    Thread: What did you do to your mk1 today?
    1. Member 83mk2scirocco's Avatar
      Nov 12th, 2008
      StickenBurg,AZ
      84 scirocco,83 Scirocco(parts),76 scirocco"Sabine",85 ledgends turbo scirocco
      05-10-2009 11:27 AM #76
      Ah I looked in the shed and found a shifter knob I salvaged of a 79 rabbit from the wrecking yard.Perfect fit.
      Who ever put that 79 in that yard should be drugged to death by a Rabbit. A 09 with a 2.0t for that matter!
    2. Member Austin_85'MKII's Avatar
      Jul 3rd, 2008
      Fo Co
      86 gti g60/85 gti-sold/82 rabbit- sold
      05-10-2009 01:05 PM #77
      Quote, originally posted by All VW All the time »
      Motor a-building
      [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    3. 05-10-2009 01:30 PM #78
      bought these
    4. Member swedub-13-'s Avatar
      Sep 18th, 2006
      Avesta, Sweden
      1982 Golf GTi
      05-10-2009 01:44 PM #79
      I drove mine and it felt great [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      I can bench press a car, I'm an ex football star
      with degrees from both Harvard and Yale.
      www.garaget.org/soilwork
    5. Member Road Boss's Avatar
      Jul 15th, 2004
      Crossville, TN
      84 VW Rabbit GTI, 84 VW Jetta Coupe
      05-10-2009 06:33 PM #80
      I washed it!
    6. Member wantacad's Avatar
      Apr 3rd, 2003
      Belleville,Ill
      I haz a bunnah
      05-10-2009 06:39 PM #81
      Replaced 25+year old axle (surprisingly with both ripped boots and bone dry it wasn't completely trashed, GO VW! )
      Quote Originally Posted by WackyWabbitRacer View Post
      You're new here but don't be a DORK.....
      Cheers, WWR.
      Quote Originally Posted by rte7x9 View Post
      Don't swap if you can't weld or fabricate. It's not a trivial task just to bolt everything up. There's a lot of nut-scratching involved. Take your time and do it right.
    7. Member 83mk2scirocco's Avatar
      Nov 12th, 2008
      StickenBurg,AZ
      05-11-2009 11:25 AM #82
      Ah, a new day I'm going to make a 120 mile round trip to pick up a wheel bearing,and go to affordable german to brag about my rabbit.
      Oh I will be doing this trip in my 83 wolfie rocco.
    8. Member newfoundgti's Avatar
      Dec 23rd, 2002
      St. John's, NL Canada
      1982 Rabbit Black Tie Edition 1983 GTI 2009 Rabbit
      05-11-2009 12:00 PM #83
      Took it out for the first slalom event of the season and popped a brake line during tech inspection You can see the puddle of fluid under the car. Goodthing the event was just a Test & Tune and not part of the regular points season and better for it to pop a line during tech inspection. Time to replace all the lines.
      I need a new drivers side rear mudflap for my truck as well
      newfoundgti
    9. Member 83mk2scirocco's Avatar
      Nov 12th, 2008
      StickenBurg,AZ
      05-12-2009 01:03 AM #84
      Irealized how much work I got ahead of me.
    10. Member egranlund's Avatar
      Jul 21st, 2008
      Lafayette, CA
      1986 and 1987 Cabriolet
      05-12-2009 01:16 AM #85
      Got my 6th alignment in the span of a month of doing some front end work (wheel bearings, etc)
      Car still pulls, wheel still shakes and is not centered.
      I promptly yelled various swear words traveling home...thinking maybe my tires are screwed.
      Still out of money...really need suspension...
    11. Member 83mk2scirocco's Avatar
      Nov 12th, 2008
      StickenBurg,AZ
      05-12-2009 09:18 AM #86
      Quote, originally posted by egranlund »
      X2 minus the non centered rim it could very well a seperated tire.If you spent that much money on alighnments they should have checked that problem.
    12. Member chrisbmx68's Avatar
      Aug 14th, 2003
      Collegeville PA
      1991 318is with sr20det, 1999 a4 avant
      05-12-2009 09:24 AM #87
      worked toward getting this running the other day
    13. Geriatric Member JUS_GT_EYEZ's Avatar
      Nov 12th, 2001
      NY/NJ
      Green MK1, White Rocco, Red Mk2,Yellow Mk4,Grey Wagon
      05-12-2009 09:34 AM #88
      Motor a-building
      I can only think of one car this would be clearly at home in..
      did a bunch of little things last night... cleaned a braket or two, put in new valve cover gasket and freshly painted valve cover. R routed a few wires, few more zipties, a little paint here and there...
      "Its cool to spool, but I'd rather be blown.." - JUS_GT_EYEZ
      My FLickr <-- DUKEDLF
      Digital.Life.Form
    14. 05-12-2009 10:15 AM #89
      what did I do to my MK1 today....looked at it in disgust.
      TDI | GTI | Type 1 | PVW 02/09
    15. Global Moderator Rockhead261's Avatar
      Jan 5th, 2004
      Brewster, New York
      '75 Eldorado vert, '15 Grand Cherokee HA 3.6, '11 Outback 3.6R
      05-12-2009 12:20 PM #90
      1. Pulled various interior pieces for refinishing.
      2. Laughed/grimaced at the spray foam "insulation" job one of the PO's did behind the rear cards.
      3. Removed large chunks of aforementioned spray foam.
      4. Started tearing apart three driver seats to make one mint one.
      5. Admired my NOS flakes with brand-new P6's before putting it back in the garage.
    16. Member 83mk2scirocco's Avatar
      Nov 12th, 2008
      StickenBurg,AZ
      05-12-2009 11:10 PM #91
      Quote, originally posted by 83mk2scirocco &raquo;
      Put back to gether my RF spindle wuth new bearing and peace and quite.Now i can drive again.
    17. Member MadTextureYo's Avatar
      Jun 10th, 2006
      RI
      B7 A4, The Easter Bunny
      05-12-2009 11:12 PM #92
      just about finished up the rain tray, and did some work on lengthening the harness.
    18. Member Deaner's Avatar
      Dec 28th, 2004
      Alberta
      mk2 vr6 , scirocco, landcruiser
      05-12-2009 11:27 PM #93
      I picked it up !
      84' coupe, beige on beige !
      Doesn't run right now.. needs a starter, and a rad. Also needs wheel cylinders (and a brake bleed)
      Went and picked it up for the staggering price of $FREE
      Shell is in very good shape (considering it has 402,000kms)
      I'm excited to have an A1 . . . my first VW was a scirocco.. then I went to mk2's (i still have one). . should be a fun project
    19. 05-12-2009 11:51 PM #94
      great find man...coupes are the biz....
      and on another note...
      Quote, originally posted by MadTextureYo &raquo;
      [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    20. Member Darth LE9C's Avatar
      Dec 5th, 2008
      East Coast till 2012
      05-13-2009 01:17 AM #95
      polished my antenna ...thought I was actually productive today till I see you guys shaving bays and re-building engines
    21. Member 83mk2scirocco's Avatar
      Nov 12th, 2008
      StickenBurg,AZ
      05-13-2009 01:21 AM #96
      Quote, originally posted by Darth LE9C &raquo;
      At least you dont have to thousands tiny rusty spots to wire brush Ive been doing it for a week and only got the roof done.
    22. Member
      Aug 4th, 2000
      Kailua, HI
      MK1 GTI, '95 Golf 2.0T
      05-13-2009 03:36 AM #97
      Washed car and pretended not to see all the rust bubbles on the roof rails.
    23. Geriatric Member JUS_GT_EYEZ's Avatar
      Nov 12th, 2001
      NY/NJ
      05-13-2009 08:09 AM #98
      Quote, originally posted by OLD-GTI &raquo;
      uh-ohhh
      made a to do list of things to do before the weekend... my to do lists never seem to get shorter.
      Digital.Life.Form
    24. 05-13-2009 08:19 AM #99
      5th. gear swap.
      Off this week without pay. Current economy
      Working all week getting Red Wow back together.
      There are some good hybrids.... The ones that burn gasoline and rubber!
      http://forums.vwvortex.com/showthrea...v-build-thread
      DCI until I die
    25. Member 83mk2scirocco's Avatar
      Nov 12th, 2008
      StickenBurg,AZ
      05-13-2009 09:25 AM #100
      I get to drive my rabbit to work.Who care if it dont got floor boards its a Wabbit. It needs way more suspension work.WAY more.But its ok cuz I got a rabbit.A 77 rabbit.
      Modified by 83mk2scirocco at 3:53 PM 5-13-2009
