VWVortex.com - DIY: Rear Camber Shims
    Page 1 of 6 12345 ... LastLast
    Results 1 to 25 of 126
    Thread: DIY: Rear Camber Shims
    1. Geriatric Member CapeGLS's Avatar
      Aug 2nd, 2002
      Connecticut
      01 Golf GLS 1.8T, 11 Jetta SE, 11JSW 2.5SE (Wifes)
      05-17-2009 03:01 PM #1
      Disclaimer: I accept no responsibility for your actions while following this DIY.
      Depending on your knowledge/tools you should be able to do this in about an hour and half.
      Step 1: Purchase camber shims from select vendor. *I highly recommend the 16mm offset wrench*
      Step 2: Jack up car and pull off the wheels. Make sure the front wheels are chucked and you put a jackstands under the rear of the car. Release e brake handle.
      Step 3: Remove center cap off of hub, it’s the aluminum cap in the center.
      Step 4: Remove the 8mm bolt holding the ABS sensor to the back of the dustshield DO NOT REMOVE SENSOR AT THIS POINT.
      Step 5: Undo 2 bolts holding the caliper to the carrier, and ziptie caliper out of the way.
      Step 6: Remove the 30mm hub nut in the center of the wheel.
      Step 7: GENTLY remove abs sensor and secure it into a safe location near caliper.
      Step 8: Install gear puller (5mm spread min) onto hub, and use hub stub as the centering location for the bolt. **TO REINSTALL HUB, CENTER AND TIGHTEN THE 30MM NUT)
      Step 9: Remove hub and set aside
      Step 10: Remove the four 16mm bolts holding the hub to the dust shield to the rear beam.
      Step 11: Remove the 2 bolts holding the brake carrier (you will need to shim this so the rotor does “wobble” when it comes around to the caliper.) (THESE BOLTS ARE VERY TIGHT)
      Step 11: Install camber shim and follow steps to put everything back together.
      DO NOT FORGET TO SHIM THE CARRIER (I used 2 washers on the bottom bolt, and 1 on the top bolt on a -1.0 shim)
      Good luck and Enjoy!
      USE THIS DIAGRAM BELOW FOR MORE ASSISTANCE: THIS PHOTO IS BORROWED FROM SOMEONE ELSE (BUT I AM UNSURE WHO I GOT IT FROM)
      Modified by CapeGLS at 8:36 PM 5-17-2009
      ET Feature Car 1/08|Forgeline Wheels|WRDusa.com|
    2. Member justn868's Avatar
      Jan 19th, 2008
      Gainesville, FL
      2002 GTI, 2007 Wolfsburg
      05-17-2009 03:05 PM #2
      great write up!
      Do you happen to have any before/after pics??
    3. Geriatric Member CapeGLS's Avatar
      Aug 2nd, 2002
      Connecticut
      05-17-2009 03:11 PM #3
      No After pictures as the wheels are at Forgeline right now.
    4. Member J.Michael.S's Avatar
      Dec 3rd, 2008
      Cleveland Ohio
      05-17-2009 07:15 PM #4
      Before / After pix would be nice! wondering how much more clearance you get with a -1.0 shim?! That is if you are going for the negative camber look or are you just correcting alignment? I was planning on going -2.0/-3.0 in the rear. Can you reuse the old bearings?!
      Modified by J.Michael.S at 7:17 PM 5-17-2009
    5. Geriatric Member CapeGLS's Avatar
      Aug 2nd, 2002
      Connecticut
      05-17-2009 08:32 PM #5
      I reused the old bearings.
      I chose to add some negative camber to allow more tuckage.
      Before:
      After:
    6. Member shimmy2244's Avatar
      Nov 19th, 2006
      WA
      ///M3
      05-17-2009 08:36 PM #6
      Quote, originally posted by CapeGLS »
      correct me if i'm wrong, but doesn't this have nothing to do with tuckage on our solid rear beam axles? Doesn't it basically just push the lower portion of the hub out, leaving the upper portion in the same position?
      install looks good tho [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      -brandon
    7. Geriatric Member CapeGLS's Avatar
      Aug 2nd, 2002
      Connecticut
      05-17-2009 08:38 PM #7
      It actually kicked it outward about the width of a piece of paper.
      If one added correction for toe then you would be able to get a bit lower.
      I actually purchased the MasonTech great plates, so in combination with those I hope to gain about an 1/8 of an inch clearance.
      Modified by CapeGLS at 8:45 PM 5-17-2009
    8. Member euRo_tuner's Avatar
      Nov 22nd, 2004
      Mill Creek, WA
      RIP 01 golf. RIP s2000. 04 DBP .:R
      05-17-2009 09:18 PM #8
      i need to do this bad..
      my toe is way off.. my rear tires are gettin' eatin. the inside of my tires are scalloping/feathering
    9. Geriatric Member CapeGLS's Avatar
      Aug 2nd, 2002
      Connecticut
      05-18-2009 07:30 AM #9
      Hopefully this DIY helps you out.
    10. Member langgard.net's Avatar
      Jul 14th, 2007
      Norway
      92 Golf GTI , 85 Jetta Coupe 16vt, B5.5 Passat 130PD 1756VK, B6 Passat 140 4motion
      05-18-2009 07:54 AM #10
      what thickness is the washers you used to shim the carrier ?
    11. Member Beersix's Avatar
      Oct 19th, 2007
      12 valves of Fury Since 2003
      05-18-2009 09:28 AM #11
      Why did you remove the hub and bearing?? if you buy the specialty tool, you can remove the whole piece without damaging the bearing.
      BEERSIX
      VRSociety # 105
    12. Geriatric Member CapeGLS's Avatar
      Aug 2nd, 2002
      Connecticut
      05-18-2009 11:02 AM #12
      Quote, originally posted by Beersix »
      I had the specialty tool, but chose to remove the hub because of the fact that using the specialty tool only gives you about a 1/4 of an inch of room to work. Maybe 1/2 inch.
    13. Senior Member Clean PG's Avatar
      May 9th, 2005
      Wisconsin
      Car that looks good from afar.
      05-18-2009 11:07 AM #13
      sweet DIY, something i hope to not have to do tho but im still unsure of how my rears are sitting. waitin to see if i get any nasty looking tire wear.
      || Mk4 Wheel Offset and Stance Picture Index || ClearWaterDubs || ClearWaterDubs@VWVortex ||
      || Please don't PM me with offset questions, post in THIS THREAD instead ||
    14. 05-18-2009 11:18 AM #14
      Tight sick write up... I think I'm gonna stack em' up...
      "I admit that I'm often...vexed by the behavior of my own people..." - Huey Freeman (The Boondocks)
      GTS Performance
    15. Geriatric Member CapeGLS's Avatar
      Aug 2nd, 2002
      Connecticut
      05-19-2009 07:15 AM #15
      I almost went with -1.5 but figured that might be a bit too much.
    16. Member
      Mar 28th, 2009
      land of oz
      03 20th gti, 00 vr gti, 95 vento gls
      05-22-2009 03:41 AM #16
      great write up ive been contemplating doing -3 as ive heard thats about the max you can do
    17. Member dremhmrk2's Avatar
      Sep 19th, 2003
      Fort Lauderdale FL
      2001 Mojave GTI GLX
      05-22-2009 09:54 AM #17
      Ugh, you raped your bearing. When you pull the bearings off the inner race tends to stay on the shaft, and I think from your photos this happened to you. You basically broke the seal on your bearing.
      Also, any time you remove the axle nut it must be replaced with a new one.
      Modified by dremhmrk2 at 9:56 AM 5-22-2009
      "Turning right in fifth gear from the left hand lane into the wrong end of a one-way street while indicating left, if at all."
      All the custom, none of the cool.
      "Trying to be the cool kid is so cool." - MkIV Scene
    18. Geriatric Member CapeGLS's Avatar
      Aug 2nd, 2002
      Connecticut
      05-22-2009 04:54 PM #18
      Drew, from other talks with people you can reuse the bearings if you regrease them. Only time will tell if the bearings are shot. The inner race stayed on the stub.
      Again, you are correct about the nut. Per VW you are only allowed to use most bolts once, I don't feel that I am putting myself in danger with reusing this nut. A bit of tocktite on the threads can add a bit of security.
    19. Member dragon813gt's Avatar
      Feb 18th, 2003
      Ruining VWs one car at a time
      05-22-2009 05:00 PM #19
      should have stacked like 7 of those shims to get some real camber
      L
    20. Geriatric Member CapeGLS's Avatar
      Aug 2nd, 2002
      Connecticut
      05-22-2009 05:01 PM #20
      haha.... -1.0 in the rear and -1.8 up front is enough for me.
    21. 08-06-2009 03:09 PM #21
      OP - when you mention "shimming the carrier with washers - 1 on top, 2 on bottom" you're referring to the caliper carrier? What thickness washers you use? If that's off or not done, pad wear would be on an angle....
      2004 MkIV Jetta GLS 1.8T 5-speed - Eibach ProKit springs & ProDampers - APR Stage 1 93 Tune: 215hp/247lb-ft / 100 Tune: 230hp/262lb-ft
    22. Geriatric Member CapeGLS's Avatar
      Aug 2nd, 2002
      Connecticut
      09-30-2009 04:24 PM #22
    23. Senior Member tchristemac's Avatar
      Feb 4th, 2005
      East Islip, NY
      Tooo Many to list
      09-30-2009 04:53 PM #23
      Dustin, great write... and would anyone doubt this MAN.. I use that LOOSELY.... MUAHAHAHHAHAHAHHAHAHAH....
    24. Member Dat24V's Avatar
      May 2nd, 2006
      Elizabeth, NJ
      (Current)2000 Jeep Cherokee Sport (Sold) 13 Audi Q5 (Sold) 03 VW Jetta Gli 24v
      09-30-2009 05:03 PM #24
      Great DIY.. A+
    25. Member
      May 11th, 2008
      2001 jetta wagon VR 5speed
      11-20-2010 03:27 AM #25
      VRSociety #132
