VWVortex.com - How to remove carpet
    Results 1 to 4 of 4
    Thread: How to remove carpet
    1. Member mrmylanman's Avatar
      Mar 19th, 2009
      Apopka, FL
      2010 VW Jetta 2.0T 6MT
      05-27-2009 09:54 PM #1
      Hey all,
      I recently got my car back from the shop, there was a nasty leak in the passenger footwell area. The problem was evidently there since before I owned it (about a couple months) and it just now started raining so I just noticed it, however I guess there was a mold problem that developed.
      I found out from Volkswagen that the carpet is $1600 alone, so that route is out of the question (I can't afford it) and my insurance company will not cover it (the deductible is $1000 anyway).
      So I was wondering about trying to kill the mold and fix it up that way. I was able to remove some mold that developed on the mat so I might be able to do it.
      I was wondering if anyone has experience pulling the carpet up out of these cars. I imagine that it's just the metal tabs that hold the interior trim down there in place but I don't want to start rippin stuff up without knowing.
      Thanks much
      Mylan
      2010 VW Jetta Wolfsburg Edition, 6MT
      Jan 28th, 2002
      SoCal
      05-28-2009 03:23 PM #2
      I'm not sure how it comes up, but I can tell you it's not that simple. There's a thick padding under the carpet and they're glued together. I don't know what holds the padding down, but it wasn't obvious. I had to get under the carpet to run wires for my amps and it was a major pain.
      Good luck.
      Sometimes a majority only means that all the fools are on the same side.
    3. Member mrmylanman's Avatar
      Mar 19th, 2009
      Apopka, FL
      05-28-2009 05:44 PM #3
      Ugh that sucks. But I'd rather not spend $2000 if I can avoid it. I shouldn't have to get THAT much up, it was only that 1/4 of the car that got water in it, and I only need it up enough to get some **** to kill mold in there. Thanks for the heads up. I may end up getting the repair manual anyway hopefully it mentions how to get the carpet up.
    4. Member gilotin661's Avatar
      Aug 26th, 2005
      Bergen County
      oil burning 06 passat FSI
      05-28-2009 05:46 PM #4
      its really all labor when it comes down. all day labor
      updating....
