#2416
Bought these.
//The Car Doctors//Tire Pros//801-766-4449//
//Tires//CNG//Alignments//Diesel//VAG-COM//Exhaust//
2158 N Redwood Rd, Saratoga Springs, Utah
#2417
#2418
#2420
Wiring, re-loomed most of it/ fixed turn signal problems.
aww mah gawdz teh b0rk3n sahspenshun yoo roond et~
#2421
Put in new axles from O'Riley's. Thought I'd give their lifetime warranty a shot, and they're not going in a b5 so I'm sure I wont rattle my teeth off.
The right side is significantly thinner than the old one, which I like because I can go a bit lower but I've heard stories of increased torque steer, we'll see.
#2424
Installed a new pigtail for my A/C, still not kicking on the compressor. More testing.![]()
Front end alignments for VW $40!!!!!
Bought not built, dont wanna get my hands dirty
#2426
autocrats...
#2428
#2429
#2430
The hose from the coolant flange to the heater core split, so I had to replace the hose in the mall parking lot. Couldn't get the clamp off the firewall side, so I cut the hose to half-length, ran 3/4" from the flange to the cut, and then 1/2" line near the full distance inside the 3/4".
Kinda ghetto but it's holding fine.
#2431
Installed a clutched alternator pulley on the truck and it stopped the jumping accessory belt at idle. Also pulled a new fan shroud with the two speed fan relay/sender and associated wiring from the yard for $15. Now I just gotta read up on how to wire it in properly.
Got new rockers from Columbia for the bus.
Will MIG or TIG for $$$,, or trade.
"What good is a beautiful dame with a Rolls-Royce frame and Volkswagen brain?"
#2432
Determined that the coolant temp sensor on the Jetta was bad, and that I need to fix or replace the cluster.![]()
#2433
#2434
What did Davespeed do to your vwI had Dave install h&r super sports due to my laziness .. And it's hot
also test fit some S5 wheels
Stock hoops ...
Thanks for waking up early on a Sunday Dave
autocrats...
#2435
Yeah, I'm guessing its the cluster. A while back I had a thread here about the oil buzzer that would not shut off. Eventually it went EEEEEEEEeeeeeeeeeerrr...dead, and it took the temp gauge with it. The oil pressure is just fine, and all the other gauges work without issue. The harness is fine, tho bridging post 4 to ground should yield ~5v and I'm only seeing 3.8v. Also there should be resistance across posts 2 and 4 on the sensor, and theres not, hence my idea about the sensor being bad... I replaced it when i did the coolant neck, so it may have been faulty all along.
Im not excited about getting a NEW new cluster, im broke as a joke right now, and im guessing ones from the JY are pricey too :/
Sorry for the long long reply!
#2436
Where are you getting a new new one.
All I could ever find was used new to me. And you will be out around $100 for a working one.
There is "a guy" that will rebuild them for ya. Promised to work. For like $85 but shipping back and forth with a car down doesn't seem like fun.
#2438
#2440
#2441
got started with the new panels
#2442
This weekend I Gave the car its first oil change. Also did this to my little brothers scooter.
http://<a href="https://www.youtube....ata_player</a>
Insert offensive language here.
#2443
Driver outer rocker done.
5 more rocker panels to go...
#2444
Lowered it a little bit. Looks lower today after driving it around and it settling. I need new struts and shocks lol
#2445
#2447
Just H&R springs. That was the first pic after install. They should have settled more this morning.![]()
#2448
Finished running the wires and hoses and setting up the trunk. Then I blew the bottom out of one of my rear bags, because I can't read.
Thanks for all the help Jason!
#2449
Today on the Jetta, I wired in a rear domelight, re-ran the oil pressure gauge wire, and tested a set of Volvo horns. Ill probably get the new fabric on the headliner today too.
#2450
Disassembled some MKIII control arms for new hardware; bushings, ball joints.![]()
