VWVortex.com - Why does my coolant keep running low
    Results 1 to 20 of 20
    Thread: Why does my coolant keep running low
    1. 06-05-2009 06:52 PM #1
      I just had the alternator replaced, and the day after I picked it up from the shop, I am driving along and the coolant level light comes on. Sure enough, it is low, so I put more coolant in. The next day, same thing. Obviously, I have a leak, how do I diagnose this? There doesn't seem to be any leak under the car, so does that mean head gasket or block? How can you tell, and what is the typical cost to fix either one?
      Thanks guys!
    2. 06-05-2009 07:04 PM #2
      see if its leaking around the thermostat. (its almost directly under the alternator.) maybe they bumped the black plastic hose coming off of the engine or something.
    3. 06-05-2009 07:36 PM #3
      That's what I was thinking because everything was fine until after I got it back from the shop. I even called them back and asked if they noticed any leak or anything.
      I looked but can't see the hose by the thermostat, is there a "creative" way to get to the thermostat? i'm not engine savvy, so bear with me
    4. Member Andaloons's Avatar
      Apr 16th, 2004
      Texas
      2004 GLI 02M; 1997 Ford F-150
      06-05-2009 07:46 PM #4
      Quote, originally posted by klive72 »
      You pretty much have to pull the intake manifold to get a good look at it.
      Please vote for a Maestro Tuning Sub-Forum!
      PM me for Bentley repair manual PDF.
    5. Member WHITEWOLF01's Avatar
      Jan 8th, 2006
      Orlando - ish
      04 BMP GLI............ 01 Jetta Wolf R.I.P
      06-05-2009 07:48 PM #5
      get a pressure tester
      Modified by WHITEWOLF01 at 8:49 PM 6-5-2009
    6. 06-05-2009 07:51 PM #6
      OK, Thanks, I'll try that.
      One other thing I shoul add, the coolant doesn't seem to leak just sitting idle, it seems to leak when driving. I filled the coolant tank last night, and this morning it was the same level. I drove it to work and back (35 mi ea. way), and the coolant level light came on about 10 miles from home. Does that indicate one thing or another?
    7. Member Andaloons's Avatar
      Apr 16th, 2004
      Texas
      06-05-2009 07:54 PM #7
      Heat builds pressure in the coolant system. The more pressure, the more leak. Probably a small crack in plastic piping or bad o-ring.
    8. 06-05-2009 08:11 PM #8
      Thanks, hopefully that is all that it is, those are inexpensive fixes!
    9. Member vwgtimk41088's Avatar
      Oct 31st, 2007
      Henrietta, Ny
      06 Jetta GLi,
      06-05-2009 08:40 PM #9
      dont remove your intake, to see if the thermostat is leaking!
      remove your engine covers, then look to the right of the alternator right where you see the coolant hose, get a flashlight and a mirror, if you still cant get a good look at it remove the black bracket attached to the intake and dipstick tube.
      How many miles you have? water pumps like to leak? Look above your transmission as well as your coolant flange is right there and they also like to leak.
    10. 06-05-2009 08:55 PM #10
      130k
    11. Member vwgtimk41088's Avatar
      Oct 31st, 2007
      Henrietta, Ny
      06 Jetta GLi,
      06-05-2009 09:21 PM #11
      if the Timing belt/waterpump/tensioner hasnt been done yet get them all done.
      if you remove the belt cover(PITA to get off/on sometimes) and look at the waterpump if its leaking you will see what looks like corrosion on a battery terminal (best way to describe it)
    12. 06-06-2009 08:29 AM #12
      Quote, originally posted by vwgtimk41088 »
      Thank you !!! Some one with some sense!!! You also may want to look at your Aux. water pump seeing that it sit right infront of the alternator and some dumb ass could have hit it. The water pump and coolant flange are very good places to look. If you run a pressure test then you will find the leak for sure!
    13. 06-06-2009 08:34 AM #13
      Its a close system so you arent "running low," you have a leak somewhere.
    14. 06-06-2009 10:12 AM #14
      OK Guys, some updated info to mu low coolant levels. Since I was only noticing the problem when I drive, I decided this morning to turn on the car and let it run for 1/2 hour to see if I could notice any leaks. (I wasn't noticing any when the engine was cold). I also wanted to see if I was getting a lot of water coming out of the tail pipe which wouldn't be good. After 30 mins, sure enough there was a huge puddle of coolant under the car, as pure as when I put it in. So, that probably indicates a leaky hose or something??? What should I try next?
    15. 06-06-2009 10:51 AM #15
      Pressure test the system and look at the highest point first, then work your way down.
    16. Member vwgtimk41088's Avatar
      Oct 31st, 2007
      Henrietta, Ny
      06 Jetta GLi,
      06-06-2009 11:55 AM #16
      check these in any order you want: coolant flange, thermostast housing, water pump, auxilary water pump, and hoses.
      when the car is sitting still where does the puddle seem to sit under related to the car?
    17. 06-06-2009 12:18 PM #17
      Where do I get a pressure tester?
    18. 06-06-2009 01:43 PM #18
      - I found the leak in 2 places, the first hose is at the top just behind the engine (between the engine and dash); there is an "s" shaped hose about an inch or so in dia.that actually has some heat protective covering around it and another hose running along side of it. There is a small leak there. The 2nd is just below that large hose. It is about a 1/4" dia hose and if I set my flashlight on top of the brake fluid container and shine straight down, I can see it coming out pretty good there also. Bad news, no way I can get in there and fix myself with my tools. any comments?
    19. Member vwgtimk41088's Avatar
      Oct 31st, 2007
      Henrietta, Ny
      06 Jetta GLi,
      06-07-2009 12:58 AM #19
      bad news is that the only dealer in your area that im aware of is Garnet VW in Chadds ford(lived in west chester for two years). if your not to far from west chester i would recommend Tom's Volkswagen on Market St. He is a good guy that doesn't rip you off unlike garnet where they dont have a problem with breaking your panels in you interior and then dont do anything to fix the problem that they caused.
    20. Member zeusenergy's Avatar
      Feb 25th, 2008
      New Hamp-Shire
      2011 MK6 Jetta TDI
      06-07-2009 01:40 AM #20
      It may just be one of those hoses. So don't rip it all apart to fix both until you are sure both are bad. The larger one goes to the heater core in the dash, the smaller line goes to the turbo bearing from the hard pipe on the passenger side frame rail. Pressure might be pushing the coolant out onto another hose.
      I have VCDS and located in New England, PM me!
      Four 1980 Audi 5000s gas and diesel, 1987 & 1988 VW Fox, 1980 VW Mk1 Scirocco, 1987 Audi 5000 TQ, 1988 Audi 5000 Q, 2001 VW New Beetle Sport 1.8t, 2011 VW Jetta MK6 TDI/DSG
