Page 1 of 3 1 2 3 LastLast
Results 1 to 35 of 72
Thread: Brand New 02A and 02J Transmissions Available from AP Tuning
  1. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    30 S 5th Ave, Lebanon PA 17042
    MK6 GTI S3+, MK6 Golf R, MK4 R18, Q5 3.0T
    06-05-2009 02:43 PM #1
    AP Tuning has the following brand new transmissions available. Quantities are limited.
    02A Transmissions
    VR6 (MK3) Compatible Code(s): CCM
    Ring & Pinion: 3.38
    Gear Ratios: 1 = 3.30; 2 = 2.12; 3 = 1.31; 4 = 1.03; 5 = 0.84
    Price: $1655.00
    02J Transmissions
    2.0L Compatible Code(s): DZQ, EMS, EKG, EKH, EBP, FBV, EGT, EZK
    Ring & Pinion: 4.24
    Gear Ratios: 1 = 3.30; 2 = 1.94; 3 = 1.31; 4 = 1.03; 5 = 0.84
    Price: $1275.00
    1.8T Compatible Code(s): EGX, EGC, EGD, ELG, EBQ, FBW, EMT, EMR
    Ring & Pinion: 3.94
    Price: $1295.00
    1.8T Compatible Code(s): EHA, EXE
    Ring & Pinion: 3.65
    Gear Ratios: 1 = 3.30; 2 = 1.94; 3 = 1.35; 4 = 1.03; 5 = 0.84
    Price: $1395.00
    TDI Compatible Code(s): DQY, EBJ, EGR, EGS, EUH
    Ring & Pinion: 3.38
    Gear Ratios: 1 = 3.78; 2 = 2.06; 3 = 1.31; 4 = 0.97; 5 = 0.74
    Price: $1425.00
    VR6 (MK4) Compatible Code(s): DZC, EHC, EWW
    Ring & Pinion: 3.38
    Price: $1895.00
    Prices do not include shipping. Please call if you have any questions or would like to order: 717.272.0916
    Modified by APTuning at 3:02 PM 12-2-2009
    APTuning LLC, 30 s 5th Ave, Lebanon PA 17042, (717)272-0916
    aptuning.com - tom@aptuning.com - Facebook - Twitter
    APR Stocking Master Distributor - United Motorsport Distributor
  2. 08-18-2009 08:28 PM #2
    I am looking for the depth of the clutch release bearing from the motor mating surface on the bell housing of the transmission.
    Can someone at your facility take a look at one of the VR6 02J units and post it here?
  3. 08-20-2009 10:53 PM #3
    I am looking to run a 2.0 NA 16V any ideas on what might be a go ratio to go with?
  4. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    08-22-2009 04:02 PM #4
    Sorry this thread is simply for the listing of transmissions available for sale.
    For technical questions or recommendations please email tech@aptuning.com
    Thanks
  5. Member the_q_jet's Avatar
    Mar 19th, 2005
    DC
    QUINTIN@USRT
    10-04-2009 01:39 PM #5
    i think the gear ratios might be wrong for some...here's what i got...
    1.8T trannys coded: EBQ, EMT, EGX, FBW:
    _1st___2nd___3rd___4th___5th___R&P_
    3.300-1.944-1.308-1.029-0.837-3.938
    TDI trannys coded: DQY, EBJ, EGR:
    3.788-2.118-1.360-0.971-0.756-3.389
    2.0 trannys coded: DZQ, EBP, EGT, EKG, EKH, EMS, EZK, FBV:
    3.778-2.118-1.360-1.029-0.837-4.235
    VR6 trannys coded: DZC, EHC, EGF, EWW, FBY, FCF
    3.625-2.071-1.474-1.038-0.844-3.389
    DONT PM THIS ACCOUNT!! I RARELY CHECK IT!
    IF YOU HAVE QUESTIONS/CONCERNS/ISSUESWITHZOMBIES PLEASE IM MY OTHER ACCOUNT BELOW:
    Quintin@USRT
  6. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    10-06-2009 03:30 PM #6
    No the ratios are not wrong. They are European transmissions and are very close and may be exact on most ratios but not all. Thats why they are listed as compatible trans codes.
    I personally think the ratios are better then most of the U.S. ones as they help even the rpm change between shifts on 1st-2nd.
    And the VR6 trans especially is nice as it has the longer first similar to the early 02A boxes
  7. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    10-27-2009 12:30 PM #7
    Transmissions are selling like hotcakes lol
    Most of these prices are comparable to a used trans. from a salvage yard.
  8. 11-18-2009 08:14 PM #8
    I have a 2.0T FSI Audi TT DSG, want to swap for a manual, what would be compatible?
    Thanks
    AUDI TTS
    Build thread: CLICK ME
  9. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    11-19-2009 09:15 AM #9
    Quote, originally posted by Serrari »
    Thanks
    These are all 02A/MK3 and 02J/MK4 5spd transmissions. Your best bet is going to be getting everything from a wrecked car, as you need everything that touches the trans(trans,clutch, axles,mount bracket, shifter stuff, etc, etc,)
    If interested please call the shop and we can see if we can source the swap for you.
    Thanks
    Tom
  10. 11-19-2009 12:42 PM #10
    care to elaborate? ive never heard anything bad about these guys and they've been around for a long time...
  11. 11-19-2009 01:10 PM #11
    Alias name.
    Modified by Blonde Imola Chick at 10:30 AM 11-19-2009
  12. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    11-20-2009 06:21 PM #12
    Yea im not sure what thats all about as that user posted something in every thread of ours then it got deleted or removed?!?
  13. Member ksgraphite's Avatar
    Jan 14th, 2005
    Bozeman, MT
    95 Jetta, 97 Jetta, 3/4 ton
    12-25-2009 12:07 PM #13
    What's the arranty on these new ones???
    Might want one for 97 2.0
  14. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    12-26-2009 04:41 PM #14
    Warranty is 1 yr.
    These are 02A-02J your 97 2.0 has an 020
  15. 01-14-2010 06:50 AM #15
    hi i have a 1999 new beetle 1.8 turbo manual 5spd
    and i think that the tranny broke... what tranny should i buy or what other tranny can i use?
    thank you
  16. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    01-14-2010 11:37 AM #16
    replied
  17. Member thank god for vw's's Avatar
    Apr 5th, 2004
    beverly,ma.
    67westy,93 fox,94 2.0l 8v ,98 volvo s70t5,78 volvo 262c bertone
    01-20-2010 03:52 PM #17
    Quote, originally posted by APTuning »
    Warranty is 1 yr.
    isn't it posible to swap out the 020 for either of theses? of course i would need to swap out the entire shifter and linkage to the cable set up.
  18. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    01-20-2010 08:33 PM #18
    Quote, originally posted by thank god for vw’s »
    yes it def it but
    you would also need clutch, flywheel, mount brackets, shifter box, clutch hydraulics, started, axles i think thats it
  19. n00b
    Sep 7th, 2009
    Vancouver BC
    2002 Jetta 2.0
    03-28-2010 04:40 PM #19
    I have a 2002 2.0L Jetta with a hole in the bellhousing. How can I tell my transmission code?
  20. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    03-30-2010 06:04 PM #20
    Quote, originally posted by paranoiattack »
    Code can be found on the trans itself next to the shift assembly or on the production tag in the trunk next to the spare tire well
  21. 05-07-2010 12:57 PM #21
    soory to sidetrack do you guys sell 02M transmissions with gears and all?
    If yes..how much?
  22. 05-08-2010 07:02 PM #22
    just wondering still aval and how much with a peloquin installed ?
  23. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    05-14-2010 02:22 PM #23
    Quote Originally Posted by RED BULL View Post
    Which are you looking for?
  24. Member CorvetteKillerVr6's Avatar
    May 9th, 2007
    Sarnia, Ontario, Canada
    2001 VW Jetta GLX VR6T on 20psi (Garrett 60-1)
    08-14-2010 09:01 AM #24
    any chance you guys have O2j Parts
    i need the shift tower housing. Part # 02J 301 232 A.
    i really really really need one asap
  25. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    08-18-2010 11:34 AM #25
    Should have Ill check and let you know.
    Please send an email to tech@aptuning.com to follow up as I dont get on here as often as I would like
    thanks
    Tom
  26. 08-26-2010 10:49 PM #26
    I need a manual transmission code EHA for a 2003 VW Jetta GLS 1.8L gas engine. Is the one listed on your thread for $1295.00 available and if so who mnufactures it and is it OME? Would there have to be anymodifications for installation or is it a complete drop-in? What is the warranty? Thank you very much for your assistance.
    Sincerely,
    Pat Heffernan
  27. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    08-27-2010 11:00 AM #27
    Quote Originally Posted by patfheffernan View Post
    Sincerely,
    Pat Heffernan
    This was responded to via your email prior to this post?
  28. Member
    May 4th, 2010
    Northern VA
    '01 Jetta GLS
    10-05-2010 03:13 PM #28
    I have a 2001 2.0 Jetta with an auto in it looking to do a manual swap. What would I be looking at in here?
    Thanks
  29. 11-20-2010 10:39 AM #29
    Quote Originally Posted by cjon3s View Post
    Thanks
    I'd like to know as well thanks.
  30. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    11-20-2010 01:07 PM #30
    Quote Originally Posted by zedt3 View Post
    Please private message or email about that kind of info this thread is a for sale thread for new parts
    Thanks
    tom
  31. 02-08-2011 11:05 PM #31
    EHA code shipped to Greenland NH?
  32. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    02-09-2011 10:03 AM #32
    Quote Originally Posted by R-GTI20 View Post
    Shipping would be about $200
  33. Junior Member helmy's Avatar
    Feb 7th, 2009
    Egypt
    02 GOLF 2.0
    02-17-2011 10:49 AM #33
    My car is MK4 Golf 2.0 APK with Auto Box. what 02j trans. could be compatible with it?
    Thanks in advance
  34. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    02-17-2011 10:57 AM #34
    Quote Originally Posted by helmy View Post
    Thanks in advance
    02J Transmissions
    Ring & Pinion: 4.24
    Price: $1275.00
  35. Member black wolfsburg 99's Avatar
    May 7th, 2005
    2003 Jetta 02M Swap 1.8t, 2000 Passat 1.8t
    04-19-2011 09:31 PM #35
    Do you still have any of these in stock? How much for shipping to 92408 in a California business area? Any credit for a fully working one that grinds into 2nd sometimes? I have a 2003 Jetta 1.8t.
    Ring & Pinion: 3.94
    Price: $1295.00
