Page 4 of 15 FirstFirst 1 2 3 4 5 6 7 8 14 ... LastLast
Results 106 to 140 of 507
Thread: Project Blacker II BEV 16V Turbo
  1. Member duke_seb's Avatar
    Jul 29th, 2003
    Halifax, Canada
    98 VW Golf (AEG) RIP, 04 VW Golf 16VT (In Progress)
    11-15-2009 09:07 PM #106
    hey rey or shifty
    if this the tensioner that i need?
    is there a special way to put this on the head or anything? I have never had to deal with a dampener before does the head have a hole it it to accomodate it
    http://www.germanautoparts.com...26/11
    :bow Old Vortex
    Really Volvo? A failure of system that is supposed to save the inattentive would have been noticed by a real inattentive driver?
    Really?
  2. Member Shifty's Avatar
    Mar 25th, 2004
    Oklahoma City Metro
    '01 Jetta 16v(!), '09 CC VR6, 1998 Suburban Command Center, '01 Triumph TT Warbird
    11-15-2009 09:45 PM #107
    No you'll need the 16v one. Like this:
    http://www.worldimpex.com/part....html
    PM replied BTW!
  3. Member elRey's Avatar
    May 15th, 2001
    16vt 2.0L MK4 Jetta Wagon | B6 A4 Avant
    11-15-2009 10:12 PM #108
    I didn't consider the 1.8T hydraulic tensioner because I didn't have one on hand like I did for the 8v and 16v and because of the price.
    BUT looking at some pictures online, It 'may' be possible to use it. You won't know unless you try it.
    Modified by elRey at 10:17 PM 11-15-2009
  4. Member duke_seb's Avatar
    Jul 29th, 2003
    Halifax, Canada
    11-15-2009 10:15 PM #109
    didnt you suggest to me somewhere that i can use it?
    i guess ill have to pick the stuff up tomorrow and check to see if it will work
    :bow Old Vortex
    Really?
  5. Member duke_seb's Avatar
    Jul 29th, 2003
    Halifax, Canada
    11-15-2009 10:27 PM #110
    from what i can tell looking in the bentley i think it may just work... I took a look at one of the tensioners yesterday and it does stick out a good half inch further then the 16V one which if about what i noticed when i tried putting spacers behind the 16V tensioner to line it up
    the only thing i dont know for sure right now is if the 2L block has the 1.8T lower dampener hole i assume it would considering they are the same block just bored out
    from looking at my pictures i do have the upper hole so let us pray... ill let everyone know tomorrow..... the price for the dampener and tensioner arent that bad i priced them out at about 100 bucks for them both, certainly cheaper then making a custom spacer that might not work right
    :bow Old Vortex
    Really?
  6. 11-16-2009 04:26 PM #111
    hi, found this thread and wondered what output you where expecting to get with this combination,
    did a 16v digi2 conversion in july 2008 as phase1 progressing hopefully to a 16v eaton at some time, considering a turbo, had thoughts about using 1.8T ecu and wiring as a possibility then forgot about the thought then remembered about it when i found your build,
    what ecu and wiring would you be using and do you think this is a possibility with the mk2 fuse box
  7. Member duke_seb's Avatar
    Jul 29th, 2003
    Halifax, Canada
    11-17-2009 07:10 PM #112
    Ok so i got some big work done today..... some rreally important work actually....
    I finally sorted out my issue with using plugs and wires and instead am using coil packs now.....
    I had to do some major trimming to get the coils to get all the way down but they are snug in there... I think ill look for an oring or something to try and seal the holes a little more but they are in there good
    here are the stages of the trim
    1. You have to use and exacto knife and shave all rubber off the coil all the way up to the top indent (comes off easy)
    2. You get a hack saw and you cut the plastic that is underneath until you get to the metal and then you pull that off (wasnt that hard)
    Next thing i got was my oil return line back.... strictly hydraulics in dartmouth made it up for me i would highly recommend then they have done a few lines for me im getting them to make up all my braided stuff
    Also got my TB mounted (ignore the hoses I just threw them on there so i didnt loose them
    I think im going to look at attaching the CPS from a 1.8T right onto the cam gear if possible...... then block off the dizzy side..... I have to get access to a 1.8T head with some parts on it and i might be able to..... I dont know yet
    ill keep you all posted
    :bow Old Vortex
    Really?
  8. Member duke_seb's Avatar
    Jul 29th, 2003
    Halifax, Canada
    11-17-2009 07:16 PM #113
    Quote, originally posted by 6a2.0digi2 »
    Im hoping for around 300HP 280-300TQ ish
    as for your question I would go standalone if i were you...... if i had to do over again my whole build I think i woud have done a 20V head so i could use the 2L block and all 1.8T stuff.... for you to use the 1.8T harness youll have a lot of extra things that you wont need the 1.8T ECU is going to go crazy and i doubt youd be able to use the MKII fuse box....
    if you want more power out of your car eithr do standalone or find yourself a complete 1.8T and do a swap
    :bow Old Vortex
    Really?
  9. Member Shifty's Avatar
    Mar 25th, 2004
    Oklahoma City Metro
    11-17-2009 08:14 PM #114
    Looking good bro, nice progress!!!
  10. 11-18-2009 06:26 PM #115
    1.8t conversions out the question, and so is standalone
    the reason your thread stood out to me was the title mkiv 16vt, i fully expected to read that you where using standalone bt then i read that you where using( 1.8T (late model) ECU 1.8T (Late model) Wiring Harness) this is the bit that got really interested as all other threads on 16vt are either standalone or digi1
    digi1 wld be easy change ecu and wiring and all assosiated intake plumbing
    the idea of using an easily remappable 20vt ecu and wiring is so appeling tht i think thts why i had the thought so many month ago, i admit that i know shi* about 20vt's apart from tht they have 20valves and the 180bhp versions have trouble keepin up with the 6a 2liter port&polished gti cam'd 16v
    anyway obviously theres more to your swap than swappin over a dizzy trigger wheel, what sensors does the ecu read from other than the lamda, map and tb sensors
    does your block alread have a crank trigger (id have to get one if you do)does 20vt use cam position sensor etc
    clocks and immobilisers no probs, can get it deleted when its remapped
    cheers
  11. Member duke_seb's Avatar
    Jul 29th, 2003
    Halifax, Canada
    11-18-2009 06:31 PM #116
    think of it this way this is what i remembered through the whole build
    both the 1.8T and the 2L blocks are the same just bored different...... so if I replaced everything with 1.8T parts I can trick the ECU into thinking the car is a 1.8T
    thats why im dealing coil packs and the 1.8T ECU and the complete 1.8T wiring....
    im still looking for a better mount for the CPS...... I want to use the whole sensor somehow soon as i get to see the whole assembly I man finda way to mount it on the cam sprocket then everything will run the same way and all the plugs will fit and hopefully it will run like a champ
    :bow Old Vortex
    Really?
  12. Member elRey's Avatar
    May 15th, 2001
    11-19-2009 11:29 AM #117
    How did the 1.8T hydraulic tensioner work out?
  13. Member duke_seb's Avatar
    Jul 29th, 2003
    Halifax, Canada
    11-19-2009 12:22 PM #118
    Not sure yet..... I haven't got my hands on one yet ..... But believe me I'll post if I do I'm also considering getting a tensioners spacer made up for the 16v tensioners.... Something that would cup the back so it can't shift like it might on washers
    my concern right now is the CPS i'm getting a whole 1.8t assembly this weekend aswell I'm going to see if there is any way at all to fabricate comthibg else who know
    :bow Old Vortex
    Really?
  14. Member duke_seb's Avatar
    Jul 29th, 2003
    Halifax, Canada
    11-20-2009 05:44 PM #119
    Got some work done today.... started by pulling the 2L harness out of the car.... actually easier then i thought but I still a paint to get under the cowl...... can someone tell me if there is an easy way to get the thing off I stuck my arms underneath it and pulled the connectors out... would have been a lot better if i could have found a way to get it off
    Next step was to put the 1.8T wiring harness onto the motor.... I thought for a while the easiest thing to do would be put it in the car first but after some of the stupid things i ran into im definitely glad i did the harness in the motor first
    Everything worked out good I had to lengthen the line for the AIT sensor..... I also had to swap connectors for the connector on the oil filter flange see the difference......
    for those that dont know how to swap the connectors between the harnesses is a matter of looking inside the connector and pulling out the purple piece of plastic then just yank out the wire from the back......
    I got everything all plugged in but im not sure what some of the connectors are for.... im sure they are things not on my 2L ..... im hoping the elrey might be able to help me out with these
    Im assuming the connector in the middle is for the CPS sensor but the one on the left and the one above the CPS... im not sure what they are
    and on this side the connector that is dangling on the left
    I also mounted my manual boost controller
    I came across a 1.8T coil pack the other day now i realise y you cant use the 1.8T packs with this set up as they are too short
    :bow Old Vortex
    Really?
  15. Member duke_seb's Avatar
    Jul 29th, 2003
    Halifax, Canada
    11-20-2009 06:53 PM #120
    The red circles are the ones i need to know for sure
    :bow Old Vortex
    Really?
  16. Member elRey's Avatar
    May 15th, 2001
    11-20-2009 10:36 PM #121
    Quote, originally posted by duke_seb »
    top middle = knock sensor 1
    lower left = throttle body
    lower right = CPS
    if you're talking about the one on the far left near your broken oil dipstick funnel, I can't tell where it's coming from. Maybe SAI kombi valve solenoid (N112). The ones in the lower center of the pic:
    Gray = Crank Position Sensor
    lower middle = DV N249
    lower right = oil pressure
    I thought we had a conversation about which COPs are usable?
    http://forums.vwvortex.com/zerothread?id=2368051
    Modified by elRey at 10:50 PM 11-20-2009
  17. Member elRey's Avatar
    May 15th, 2001
    11-20-2009 10:40 PM #122
    from left to right:
    TB
    CPS
    knock 1
    RPM/crank position
    oil pressure
    knock 2
    VSS
    and one you missed right above VVT: ECT
    Is this harness from an automatic? I don't see a reverse light connector.
    nevermind, it won't have the VSS is it was an auto harness.
    edit
    Modified by elRey at 10:51 PM 11-20-2009
  18. Member duke_seb's Avatar
    Jul 29th, 2003
    Halifax, Canada
    11-20-2009 10:42 PM #123
    Quote, originally posted by elRey »
    I believe we did and you suggested 2.5L MKV ones.....
    with the trimming they fit perfect
    am i missing something?
    :bow Old Vortex
    Really?
  19. Member duke_seb's Avatar
    Jul 29th, 2003
    Halifax, Canada
    11-20-2009 10:45 PM #124
    i dont know i was sure it was from a stick... I could be wrong though
    :bow Old Vortex
    Really?
  20. Member elRey's Avatar
    May 15th, 2001
    11-20-2009 10:52 PM #125
    Nah, I thought I mentioned 1.8T COPs were too short.
    I edited my above posts with more concise info.
  21. Member duke_seb's Avatar
    Jul 29th, 2003
    Halifax, Canada
    11-20-2009 10:58 PM #126
    I was wondering about the reverse indicator too....... I actually had the the knock sensor plug plugged into that for a little bit cuz it fit the same....... from what i can tell i dont have any more plugs for the reverse
    :bow Old Vortex
    Really?
  22. Member duke_seb's Avatar
    Jul 29th, 2003
    Halifax, Canada
    11-20-2009 10:59 PM #127
    the ones above the VVT i plugged into the collant temp sensor
    :bow Old Vortex
    Really?
  23. Member elRey's Avatar
    May 15th, 2001
    11-20-2009 11:02 PM #128
    ECT = Engine Coolant Temp
  24. Member elRey's Avatar
    May 15th, 2001
    11-20-2009 11:03 PM #129
    Do you have a multimeter?
  25. Member duke_seb's Avatar
    Jul 29th, 2003
    Halifax, Canada
    11-20-2009 11:04 PM #130
    i hve access to one.... dont know how to use it though
    :bow Old Vortex
    Really?
  26. Member duke_seb's Avatar
    Jul 29th, 2003
    Halifax, Canada
    11-20-2009 11:06 PM #131
    could the one right under the number N249 be the reverse?
    im wondering if its part of the harness still left in the car....
    :bow Old Vortex
    Really?
  27. Member elRey's Avatar
    May 15th, 2001
    11-20-2009 11:08 PM #132
    I believe it is on the other harness. So, you're good.
  28. Member duke_seb's Avatar
    Jul 29th, 2003
    Halifax, Canada
    11-20-2009 11:15 PM #133
    geez rey dont freak me out like that....lol
    ok this is good .... so i have to lengthen the TB line and maybe the line for the MAP sensor....
    then i get to move on to coolant lines...... I really should have labelled these cuz i dont remember for the life of me where they all came from.... same as the vacuum lines
    got my ECU and cam gear and tensioner and damper coming sunday so i can get the timing going
    hey rey do i need the N75 while running external or the N249 which i dont even know what if does? ... and N206 is the SAI right?
    :bow Old Vortex
    Really?
  29. Member elRey's Avatar
    May 15th, 2001
    11-20-2009 11:26 PM #134
    No, you do not need the N75 or N249 (DV). You can run a mbc instead of the n75 and just run the DV straight to a vacuum line from intake mani.
    N206 = VVT Variable Valve Timing which you do not have.
    Now, you will need to put resistors in place of those solenoids for you ECU to adjust/save fuel trims.
    What's software are you running?
  30. Member duke_seb's Avatar
    Jul 29th, 2003
    Halifax, Canada
    11-20-2009 11:28 PM #135
    ill be running unitronic 630cc file
    im going to get the SAI deleted
    what is this MBC?
    :bow Old Vortex
    Really?
  31. Member duke_seb's Avatar
    Jul 29th, 2003
    Halifax, Canada
    11-20-2009 11:36 PM #136
    ah little google figured it out.... Manual boost controller...... go figure i got one..... mounted the side of the head
    :bow Old Vortex
    Really?
  32. Member duke_seb's Avatar
    Jul 29th, 2003
    Halifax, Canada
    11-20-2009 11:47 PM #137
    So i need to Run resistors in the following connectors
    N75
    N249
    N206
    SAI
    does 1W 330ohm sound good to you?
    :bow Old Vortex
    Really?
  33. Banned ihavenoideax2's Avatar
    Apr 12th, 2008
    Holbrook, LINY
    2001 Jetta 1.8T AutoTragic
    11-21-2009 12:03 AM #138
    That is usually what is run in them. I don't know if it is completely overkill to use them since they are huge but they still should work. If your getting the SAI deleted, you shouldn't need them for the N249 and the N112 valve. See if before you get it in the car, if uni will just delete all of it since you wont need the resisters in it.
    Does that make any sense since I am half asleep.
  34. Member duke_seb's Avatar
    Jul 29th, 2003
    Halifax, Canada
    11-21-2009 12:05 AM #139
    which is N112... SAI?
    :bow Old Vortex
    Really?
  35. Banned ihavenoideax2's Avatar
    Apr 12th, 2008
    Holbrook, LINY
    11-21-2009 12:07 AM #140
    Yea, its the solenoid right next to the N249 valve. Its the combovalve controller for the SAI system.
