| Quote, originally posted by gearshifter6 » |
1.) I noticed you spent $80 on your heater hose. When I was shopping, I saw them for around $20. Are there a difference in the quality of hoses? Do you have a link to where you got yours? |
It is a high temp silicone heater hose but it is very possible I overpaid for it as it seemed high but I was in a hurry and didn't want to shop around. It wasn't the standard heater hose. I got mine from thrifty auto parts which was just bought out by carquest. I assume it was from old thrifty stock.
| 2. Do you think the Venturi effect is strong enough to the point where it may possibly suck oil from the block and cause damage in the form of oil starvation under high load conditions? |
I have driven 900 miles so far including city, highway, 0-60, 1/4 mile runs and brief 120+mph cruises and oil consumption has been zero on the dipstick. Normally I would have seen a slight drop in 900 miles as I watch it very close. So it appears that oil consumption has decreased. The 5000 mile mark will tell for sure as I normally consume about 1/2 quart in 5000 miles. I will be doing UOAs as well.
Also the Honda-tech guy (see thread link above) ran two nipples into the exhaust as his preferred method so I don't think it is pulling too much vacuum. If I get time I need to hook up a vacuum gauge but I don't see it happening in the near future.
| 3. Will connecting the hose to the rear PCV port be just as effective as connecting to the front where you did yours? |
In terms of the stock pcv, crankcase gasses under vacuum go out the front port (see diagram above). While under boost, as I understand it the check valve makes the gases go out the back. I wanted to keep it simple and evacuate just like stock that is why I went off the pcv. I suppose if you blocked the pcv that would be just like having the check valve closed and gases would run out the back line but I never messed with that.
| 4. How is your car running so far? |
at 900 miles:
a) Overall car is running the best it has since new. Smoothness is much better than before and power is noticeably better than before (noticeable improvement, not big improvement), especially running around town.
b) Mpg went up roughly by 2. I have a highway strip where I have tested mpg using the MFD since the car was new. Highest I have got there before was 34.5. Now it gets 37 at the highest on that strip at that speed. Also city mpg seems to have gone up but I don't track mpg in city. It always seems to get about 21 on MFD and now it is always about 24 or higher. Just an impression on city mpg though and not measured.
c) Small but noticeable increase in power when "pulling" under boost. I don't have access to a dyno so I don't have any measurables. It is definitely noticeable with butt dyno and 0-60 times went down a little.
d) Oil consumption appears to have decreased but really too early to tell on that as 5000 miles would be a good point to measure
e) Only negative is a slight oil smell and residue noticed at tailpipe. Only noticeable if you are into sniffing tailpipes ha ha.
My impression of the pcv problem is that we are fighting pcv-derived problems from the time when the car is new. Kudos to Rl_RS4 who has done so much work to discover and describe this problem in the audi engines. As the vw language above shows, the pcv gunk on the valves causes numerous other problems, misfiring, incomplete combustion, coil packs going bad, dirty fuel injectors, etc. If I were to speculate, I would say it may also contribute to ring deposits and increased fuel dilution/premature oil breakdown. It is all interrelated. The DI engine is extremely efficient and powerful but it depends on precision and a clean engine and this pcv gunk pugging things up has multiple effects.
The Honda tech guy tested numerous crankcase evacuation methods on his turbo engine and found the slashcut to the exhaust to be the most effective. It sure looks like the simplest and most effective to me. It may be enhanced possibly by running two nipples (see honda-tech thread) but I will leave that up to someone else to test as my car is loving life and so am I. Now that i have pcv problem taken care of I am looking forward to finally doing performance mods.
