Page 1 of 2 1 2 LastLast
Results 1 to 35 of 48
Thread: '82 Quantum coupe build up
  1. Member passat_98's Avatar
    Mar 31st, 2007
    Pearland, TX
    '11 Raptor '12 Tiguan
    05-18-2009 10:54 AM #1
    Quote, originally posted by "vwmatt" »
    So yesterday I drove 3.5 hours to pick up my new project, a 1982 VW Quantum Coupe. It runs but needs a tune up and some body work to it back up to par. If anyone has sites where I can get parts please give me the links; I've looked around and haven't much luck :cry:
    Today:
    new air filter
    new plugs
    oil change
    pulled dented fender
    adjusted idle(purrs like a kitten)
    got the sun roof to closed
    Other than that I've been sanding a bit on the car
    and added this for a little fun
    a little rust
    Found a magnet in the car
    oh yeah this baby was on the autobahn in '93
    got the back cleaned up a bit an primed. For some reason I got 2 different colors of primer?
    then it sat for almost 10 months then..........
    getting back on the B2! cleaning out the bay to get ready for some real work
    got the motor out
    bolts were rusted so bad I had to cut it off to get the motor out
    and my little helper
    getting clean little by little
    look at what I found holding my throttle together
  2. 05-18-2009 03:10 PM #2
    wow
    my oil stain is bigger than yours
    the Race Dasher Project is now on Facebook, 180hp and 188tq... while miss-firing BADLY
    the Dasher Owners Group is now on Facebook
  3. Member turbinepowered's Avatar
    Mar 18th, 2007
    Southeastern US of A
    '86 Interceptor 700, '82 Quantum Coupe, '89 Fox Wagon
    05-18-2009 10:01 PM #3
    awesome. Is that the stock 1.7L engine?
    I have an '82 of my own with a swapped in 1.6, contemplating building up a high compression 1.7L for it for some extra fuel economy. Sub-10:1 sucks.
    Buy my Nighthawk?
    There is an area of a normal brain that lets the owner know the object works and needs to be left alone. Not all of us have it. It is like being colorblind.
  4. Member passat_98's Avatar
    Mar 31st, 2007
    Pearland, TX
    05-18-2009 11:28 PM #4
    stock for now it'll stay a 1.7 but when it goes back in I'm ditching the CIS for carbs and putting a little pep in it's step
  5. Member VW Fox's Avatar
    Aug 1st, 2000
    MCMLXXX B1, MCMXCII BX, MCMXCIII B3
    05-19-2009 08:54 AM #5
    Whoa!
    Odd School.
  6. 05-19-2009 11:07 AM #6
    thats very sweet
  7. 05-19-2009 01:52 PM #7
    Quote, originally posted by passat_98 »
    I have a source for custom made copper head gaskets... super thin ones like people buy for motosports use. The one I'm hoping to set up a group buy on will change the 8.3:1 1.7L engine to 8.9:1 (and the 8:1 1.6L engine up to about 8.6:1)
  8. Member turbinepowered's Avatar
    Mar 18th, 2007
    05-19-2009 06:03 PM #8
    I agree with everything you said except associating "pep" and "carbs," but it's your car, not mine. CIS-E turbo all the way for mine.
    How much rust repair did you have to do that next-to-irreplaceable rear end? Found a good source for rubber for the rear windows yet?
    I need to pop all of mine out to do some rust control before it becomes a problem, I'm getting bubbling, but the seals are too dried out to reuse once I'm done.
    [edit I spy with my little eye a shaved battery tray... putting it in the back somewhere, or just building a new tray to replace a rusty old one?
    Modified by turbinepowered at 3:06 PM 5-19-2009
    Buy my Nighthawk?
  9. Member passat_98's Avatar
    Mar 31st, 2007
    Pearland, TX
    05-19-2009 06:16 PM #9
    I've done a turbo build on my B5 so cam and carbs for this one. Just something new for me to learn.
    Rust isn't a problem on this car. I had the one spot on the window and a small one in the passenger floor board.
    No rubber yet, but depending on what glass place you go they have something that will work. I got a good look at the top on my grandpa's Thing top and it's the same style seal and it's an off the shelf job they do. I'm also looking for all the door weatherstripping
    you'll be seeing a lot more to that shave job soon
  10. Member Cubster's Avatar
    Nov 26th, 2002
    Fort Worth, Texas
    05-26-2009 12:02 PM #10
    Where did you find this one? Just curious because I know where a few coupes are and wondering if this is one of them.
  11. Member passat_98's Avatar
    Mar 31st, 2007
    Pearland, TX
    05-27-2009 02:37 PM #11
    off the vortex, but here are these others?
  12. Member Cubster's Avatar
    Nov 26th, 2002
    Fort Worth, Texas
    06-02-2009 03:44 PM #12
    A few near College Station, one near me in Mansfield, and one down near Hunt. Matt is this you with the bagged CC?
  13. Member passat_98's Avatar
    Mar 31st, 2007
    Pearland, TX
    06-03-2009 12:30 PM #13
    Yep. I've seen the few outside of CS but didn't know of any others
  14. Member passat_98's Avatar
    Mar 31st, 2007
    Pearland, TX
    06-09-2009 03:23 PM #14
    So I've just got this thing lying around, it might come in handy later
  15. Member passat_98's Avatar
    Mar 31st, 2007
    Pearland, TX
    06-11-2009 12:02 AM #15
    motor is ready for it's new home
    I'm running out of garage space
  16. Member turbinepowered's Avatar
    Mar 18th, 2007
    06-11-2009 12:39 AM #16
    So, now it's a 20v turbo swap?
    Buy my Nighthawk?
  17. Member passat_98's Avatar
    Mar 31st, 2007
    Pearland, TX
    06-11-2009 09:19 AM #17
    Quote, originally posted by turbinepowered »
    yeah I've spent so much on that motor and selling it with the B5 would be a waste. It's a fully build 2.0 so I can't let that go to waste
  18. Member turbinepowered's Avatar
    Mar 18th, 2007
    06-11-2009 12:50 PM #18
    I like the 20v option a lot better than the cam-n-carbs your initial plan was. But I'm a member of the Anti-Carb Militia. :lol:
    Be a sweet car when it's done. I just ordered some 76.5mm pistons for my own engine build... Not so powerful as yours, no doubt.
    Buy my Nighthawk?
  19. Member passat_98's Avatar
    Mar 31st, 2007
    Pearland, TX
    06-11-2009 02:35 PM #19
    yeah what I needed to spend on a proper tunes was the same as a new carb kits so I figured why not. This motor made 282whp and 298wtq on a bad tune and she'll get a bigger turbo and I'll be trying for 400-500
  20. Member passat_98's Avatar
    Mar 31st, 2007
    Pearland, TX
    06-13-2009 11:11 PM #20
    uh oh
  21. Member MF's Avatar
    Aug 22nd, 2004
    Finland
    06-14-2009 07:16 PM #21
    Intake will be very close to brake master cylinder, but it´ll fit
  22. Member passat_98's Avatar
    Mar 31st, 2007
    Pearland, TX
    06-14-2009 08:15 PM #22
    build thread? or any idea for motor mounts?
  23. Member DubbinChris's Avatar
    Dec 15th, 2005
    Columbus, OH
    85 Ur Quattro, 88 Fox Wagon (sold), 90 Golf, 83 Q Sedan TD, 88 QSW (soon tdi), 85 Q wgn, 03 A4 Avant
    06-14-2009 10:39 PM #23
    Custom mounts?
    Although a Fox...this may help a little...
    http://forums.vwvortex.com/zerothread?id=4267759
  24. Member passat_98's Avatar
    Mar 31st, 2007
    Pearland, TX
    06-14-2009 10:47 PM #24
    you da man thanks
  25. Member MF's Avatar
    Aug 22nd, 2004
    Finland
    06-17-2009 10:47 AM #25
    No build threads for my project. Like in Fox, I made my own mounts, used stock rubber mounts. I cut the front frame rail from body, used Audi A4 front mounting and made it fit to body Got a lot more room for big radiator&intercooler.
    I believe it´s AEB from ~98 Passat? I recommend to use stock Quantum oil pan. The Passat pan will fit, but needs a lot grinding for K-member clearance.
    My build shortly:
    1986 Audi 80q
    AEB from 1998 Audi A4
    Custom header with Switcher S2BG
    3" exhaust
    630cc@3bar injectors
    Megasquirt
    Later 1,8T COP´s
    Stock tranny and rear diff with 4,55:1 ratio
    No changes to body, stock sleeper looks (exept those 16" black steelies for summer)
    Pics are here
    Modified by MF at 5:48 PM 6-17-2009
  26. Member DubbinChris's Avatar
    Dec 15th, 2005
    Columbus, OH
    06-26-2009 10:01 AM #26
    you da man thanks
    No problem...
  27. Member
    Aug 29th, 2007
    East Falmouth, MA
    82 Quantum Coupe, 86 Quantum Syncro Wagon, 87 Scirocco 16V
    07-05-2009 01:43 PM #27
    You beat me to it. If I had a garage, I'd have had my 1.8T conversion done by now...Gotta get the garage first, then the build can continue. I almost bought that Coupe too...just too far away at the time. When I get my build done, we'll have to meet up at one of the shows. That would absolutely blow some minds. It'll be next year before I get working on my build again as shoulder surgery is in less than 2 weeks...
    Good luck on the build!
    grimwater
    Very small rocks!
  28. Member 8V Fury's Avatar
    Jul 26th, 2003
    roseville, california
    2004 vw jetta wagon, 1990 vw jetta coupe
    07-08-2009 02:47 AM #28
    Another cool thread to watch.
    Quote Originally Posted by Ron@RMAMotorsport View Post
    real deal<p>After spending two months in the mk3 forum it drove into the woods and set fire to itself.
  29. Member passat_98's Avatar
    Mar 31st, 2007
    Pearland, TX
    07-09-2009 04:03 PM #29
    it'll be winter before I get started again 100+ degrees daily doesn't agree with me
  30. Member passat_98's Avatar
    Mar 31st, 2007
    Pearland, TX
    09-17-2009 10:31 PM #30
    from this
    to this
  31. Member turbinepowered's Avatar
    Mar 18th, 2007
    09-17-2009 11:07 PM #31
    Whose sleeves, springs and perch is that?
    Buy my Nighthawk?
  32. Member passat_98's Avatar
    Mar 31st, 2007
    Pearland, TX
    09-17-2009 11:39 PM #32
    it's a ground control kit from a mkII. It's not perfect but it's a start. I still need to do the other side I'll do a little write up for it this weekend
  33. Member turbinepowered's Avatar
    Mar 18th, 2007
    09-17-2009 11:49 PM #33
    Cool deal, look forward to reading it. What struts are you running with that?
    Buy my Nighthawk?
  34. Member passat_98's Avatar
    Mar 31st, 2007
    Pearland, TX
    09-18-2009 01:00 AM #34
    bilsteins. they are shortened so ultimately there will be some modifying to the housing itself to make it work. right now it moves up and down
  35. Member passat_98's Avatar
    Mar 31st, 2007
    Pearland, TX
    09-19-2009 12:21 AM #35
    not bad for a first mock up. housing still needs to be cut down and with a shorter insert I'll get the stance I want. This is at it's lowest
