VWVortex.com - Intake air temp sensor
    Results 1 to 10 of 10
    Thread: Intake air temp sensor
    1. Member VW KEVIN G's Avatar
      Oct 26th, 2000
      Willoughby Hills, OH
      1993 Corrado, 2006 2.0t Audi A3, 2008 3.2l Audi TT Roadster
      07-22-2002 09:54 PM #1
      Does anyone know what this sensor does and what would happen if it was "bad". The shop where my car is located said mine was bad although the car seems to be running fine (I think. I haven't drove it yet since they replaced my faulty blue coolant temp sensor). Any symptoms to watch for? How can I confirm that this sensor is bad?
    2. 07-22-2002 09:59 PM #2
      Not to take away from your topic, but has anyone ever thought about extending the temp sensor from the lower bumper (Im assuming its that grey nipple on the passenger side) to the intake tube? I havent done it since it probably only samples the temp like every minute.
      But to your question, I bet if you held a lighter somewhat near the sensor you would be able to check your MFA display to see if the temp changes......
      [Modified by Screamin'Demon, 9:04 PM 7-22-2002]
    3. Member VW KEVIN G's Avatar
      Oct 26th, 2000
      07-23-2002 05:19 PM #3
      We are not talking about the same sensor. The one you are refering to is the ambient air temp sensor. That is the one that displays the outside air temp on the MFA. The one I'm refering to is the one that is screwed into the intake manifold on the driver's side right in front of the distributor.
    4. Member SLC4EVER's Avatar
      Oct 7th, 1999
      San Diego
      '93SLC '94SLC
      07-24-2002 03:01 AM #4
      It's been done...
      Dak
      I drive waaay too fast to worry about my cholesterol.
    5. 07-24-2002 09:50 PM #5
      How well did it work? Am i right?..... it samples the air only every so often?
    6. 07-24-2002 09:55 PM #6
      Done get gone and go get me a hijacked thread over here.
      Got a buzz, forget me
    7. Member VW KEVIN G's Avatar
      Oct 26th, 2000
      07-25-2002 06:02 PM #7
      Someone please save my hijacked thread (HAHA!!) and answer my original questions please.
    8. 07-25-2002 06:21 PM #8
      You would need the electrical specification for the temp sensor...so much resistance and such and such temperature....
    9. 07-25-2002 07:06 PM #9
      the ecu uses the intake temperature sensor to determine when and how much to retard timing to prevent detonation. If your timing was being pulled back unnecesarrily or not pulled back enough then the sensor MAY be the problem.
    10. Banned
      Feb 18th, 2000
      07-25-2002 07:36 PM #10
      look up the stock resistance for the sensor.(the ohm reading).
      test yours.
      it should be in the bently.
