VWVortex.com - Direct injection causes intake valve buildup?
    The Car Lounge
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 47
    Thread: Direct injection causes intake valve buildup?
    1. Member greatfox's Avatar
      Mar 5th, 2005
      SoCal
      '00 Boxster Wannabe
      05-19-2009 03:25 PM #1
      It seems as though more and more cases are popping up where direct injected engines are experiencing miss-fires, rough running, and reduced power output due to extreme levels of carbon buildup on the intake valves. Audi's 4.2 FSI V8 and 5.2 FSI V10, VW's 2.0T, and Porsche's 4.8 DFI V8 are known victims so far...
      Presumably, this is because normal port-injected engines have the added benefit of washing away any deposits that may form with the fuel spray. Unfortunately direct injected engines have no way of clearing off deposits and thus need to go in periodically to have the valves cleaned.
      Is this a design flaw with direct injection or is there a solution on the horizon? Has anyone had first-hand experience with this phenomenon?
      Links for reference:
      Audi RS4:
      http://forums.audiworld.com/sh...build
      Porsche Cayenne Turbo:
      http://www.planetporsche.net/c....html
      Modified by greatfox at 12:26 PM 5-19-2009
      Quote Originally Posted by iamnotemo View Post
      ...I am jealous of your shift knob. That is a shape I love.
      Quote Originally Posted by elementpb View Post
      your mom sounds like my kind of lady. is she single and/or discrete?
    2. Moderator Mike0105's Avatar
      Dec 31st, 1999
      Belle Mead, NJ
      LR4
      05-19-2009 03:27 PM #2
      At every oil change I have Terry Dyson do an oil analysis on my car since the direct injected motors seem to destroy most oils pretty quickly. He just warned me about this as well so once I get the analysis I just sent him back we'll chat and see what his thoughts are what we can do to prevent it.
      Mike
    3. Member chucchinchilla's Avatar
      Dec 25th, 2004
      Dallas, TX
      2016 A6, 2014 X3, 1963 356
      05-19-2009 03:30 PM #3
      So the 2.0T can lose...
      Quote Originally Posted by jamie@vwvortex View Post
      This forum is more and more of an embarrassment every day...
    4. Geriatric Member ByronLLN's Avatar
      Jul 29th, 2004
      Cleveland, OH
      '16 FiST, '90 Miata
      05-19-2009 03:32 PM #4
      Seafoam that bitch.
    5. 05-19-2009 03:34 PM #5
      our solution to this comes back to good ol' seafoam. Inject into the intake and voila. I've heard 2 or 3 treatments should completely clear the valves off.
    6. Member greatfox's Avatar
      Mar 5th, 2005
      SoCal
      '00 Boxster Wannabe
      05-19-2009 03:35 PM #6
      Quote, originally posted by PassSedanGLX »
      Seafoam that bitch.
      Would you really want all that crap entering your engine and potentially clogging your catalytic converter? I'd have a hard time using seafoam on a 2008 RS4 with less than 6k miles on the clock
      Modified by greatfox at 12:37 PM 5-19-2009
    7. Member eweu's Avatar
      Jul 22nd, 2001
      Silicon Valley, CA
      e-Golf, Touareg TDI, TT VR6, F250
      05-19-2009 03:37 PM #7
      Volkswagen has a patent that discusses this buildup problem as an inherent flaw with direct injected engines. The patent claims several solutions to the problem, but it isn't evident to me that they have actually implemented any of these solutions on the current FSI engines.
      The patent is worth a read.
    8. 05-19-2009 03:41 PM #8
      is this a VW group only prob or all DI'S (GM, Ford etc) in general?
    9. Banned SVTDanny's Avatar
      Aug 7th, 2005
      Winchester, VA
      05-19-2009 03:43 PM #9
      Quote, originally posted by AS50 »
      Should be all, they all work the same way. Fuel gets injected in the cylinder instead of in the runner.
      Seafoam or a catch can on all cars would be the easiest way to prevent this.
    10. Member Tucci's Avatar
      Feb 2nd, 2005
      Oakwood GA
      TDI Golf
      05-19-2009 03:43 PM #10
      My 06 GTI had this problem on a much higher scale. I brought it in for constant miss codes. They had to scrape the carbon build up off the ports and clean the valves. Almost 1/4 in thick, it looked like an old TDI head and the car only had 40k on it.
    11. Member greatfox's Avatar
      Mar 5th, 2005
      SoCal
      '00 Boxster Wannabe
      05-19-2009 03:44 PM #11
      Quote, originally posted by eweu »
      Interesting. Thanks for posting that link. It seems that by simply coating the intake valves with a Vanadium catalyst, the deposits can oxidize more readily and buildup may be reduced/eliminated. I wonder when they will realize that this is a serious problem and incorporate this coating in the next iteration of their 2.0 TSI engine.
    12. Banned iPinch's Avatar
      Oct 24th, 2008
      Chesapeake, VA
      askavwsalesguy.com
      05-19-2009 03:49 PM #12
      I put 60K miles on my 2.0T and didnt have an issue of this nature
    13. Member
      Mar 24th, 2007
      05-19-2009 03:50 PM #13
      Looks like nothing a good ol' "Italian tune up" couldn't fix.
      In fact revving the snot out of the motor regularly could actually help things.
    14. Member Slickvic's Avatar
      Apr 24th, 2006
      WI
      2010 Mustang GT, 2005 Legacy GT, 2012 Honda Accord
      05-19-2009 03:53 PM #14
      Quote, originally posted by greatfox »
      Word in the 2.0 FSI forum is that the root cause is from the PCV valve sucking oil into the engine and collecting on hot intake valves. A PCV valve is supposed to just collect crankcase fumes but in the case of the FSI engines they suck in a bit of oil as well.
      That other non-douche Mustang owner.
    15. Member WhiteG60's Avatar
      Aug 19th, 2001
      Gilbertsville, PA
      1980 VW Scirocco, 2004 Audi A6 S-Line 2.7T
      05-19-2009 03:57 PM #15
      Quote, originally posted by Slickvic »
      This has been happening for years on VW's, especially the 1.8T. The PCV would vent into the intake tract and get burned, but in the process would coat everything in oil. i can imagine if there isn't enough cooling on the back of the intake valve that the fuel provides, it would simply burn and leave the build up there. Maybe its time to rethink plumbing the PCV into the exhaust manifold and letting it be burned there? If theres no oil on the intake side of the motor, then there can't be any build up.
    16. Member
      Mar 20th, 2002
      Oh-I-O
      13 GTI Driver's Edition, 12 Subaru LadyWagon, 87 Saab 900T
      05-19-2009 04:00 PM #16
      I had a lot of misfires on my Jetta NevarLose Edition, but have never had it in my Audi NevarLose Edition. I've been running synthetic from day one in this car, though.
      "If I have any beliefs about immortality, it is that certain dogs I have known will go to heaven, and very,very few people." -- James Thurber
    17. Member the flying grape!'s Avatar
      Dec 4th, 1999
      12 S4, 02 VW 337, 93 F-150
      05-19-2009 04:00 PM #17
      Uhh, crankcase fumes have a quite a bit of oil in them anyway. It doesn't matter if actual liquid gets sucked into the intake, the fumes are going to coat the valves without liquid.
      Fondest Regards,
      Me
    18. 05-19-2009 04:09 PM #18
      Quote, originally posted by chucchinchilla »
      As younger brothers always do.
    19. 05-19-2009 04:09 PM #19
      Quote, originally posted by Dextrobrick »
      In fact revving the snot out of the motor regularly will always help things.
    20. Member
      Mar 20th, 2001
      2007 Porsche Cayman 5MT; 2009 VW Passat Highline Wagon 6MT; 2017 VW Golf R 6MT Tech Pack
      05-19-2009 04:15 PM #20
      Hmmm, no driveability, fuel economy, or power issues with my car. I also stick to the 16,000 km oil change interval recommended in the manual. The only thing I have noticed on my car is soot on the exhaust tips, and this seems to be common to all DI engines.
      Quote Originally Posted by 20aeman View Post
      No, the real enthusiast vehicle would be the RX8. It combines V12 Lamborghini gas mileage with Hyundai Genesis 4cyl. performance.
    21. Member kptaylor's Avatar
      Apr 7th, 2001
      PHX, AZ
      '12 Miata, '11 Routan, '04 Triumph Sprint ST, E36 & E39
      05-19-2009 04:18 PM #21
      The BMW DI motors are experiencing this, too.
    22. Member mraguilar's Avatar
      Sep 27th, 2004
      01 Neon (sold), 07 Caliber MTX, 07 Quest S
      05-19-2009 04:22 PM #22
      I was expecting this
      when saw the thread title
    23. Member greatfox's Avatar
      Mar 5th, 2005
      SoCal
      '00 Boxster Wannabe
      05-19-2009 05:53 PM #23
      It sounds like the OP on the audi forum link I posted drives his car hard, so I'm not sure that is the solution
      Quote, originally posted by Audi World Post »
      ...I posted a couple of months ago about recurring misfires on a 2008 RS4. Only 9500 kms on it after 1 year of ownership. Not a daily driver and certainly not babied when i get it out on the highway....
      here is an article confirming that it is a problem with DI engines in general an not just a VAG problem:
      http://blogs.edmunds.com/green...60233
    24. Member Bull0080's Avatar
      Mar 12th, 2005
      MN & Tahoe
      B7 A4, 82 MB 300D
      05-19-2009 06:00 PM #24
      Use TOP TIER Detergent Gasoline every few tanks. At least that is what my Audi dealer told me, he actually said i would rather see you using a LESS octane top Tier fuel than a higher non Top Tier octane. They even game me a flyer explaining why and what stations pump Top Tier fuel
    25. Member Sump's Avatar
      Jul 14th, 2006
      Chicagoland, IL
      99 M3, 17 GTI, 17 Golf Alltrack
      05-19-2009 06:01 PM #25
      I always make sure if I am doing a full heat cycle to do a good ol eyethai tune up and at 36k the car is running better than it did at 10k.
