VWVortex.com - Code PO441 - Vapor Canister Purge Valve?
    Results 1 to 18 of 18
    Thread: Code PO441 - Vapor Canister Purge Valve?
      Dec 5th, 2003
      Cleveland, Ohio
      2002 Passat GLX Wagon (2.8L V6 "ATQ")
      05-09-2009 01:06 PM #1
      My 2002 Passat check engine light is on continuously and a code read revealed fault code PO441 (incorrect EVAP system purge flow). I did a search here and it pointed me to the vapor canister (EVAP) purge valve as a likely cause, so I am going to start with replacing this valve as a first step.
      Where is this valve located?
      Any other suggestions re: PO441??
      Is the vapor canister itself prone to failure or clogging? Where is it located?
      Thank you.
      Modified by thscott at 7:49 PM 5-11-2009
    2. 05-09-2009 05:44 PM #2
      The evap purge valve is located on top of the air box. It has both an electrical connection and two vacuum hoses. Before replacing it you might try cleaning it. Dump some carb cleaner in each end and shake it. This has worked for me a couple of times and sure beats the ~$100 for a new one. BTW, the CEL won't clear immediately, so give it a day or two after cleaning before declaring failure.
    3. 05-10-2009 12:59 PM #3
      make sure you try taping both sides on to something clean to see if you get any debris out. a faulty charcoal canister could cause your purge valve to go bad.
    4. Member
      Dec 5th, 2003
      Cleveland, Ohio
      05-11-2009 11:38 AM #4
      Thanks.
      I've located the purge valve - couldn't be easier to get at.
      How does one remove the VW hose clamps? Looks like they have to be cut off to remove.
    5. 05-11-2009 11:24 PM #5
      I just use a side cutters to clip off the one time use clamps then replace them with standard screw type hose clamps.
    6. Junior Member emanuel fresh kidd's Avatar
      May 5th, 2009
      Boca Raton, FL
      '01.5 V6 Passat GLX
      09-07-2009 01:34 PM #6
      hey i got the same code like 2 days ago . im gunna take your advice.
      Dec 5th, 2003
      Cleveland, Ohio
      09-09-2009 10:16 AM #7
      Replacing this valve cleared the code for me - a cheap and easy fix.
    8. 09-28-2011 11:31 PM #8
      I had gotten a rejection sticker due to Code PO441. Did exactly what you said. bought some carburator cleaner and some hose clamps ($5). Expected to wait a couple of days, but an hour later, I noticed that my check engine lite was gone so I rushed to get it inspected and PASSED! Thank you, thank you!
    9. Former Advertiser FCP Euro's Avatar
      Sep 4th, 2008
      Milford, CT
      09-29-2011 12:01 PM #9
      I just put an order in yesterday for one, Ive been coming up with the same code off and on occasionally. Figure it was a cheap and easy part to replace. Also at 185k miles, it wouldn't hurt to replace it. I'll follow up if it clears my P0441 code completely.
      (Click the pic to follow the link)
    10. n00b K8DizzleMK4's Avatar
      Jun 19th, 2011
      Renton, WA
      2000 Jetta VR6
      04-24-2012 02:49 AM #10
      I've gotten same code on my 2000 jetta. I've replaced the purge valve (easy 5 min job) and the gas cap, as well. Didn't clear my code. :/
      Also, whenever I go to get gas (and ONLY then) my car struggles to start. i then pump the gas, and it will turn over. (rough...but then works itself out)
      I'm thinking the only other thing left (other than a pinched hose...which I've checked for) is the charcoal canister. Just picked one off ebay for $49.99....so gonna put that in asap.
      Any advice as to swap this out? Is there easy access through the trunk? Suggestions??
    11. Semi-n00b
      Jun 8th, 2008
      Fort Wayne, IN
      2000 Passat
      10-22-2012 09:03 PM #11
      Hi K8....,
      I'm having the same problem with starting after a fill up. Did you ever find out what the problem was?
    12. 07-17-2013 12:52 PM #12
      i have had the same issue after pumping gas it is driving me crazy trying to figure out what the problem is im tired of seeing the cel so if ya have found out what the problem is i would greatly appreciate the share of knowledge haha
    13. Member rayj's Avatar
      Jun 10th, 2009
      norwalk, ct
      2000 B5 2.8L V6 wagon 2013 jetta 2.5L auto
      07-17-2013 02:54 PM #13
      Quote Originally Posted by bhicks007 View Post
      Cheapest and easiest way would be to replace the gas cap. Then make sure that you tighten it so it clicks when you put it back on.
    14. 07-18-2013 02:30 AM #14
      Quote Originally Posted by rayj View Post
      Thank you I think I'll try that
    15. 04-11-2014 03:39 AM #15
      Hi! I have problems with this (EVAP) Canister Purge Valve as well. Can somewone tell me where can i buy a new one? i would like to replace it
    16. Member
      Dec 5th, 2003
      Cleveland, Ohio
      04-11-2014 11:35 AM #16
    17. 10-30-2015 02:52 AM #17
      Did you ever figure out what the problem is
    18. Member gettajetta13's Avatar
      Jun 22nd, 2008
      Bellevue , wa
      86 1.8 Jetta Sold, 96 2.0 Jetta Sold, 97 2.0 Jetta Sold, 01 vr6 Jetta Sold, 01 Passat b5 cuurent
      11-01-2015 01:50 PM #18
      this is not the exact answer…but I'm not entirely sure you need the vapor canister. I took mine out months ago since there was a crack in the line to it..i never had any fault codes so…it went bye bye. i still have it stored in the garage, and yes i know its for emissions and its illegal or something to not have one but meh….i don't even drive the car during the week.
