Superb write up..
very impressed you did this and took time to video it, edit it well, and post up for others to learn from.
thankyou sir.
#36
+2 cookies for you!!![]()
I always wanted to see a good write up like this!
Edit- Pg2 is mine.
#37
Superb write up..
thankyou sir.
GT35R, Full-Race, DTA S60, SEM, WMI, 8 injectors, SQS Transmission, 1000kg car, >500bhp, Racecar (circuit)
www.badger5.co.uk
#40
Did you use the GB Flex Hone 83mm Silicon Carbide 180 grit tool?
#41
Yep, thats what he used.. Impressive vid my friend
Quote, originally posted by number1275 » Did you use the GB Flex Hone 83mm Silicon Carbide 180 grit tool? ![]()
01' BT Jetta
Disco Potato Club
#42
Nice Job. I'm sure this will help alot of folks.
#43
Quote, originally posted by number1275 » Did you use the GB Flex Hone 83mm Silicon Carbide 180 grit tool? any websites that sells them? aka link for one?
also a link for the thing that cleans the block and head?
#44
This is where I got my Flex Hone and I found this 3M Not sure the 3M is the correct one...waiting for the OP to chime in
Modified by jwalker1.8 at 5:42 PM 5-5-2009
FS/FT 2001 TT (400 WHP) Roadster Wisconsin lots of extras http://forums.vwvortex.com/showthrea...lots-of-extras
#45
Very nice work. One thing though. i wouldn't pound/tap the rod open after the plasti gauge step. you are effectively pounding on the plasti gauge until the dowels let go. This could throw your measurements off a bit. otherwise good job.
#46
Quote, originally posted by jwalker1.8 » This is where I got my Flex Hone and I found this 3M Not sure the 3M is the correct one...waiting for the OP to chime in yes and yes
it was a 3.25" GB 180 grit silicone carbide...you can find them on ebay pretty cheapthats a good find on the 3m roloc bristle disc for 8 bucks. they are hard to come by without buying at least 10
Modified by jazzpur at 6:25 AM 5-6-2009
#47
Quote, originally posted by DubGray1.8T » Very nice work. One thing though. i wouldn't pound/tap the rod open after the plasti gauge step. you are effectively pounding on the plasti gauge until the dowels let go. This could throw your measurements off a bit. otherwise good job. i see what you are saying, but we are talking about tightening a 3/8" bolt to 50lbft.....that yields approx 8000 lbs of axial clamp force per bolt ...times two bolts...thats 16,000 pounds of axial clamp force used in flattening that plastigauge...atleast of coarse until clearance is limited to extents
although the shock with the hammer is more of a radial force, i highly doubt that extra 5lb tap with the rubber mallet is effecting the plastigage readings to the point where they are false.
i see what youre saying though, if you guys tap them dont kill it, but trust me....those caps are no fun to take off without a little tap.
again, these are the methods i choose to use...
thanks guys for more props btw
Modified by jazzpur at 6:48 AM 5-6-2009
#48
Quote, originally posted by jazzpur » yes and yes
so the 3.25" ~83mm is fine with our 81mm bore?
good find on the links![]()
#49
Quote, originally posted by lucas13dourado » so the 3.25" ~83mm is fine with our 81mm bore?
good find on the linksyes they are meant to be used on smaller bores, hence the "flex"....with the 83...you know that you are contacting the the cyl walls entirely.
keep in mind, if your motor is has uneven or excessive wear in the cyl walls you should skip this step and have a machine shop professionally hone your block
#50
Thanks to the OP as I will be doing this is a few weeksIts a good confidence builder and shows how easy it really is.
You have my vote on being a FAQ
#51
That 8 dollars does include 10
I saw other sites that charged 60 bux for a box of ten...
#53
nice, that **** at the end of video two was hilarious caught me off guard i was like wtf
Modified by theswoleguy at 6:26 PM 5-6-2009
Project GTi-R:. '04 R32 Chassis w/ 1.8t transplant in the werks
'01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, enormous amount of go fast
'03 GTI: Gutted, Parted & Transplanted
'04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, sold to ejg3855
'13 F150 Ecoboost: Ordered, Rec'd, Triple Black, Tow Truck for other Vehicles.
#56
Quote, originally posted by jwalker1.8 » That 8 dollars does include 10
i think thats prob a typo on their site, they are def worth more than 76 cents each. but if you get 10 in the mail, send me some!
thanks for more props![]()
#57
Quote, originally posted by jazzpur » i think thats prob a typo on their site, they are def worth more than 76 cents each. but if you get 10 in the mail, send me some!
I ordered right after you confirmed they were the correct ones...we will see what happens
#58
Nice video's and good choice in music.![]()
I "ruined" a limited edition .:Race car
R32 Turbo Build Round 2! Faster, Lower, Smoother.
Integrated Engineering
#59
boostin20v, FAQ status??
#60
Part 3 around 6:30 has some interesting stuff on TV![]()
#61
Great guide OP. Thanks for making me realize I'd never be able to this on my own.
2000 Skoda Octavia 1.8T, mods: Revo Stage II, 4 bar FPR, INR tranny and engine mounts, 3" Draft 42 catless turbo back exhuast, vRS front bumper
2010 GTI, mods: Wavetrac LSD, APR Stage II, APR downpipe
#62
Quote, originally posted by tainted_demon » Part 3 around 6:30 has some interesting stuff on TV ![]()
its howard stern ripping on tyra banks
Modified by jazzpur at 11:53 PM 5-9-2009
#63
great vids![]()
I've put quite a few pistons in things over the years and never once thought to use a drill bit as a fulcrum
When I used to race motocross I kept a large stock of circlips after I almost missed the main at Loretta Lynn's
#64
Quote, originally posted by not SoQuick » great vids ![]()
yea after doin a few of them i devised that little trick, def makes things much less frustrating. the hardest thing with these motors is putting the circlips back in. i made it look kinda easy in the vid, but it really hurts your thumbs if you miss...those things are strong, not too flexible. you guys will probably curse a storm on that step, just dont throw the pistons
#65
Got the 3m disc today from link I posted...it was in fact just one disc
#66
You are GOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOD![]()
#67
Amazing Work my friend!! This should help people out so much or at least familirize them with the innards of their motor.. a bunch of![]()
fo you
#68
Quote, originally posted by jwalker1.8 » Got the 3m disc today from link I posted...it was in fact just one disc
o well, still good that you that you found one, they last forever
#69
crap...didnt realise there was that much work to do to do this....the gapping stuff is a total mystery to me.....
#70
its actually really easy, just refresh your decimal notation skills so you understand the use of a feeler gauge. all the gauges are labled...i used 0.016" for the top and 0.018" for the bottom.OEM rings are actually already pre-gapped so some just opt to skip this step and run them right out of the box....but id still use a gauge to feel that they are within spec.
it was my preference to gap these, only because of increased cylinder pressure with a bigger turbo vs a stock motor w/ stock turbo. however, i probably only filed the rings open about 0.002", which is no greater than the thickness of a blonde hair.
