VWVortex.com - 95 Jetta, open fuel door?
    Results 1 to 10 of 10
    Thread: 95 Jetta, open fuel door?
    1. 05-14-2009 05:53 PM #1
      I've got this 95 Jetta I've been working on and jesus christ I can't open the fuel door.
      How is it supposed to be done and how can it be done manually?
      search couldn't work for me..
      I've got pending city officials coming to give me a ticket and I can't move it because It is out of gas and I can't fill gas with extra tank because fuel door can't open!
    2. 05-14-2009 05:54 PM #2
      Unlock the WHOLE car..
      lemme elaborate. when you lock the car, a pin pops out and sits in the loop of metal on the fuel door. quite clever. took me 3 months of frustration to finally realize it
      Modified by BlackVr96 at 5:59 PM 5-14-2009
    3. Member super_chief's Avatar
      Aug 15th, 2008
      los angeles
      98 golf
      05-14-2009 05:57 PM #3
      *goes outside to car to check 'locking fuel door' theory*
      awww, it's either not equiped or missing :[
      Modified by super_chief at 2:58 PM 5-14-2009
    4. Member cjslapshot's Avatar
      Dec 22nd, 2005
      Stirling, NJ
      93 Passat VR6
      05-14-2009 05:58 PM #4
      push the side that has the hinge on it.
    5. 05-14-2009 05:58 PM #5
      ALL of your door pins have to be popped (read: unlock the whole car.)
    6. Member autotragik b3attlewagen's Avatar
      Aug 24th, 2003
      Norcross, Ga
      14' Beetle/ 02' Passat Wagon 5-speed! / 85' KLR600 / 99' SV650
      05-14-2009 06:32 PM #6
      or look in the truck and actuate the gas door by hand. There is a emergency release handle.
      I have to laugh when someone calls me an a*****e. I've been called far worse than that.
      - Gordon Ramsay
    7. 05-14-2009 06:33 PM #7
      got it but mine was just 1/2 messed up
    8. 05-14-2009 06:50 PM #8
      95 has a lock for the fuel door? nice to know, learning things everyday. Mine just lift when you push the hinge side of the door but mine is a 97
    9. 05-14-2009 06:51 PM #9
      Quote, originally posted by vwjettavr697 »
      lock it and try again. see what it does
    10. 05-14-2009 06:55 PM #10
      they stopped including the gas door actuators after 1996.
      you can install one in a 97-99 car easily if you want to lock your gas.
