VWVortex.com - AC and Power steering delete ?
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 58
    Thread: AC and Power steering delete ?
    1. Member Busted Fox WaGeN's Avatar
      Jun 25th, 2008
      VA
      Harlequin, 92 Jetta IDI, 91 Jetta coupe, 92 GLI, Kei Truck, 09 Cube, 02 330, 73 Plymouth Duster
      05-16-2009 05:59 PM #1
      can i delete my ac and power steering? just going to be a race car taking off as much as possible
      from looking can i just take them off and get a smaller belt from this pic looks like that possible
    2. 05-16-2009 06:07 PM #2
      yes you can.
    3. Member Busted Fox WaGeN's Avatar
      Jun 25th, 2008
      VA
      05-16-2009 06:10 PM #3
      Quote, originally posted by WeeZFan69 »
      yes you can.
      so i measure the distance around and hit up auozone and im good to go?
    4. 05-16-2009 06:16 PM #4
      yep i got a 43.60" dayco belt from advanced and that fit fine, its part number 5060436
    5. Member Busted Fox WaGeN's Avatar
      Jun 25th, 2008
      VA
      05-16-2009 06:18 PM #5
      your the man!!! thanks so much! on my way to advance
    6. 05-16-2009 07:36 PM #6
      i forgot to mention that i think it has to be 6 rib cause I have never seen a 7 made in that length.
    7. Member Busted Fox WaGeN's Avatar
      Jun 25th, 2008
      VA
      05-17-2009 12:35 AM #7
      gave them part # ordered it will be in monday it was $17.50 ill find out then [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Mar 31st, 2006
      WA
      91 RRC, 97 GTI
      05-17-2009 01:41 PM #8
      the belt has to be a 6 rib. there is a bolt head that sticks out the side of the block that will tear up the inside of a 7 rib belt. you have to align the 6 rib belt with the outer edge of the pullies (away from the block) in order to avoid that. get a 6pk1105 or a 6pk1065 (if you have an under-drive crank pulley)
    9. 05-17-2009 05:20 PM #9
      Quote, originally posted by crazysccrmd »
      Uhm... which bolt head would it hit and why would that not hit when you use a long 7?
    10. Member
      Mar 31st, 2006
      WA
      91 RRC, 97 GTI
      05-17-2009 05:25 PM #10
      i dont remember what bolt it is, but using a 7 rib puts the belt right along it. its there, trust me. look between the crank pulley and alt pulley along where the belt runs and you'll see it
    11. Geriatric Member steveo27's Avatar
      Aug 1st, 2005
      Pittsburgh
      2011 TRD Tacoma. Fake GLI. MK2 Unicorn
      05-31-2009 02:51 PM #11
      so i went to advanced auto and picked up a belt. something tells me its wrong they didnt have the PN listed in this thread, but they cross referenced it and came up with this...
      its a 6 rib. but it only has ribs one one side instead of both like the OEM one
      YOUR STICKER CLUB SUCKS
      Crooked Euros
      - Powered by Pabst and whiskey
      We Do It Big In PA
    12. 05-31-2009 04:09 PM #12
      thats okay youd ont need ribs on both sides.
    13. Geriatric Member steveo27's Avatar
      Aug 1st, 2005
      Pittsburgh
      05-31-2009 05:09 PM #13
      awesome! wasnt postive, im used to building 8Vs
      i got all the AC and PS stuff ripped off, cut down the AC bracket, and mounted the belt up. fits perfect [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Crooked Euros
      We Do It Big In PA
    14. 05-31-2009 07:22 PM #14
      you only need a double sided belt with ac, once thats removed you can use a single sided.
    15. Geriatric Member steveo27's Avatar
      Aug 1st, 2005
      Pittsburgh
      06-01-2009 02:02 AM #15
      awesome
      Crooked Euros
      We Do It Big In PA
    16. Member broke_rado's Avatar
      Nov 5th, 2008
      If it was up your ass you'd know it
      90 Corrado G60
      06-02-2009 10:03 PM #16
      my setup. moved the alternator down to for more intake manifold clearance.
      540whp, 450wtq ALL STOCK VR6 built by ---> dubsquared
    17. Member Busted Fox WaGeN's Avatar
      Jun 25th, 2008
      VA
      06-03-2009 07:44 PM #17
      Quote, originally posted by broke_rado »
      any clearance issue with rad with the alt being there?
    18. Member broke_rado's Avatar
      Nov 5th, 2008
      90 Corrado G60
      06-04-2009 11:20 AM #18
      Nothing is stock so kinda hard to say. I built my own radiator brackets.
    19. Member radojon's Avatar
      Oct 10th, 2007
      north of the turd pipe
      Your stupidity is my job security
      06-04-2009 12:42 PM #19
      with the belt being at a different angle it will come into contact with a bolt that holds the aluminum front main seal cover thats behind the crank pulley
      Quote Originally Posted by VWKW View Post
      Game totally on
      -I have a small penis
    20. Member broke_rado's Avatar
      Nov 5th, 2008
      90 Corrado G60
      06-04-2009 12:45 PM #20
      I used a 5 or 6 rib belt on mine and it hits nothing.
    21. Member mrbeetle's Avatar
      Aug 31st, 2005
      Jofield, IL: Plainfield doesn't want us, Joliet doesn't love us
      14 Passat TDi, 05 Touareg, '92 Golf, '88 Jetta 2 door
      06-04-2009 07:48 PM #21
      broke_rado, any pics of how you modified the bracket? I like how that turned out!
      http://beattheheatinc.org
      Real race cars have three pedals.
    22. 06-04-2009 08:04 PM #22
      did you make the alt bracket or is it a modified vw part
    23. Senior Member Capt.Dreadz's Avatar
      Jun 3rd, 2003
      Long Island, NY
      VRT's & 2.7T's
      06-04-2009 08:53 PM #23
      I'm using a 45" 5 rib belt.
      Everything VR6Turbo & Supercharged The world is ours!!
      Follow us on Instagram @ Everything_VR6turbo_SC
      FaceBook: Carlitus Christensen Sr. - Instagram: @ThatDreadLife - Twitter: @ThatDreadLife
    24. Member broke_rado's Avatar
      Nov 5th, 2008
      90 Corrado G60
      06-04-2009 09:54 PM #24
      Quote, originally posted by najort32 »
      Its the stock Alt/AC bracket. It uses the bottom Alternator holes and the top AC holes. takes some modifications but its pretty straight forward.
      Somewhat better pics. I eventually want to make one where it gets rid of the tensioner and i use the alternator to make tension on the belt.
    25. 06-04-2009 10:41 PM #25
      So, I deleted my a/c cuz it didnt work, now my power steering makes noise when I turn the wheels at a dead stop. I'm thinking of deleting it because it might fail in the future. How hard is it to turn the wheels without PS? & What all has to be deleted; I know the pump, lines, and bottle. What do you do at the Rack or w/e???
