Page 63 of 80 FirstFirst ... 13 53 59 60 61 62 63 64 65 66 67 73 ... LastLast
Results 2,171 to 2,205 of 2800
Thread: What did you do to your ride today ??
  1. Member MammothsKum3's Avatar
    Oct 27th, 2009
    Salt Lake City, UT
    1994 Daily Project Golf, 1991 Golf
    04-25-2012 09:13 PM #2171
    throttle position sensor, new fan auxiliary relay switch, new thermostat again, coolant flush, new radiator!
    Static = Life
  2. Member 20th#726's Avatar
    Jan 9th, 2007
    Utah
    1968 Type 3 Squareback 1983 Rabbit GTI ABA
    04-25-2012 09:20 PM #2172
    Alright.. more cleaning up little bits. Replaced exhaust manifold gaskets, 6 new studs, and 8 copper crush nuts. No more ticking sound. Found the proper battery hold down instead of a bunjee cord, removed the hot wired manual switch for the radiator fan, and wired it in correctly so it'll turn on and off via temp switch now, pulled the wiring for the fog lights (bumber with fogs will we changed out tomorrow). Already a little less cluttered!
  3. Member David802's Avatar
    Feb 22nd, 2011
    SLuT
    01 Jetta VR6, 71 Type 1.
    04-26-2012 12:53 AM #2173
    Washed it and dreamed of the day I get to put the miros on.
  4. Member 20th#726's Avatar
    Jan 9th, 2007
    Utah
    04-26-2012 11:02 PM #2174
    So I was driving home, pulled in the driveway, heard some noise from under the hood... popped the hood and the water is boiling.. look for culprit.. fan is plugged in.. everything looks good.. oh wait.. no serpentine belt upon further inspection I find that the alternator bracket is not secure.. bolts are missing, broken, incorrect, etc.. got the correct bolts. While I had the water pump out of the way, I cleaned out behind and under the radiator, routed some wires, degreased the front of the block, and cleaned up a couple other small things.. Thanks Jake for the correct water pump bolts!
    All clean!
    Wires neatly ziptied safely out of harms way
    New bolts
    Pump installed, front of block degreased
  5. 04-28-2012 07:28 PM #2175
    As far a Mk1s go, it's a great car. As far as great cars go, it's a Mk1.
  6. Member PoohDizzle's Avatar
    May 28th, 2009
    WYOMING
    One that runs, kinda.
    04-29-2012 12:34 AM #2176
    Continued shaving the bay, down to tucking wires.
    Quote Originally Posted by David802 View Post
    Oh Ic. So the Voilent criminals go to Kansas, the Sex offenders are locked in Wyoming, the drug addicts in Colorado, the crazy's here in Utah and the newbs in the Mk4 forum... Just making sure Ive got my facts straight.
  7. Member PoohDizzle's Avatar
    May 28th, 2009
    WYOMING
    04-29-2012 12:35 AM #2177
    Quote Originally Posted by Fspin720 View Post
    Lovin this.
  8. 04-29-2012 10:15 AM #2178
    New Coil Pack Harness..... Saturday.
  9. Member ((a.v.))mk-1's Avatar
    Dec 9th, 2010
    salt lake city, ut.
    1984 rabbit GTI, 95 jetta, 2011 yaris :)
    04-29-2012 09:10 PM #2179
    Cooked up something simple to wear instead of the rotas... Corrado steeliness
    Before..
    After...
    Only got two done.. But I like where it's going
    aww mah gawdz teh b0rk3n sahspenshun yoo roond et~
  10. Member
    Apr 9th, 2010
    Salt Lake City, UTAH
    06 BMP GTI 6spd
    04-30-2012 12:07 AM #2180
    Installed Rear Hawk HPS pads
  11. Member
    Jul 27th, 2011
    slc ut
    01 2.slow, 03 1.8t, 09 gti(RIP) 2010 GTI, 2011 GTI stage 3+ :D
    04-30-2012 06:20 PM #2181
    Let the lady drive the R for the first time she loved it this could be where she starts letting me do whatever to the car!
  12. Member LOW36's Avatar
    Jan 17th, 2008
    Bagged E36 Beast
    05-01-2012 12:53 AM #2182
    ***Bagged E36 ***
    FACEBOOK
    flickr
  13. Member Provocyclist's Avatar
    Dec 16th, 2004
    Salt Lake City, UT
    1999 Passat 1.8t Wagon, 1996 Jetta 2.0
    05-01-2012 08:15 PM #2183
    Went to the junkyard, got some parts for the Jetta: Tail lights, cabin air filter, headlights, central locking air pump, a door light switch, and an airbag for the leather steering wheel. Plus i ordered all new rear brake stuff, i need to rebuild the rear drums really bad. I also ordered something, but i cant tell y'all yet. Youll see it at slutfest.
  14. Member MK2_GTI's Avatar
    Dec 12th, 2003
    Radiation Valley, UT
    91 16V GTI Monty, 95 VR Jetta
    05-01-2012 10:10 PM #2184
    Quote Originally Posted by jdenney741 View Post
    Well its a cloudy grey in 3 spots where I put it on... Everywhere else it looks like I have clear coat left though, so it's just frustrating.
    Well depending on the color of the vehicle and I assume this is the MK3 your speaking about... VW didnt start using 2 stage paint till 99 There were some colors that were 2 stage.. I believe windsor blue and some of the other MK3 metallic colors were. However T red,black were single stage paint so your grey areas will never be shiny again unless you respray.
  15. Member
    Mar 21st, 2011
    park city ut.
    2008 bmp gti, 2005 touareg ,2002 b6 a4, 2009 pg jetta wolf ,2013 cw gli
    05-02-2012 12:35 AM #2185
    Tonight my rear view mirror fell off from the the windshield i guess the shop did my windshield last fall didnt used a good adhesive stuff. Any suggestion what stuff to use to stick it back from my windshield? mean while i got bored and did this, its nothing new but i think it come out pretty good
  16. Member David802's Avatar
    Feb 22nd, 2011
    SLuT
    05-02-2012 12:55 AM #2186
    Quote Originally Posted by Evil_Panda View Post
    I should have bought this car when it was for sale. Glad to see you kept it.
  17. Member David802's Avatar
    Feb 22nd, 2011
    SLuT
    05-03-2012 01:03 AM #2187
    Installed Koni shocks in the back and picked up window rubber and some wire for the bug. Gonna have to wait another week to get tires.
  18. Member salteatervw's Avatar
    Feb 26th, 2005
    Thuggin' out in Suburbia...
    98 Jetta GT(daily), 77 kz650 Cafe, 80 Rabbit C
    05-03-2012 02:41 AM #2188
    Perused online parts for the MKIII. I really need to upgrade the suspension or at least new parts. Defiantly needs new motor mounts and control arm bushings.
    First I need this damn thing lower to the ground.
    //The Car Doctors//Tire Pros//801-766-4449//
    Front end alignments for VW $40!!!!!
    2158 N Redwood Rd, Saratoga Springs, Utah
    Bought not built, dont wanna get my hands dirty
  19. Member vegaspassat's Avatar
    Jun 5th, 2007
    Las Vegas, NV
    The pink car
    05-03-2012 04:35 AM #2189
    successfully pulled my very first engine.
    Quote, originally posted by Mr. Rabboto »
    You punched a girl and didn't knock her out? Puss.
  20. Member LOW36's Avatar
    Jan 17th, 2008
    Bagged E36 Beast
    05-03-2012 10:01 AM #2190
    Thanks bud.
    ***Bagged E36 ***
    FACEBOOK
    flickr
  21. Member OG16VGLI's Avatar
    Feb 21st, 2010
    SL,UT
    1991 350 SD Mercedes Benz, 2003 Jetta TDi 1987 Mercedes Benz (R.I.P Alice)
    05-03-2012 11:31 AM #2191
    What size are these tires!? Lookin GREAT btw.
    W126 Mercedes 350SD
  22. Member Njegos18t's Avatar
    Jul 31st, 2007
    Compton USA
    04 20V 91 12v
    05-03-2012 07:22 PM #2192
    got my rear happich poputs cleaned and ready for install
    R135
    _226
  23. Member 1.8T16vhead's Avatar
    Aug 2nd, 2006
    west jordan utah
    1984 GTI 16VT ,1996 328i BMW ,92 GLI
    05-03-2012 09:16 PM #2193
    rehabbing this car
    before
    after
    before
    after
    the work is in progress will be done soon to hit RMR this year
    UTAH home of the MK2 VR swaps .... we all can do bolt ons and install a chipped ECU
  24. Member President Lincoln's Avatar
    Jun 27th, 2005
    Kanosh
    83, 85 & 91 Jetta - 87 & 03 GTi - 13 Golf R
    05-03-2012 10:09 PM #2194
    Thats gonn look nice.. what happened to the mk1 ?
    1966 Beetle - 83 Jetta Deluxe - 87 VR GTi - 20th AE GTi - 2012 Tiguan (hers)
  25. Member 20th#726's Avatar
    Jan 9th, 2007
    Utah
    05-03-2012 10:30 PM #2195
    good work tony
  26. Member OG16VGLI's Avatar
    Feb 21st, 2010
    SL,UT
    05-04-2012 12:37 AM #2196
    Cleaned off my skid plate in prep for it being back tomorrow with a fresh clutch!
    W126 Mercedes 350SD
  27. Member BRES's Avatar
    Jul 24th, 2009
    SLC
    mk4 gti
    05-04-2012 06:08 PM #2197
    Bought this today
    Sent from my iPhone 4S.
    my VW supports 2nd Amendment
  28. Member LOW36's Avatar
    Jan 17th, 2008
    Bagged E36 Beast
    05-04-2012 06:20 PM #2198
    Quote Originally Posted by BRES View Post
    Bought this today
    Why? You can get them free.
    ***Bagged E36 ***
    FACEBOOK
    flickr
  29. Member BRES's Avatar
    Jul 24th, 2009
    SLC
    mk4 gti
    05-04-2012 06:26 PM #2199
    Yeah forget that pdf sh1t...
  30. Member RenoJetta's Avatar
    Aug 11th, 2009
    Sparks
    2000 Jetta GL.I
    05-04-2012 07:05 PM #2200
    New tie rod assembly's, new fuel filter, cleaned off the maf and the intake cone, and lastly I had my throttle body realigned sense it was off a few degree's. Tomorrow I will be getting an alignment and a smog.
    Quote Originally Posted by BrewDude View Post
    I suggest you take a dictionary with you for new curse words that you'll have to come up with when you use up the ones you already know.
  31. Member munkster's Avatar
    Jul 27th, 2006
    West Jordan, Utah
    12 VW GLi / 02 1.8t GTI
    05-04-2012 08:38 PM #2201
    Pulled the rials out of storage...
  32. Member 1.8T16vhead's Avatar
    Aug 2nd, 2006
    west jordan utah
    05-05-2012 01:22 AM #2202
    Quote Originally Posted by dOWa242 View Post
    Thanks for the coment
    About the rabbit .mmmmm ? I'm still brainstorming about it
    Part it out ,junk yard or install a engine and sell it
  33. 05-05-2012 09:40 AM #2203
    Time for seat refresh.
    Temp seats installed and Airbag Adapter made.
  34. Member N3M51R's Avatar
    Apr 13th, 2010
    FEMA Region 8
    1987 Golf GT
    05-05-2012 08:05 PM #2204
    We started it for the first time.
    Insert offensive language here.
  35. Member syncrogti's Avatar
    Sep 5th, 2005
    Lehi, UT
    91 Jetta Coupe auto, 90 4dr golf, 89 T3 MS Fox Sedan, 87 two door gti for parts
    05-05-2012 09:35 PM #2205
    Quote Originally Posted by N3M51R View Post
    My old GT is alive! Well done sir!
    -Frank-
    WTB: mk2 recaros, prefer blue
