VWVortex.com - Interior dome light does not come on for Driver's door
    Results 1 to 3 of 3
    Thread: Interior dome light does not come on for Driver's door
    1. 05-02-2009 07:54 PM #1
      2001 Passat 1.8T
      The switch is in the correct position and the light comes on when the passenger door is opened.
      Any idea what causes the light to activate? I cannot find a switch anywhere on the door frame. Maybe a magnetic switch in the door?
      Thanks for the help.
    2. Member mrgreek2002's Avatar
      Sep 30th, 2002
      Toronto, Canada
      MKVI Jetta & MKIV Golf
      05-02-2009 10:57 PM #2
      There's a switch in the door that gets damaged by constant slamming of the door. $200 in parts and 2 hours labor. Not a cheap fix. [IMG]http://*****************.com/smile/emthdown.gif[/IMG]
    3. Member scotts13's Avatar
      Feb 15th, 2007
      Lehigh County, Pa.
      2004 GLS 1.8T
      05-03-2009 06:01 PM #3
      Quote, originally posted by New2Passat »
      2001 Passat 1.8T
      You can't find it because it's an internal part of the latch mechanism. Other than that, as stated previously - and expensive part and a fair bit of labor.
      If you're handy, patient, and confident, you may be able to solder a new switch to the existing latch. THIS http://www.taligentx.com/passa...nism/ will get you started.
