Page 433 of 510 FirstFirst ... 333 383 423 429 430 431 432 433 434 435 436 437 443 483 ... LastLast
Results 15,121 to 15,155 of 17844
Thread: The Official Scirocco Chit Chat Thread!
  1. Member Neptuno's Avatar
    Jul 16th, 2003
    DE 202 Concord Pike
    82 Scirocco~Rodolfo~85 Vanagon~El Guapo~
    03-19-2012 10:30 PM #15121
    Quote Originally Posted by vwdaun View Post
    Ok, first of all, the Passat management / intake stuff is going to be a TIGHT squeeze in the Scirocco engine bay. Possible? Yes, but not very attractive. If you can find the intake bits from a 16v Scirocco it will look a whole lot better and perhaps be easier to work on in the future.
    Exhaust: The 8v parts will not bolt up to the 16v parts. Not even close. You will **have** to use a setup for an A1 chassis w/ 16v, the only thing from the factory with this setup was the Scirocco 16v. Or you can use an A1 16v aftermarket header.
    I'm with Tony on this one - figure out the issues with why the 1.7 isn't running first. It's not a great engine, but it's usually easier to start with known issues than adding more potential problems right from the start.
    You better be with me or I would have to....oh....well
    yes the 1.7 was the crappiest of all the engines in these, but a good working 1.7...its bullet proof...trust me i have abuse that lump...
    Quote Originally Posted by Mtl-Marc View Post
    The engine does not need oil, it runs on awesomeness.
    For Sale 14" Steel rims:For Sale 14" Steel rims:http://forums.vwvortex.com/showthread.php?6029120-FS-Great-Shape-14-quot-rims-12-hole-4x100-Steel-rims-with-tires-caps-and-beauty-rings-120
  2. Member mk3vrdub6's Avatar
    Nov 4th, 2008
    hanover,pa
    01 GTI 1.8t, 82 Scirocco 2.0 16v
    03-19-2012 10:33 PM #15122
    Quote Originally Posted by Neptuno View Post
    Look at Cathy instigating!!!! before yo go ripping into stuff make sure you have the bible for both cars (Bentley) expirienced hands and that you really have thought this out...It is not just a blind I think Im going to do this thing...
    If it was me I would sort out the 1.7 get it right and then think of the swap...but that is just me...i have been like a bone collector for the last 3 years...and im yet to swap the 2.0ABA/JH with boost
    Oh meant to ask what color is the interior in that 82 cedar green?
    I have both Bentley's, All Data,and a VW tech at my disposal.
    The fuel distributor needs replaced on the 1.7, I took it apart for "cleaning" .... there was no cleaning or rebuilding it. The car runs great on starting fluid tho.
    The interior is mostly grey, and the headliner/ pillars/visors are white. I'm going to work on the car Thursday all day, I will be snapping a few pictures to post up.
    I appreciate all the advice though, I will definitely do more research before barreling ass into the swap.
  3. Member Neptuno's Avatar
    Jul 16th, 2003
    DE 202 Concord Pike
    03-19-2012 10:40 PM #15123
    Quote Originally Posted by mk3vrdub6 View Post
    In the mean time finf the FD from a 1.8 and put it in the car. It will work if all else is good to go..
  4. Member mk3vrdub6's Avatar
    Nov 4th, 2008
    hanover,pa
    03-19-2012 10:44 PM #15124
    That helps alot! Definitely not trying to create any more issues for myself.
    This is the first older volkswagen that I've worked on.
    I've had mkIII's and mkIV's , so this is my first stab at a volkswagen older than myself.
    I just want to do things right, verses " this will kind of work"
    Half assing is not something I want to be associated with.
    Again, Thank you guys. I really appreciate it.
  5. Member mk3vrdub6's Avatar
    Nov 4th, 2008
    hanover,pa
    03-19-2012 11:08 PM #15125
    I'm pretty sure thats all that it needs.
    P/O replaced the fuel pump,filter, plugs, wires, distributor, cap, rotor, timing belt..
    there is a small cut in the throttle body boot, but I have another to replace it.
    It ran and idled fine on an alternative fuel source.
    I'll keep you guys up to date and will definitely post more pictures thursday through-out the day.
  6. Member vwdaun's Avatar
    Oct 6th, 2001
    Dayton OH
    Multiple Sciroccos and a Jetta Wagon
    03-19-2012 11:30 PM #15126
    Sounds like if you can find a replacement fuel distributor, you might be good to go. Easier than swapping out the engine and quicker too.
    OMG I just re-read what you said about Mk3s / Mk4s and your age. That makes me feel old.
  7. Member punchbug's Avatar
    Jul 15th, 2000
    Ontario's deep south
    Assorted German Scrapmetal and a really old aircooled trike project
    03-20-2012 07:35 AM #15127
    Yeah. I am trouble maker. But a 2L 16V? Hello, that's fun in a box right there. And yeah, not as straightforward as putting it into a 16V car. I didn't notice that it was an 8V to 16V swap, but that certainly has been done lots of times, so you aren't chopping the trees, merely plowing the field.
    Me? My projects are more like moon explorations, no idea what I will find when I get to the dark side......
    Latest pics...
    Some things that will buff out:
    Speaking of which, I had a brainwave last this morning...I may as well bring part of the plane home to work on...that way I can do some Scirocco wrenching in between scrubbing and cleaning, and I will have my helper. She follows me everywhere, here she is gardening with me yesterday...
    ...or....not....my internet service still sucks... so that will wait till later....
  8. 03-20-2012 07:53 AM #15128
    Hang in there Cathy!
  9. Member vwdaun's Avatar
    Oct 6th, 2001
    Dayton OH
    03-20-2012 11:09 AM #15129
    Quote Originally Posted by punchbug View Post
    Interesting how that one piece has a fair bit of corrosion, but the rest looks to be in good shape. BTW, I should get your opinion while you're here on that Skyhawk that Brad's working on for the guy who's exporting it. It's got LOTS of corrosion in the wings.
    LOL!!! It's both nice and sad that you can bring parts home.... but I've met your help and she's always nice to have around.
    Speaking of help, I had some the other day when I went to my parent's to work on Olive Oil.
    She wore herself out for the trip home.
  10. Member
    Sep 9th, 2007
    NC
    03 Passat Variant, 86 Scirocco 16v, 73 BMW 2002
    03-20-2012 11:27 AM #15130
    I think it is great that you can take your kids with you like that, and have good hearing protection for her. My tiny pup would love it.
    He might have some issues fitting though.
  11. Member
    Sep 28th, 2001
    Belmont, CA
    '81 Z1 Scirocco Ragtop, '78 CE (gone :(
    03-20-2012 03:08 PM #15131
    Ruh-roh...
  12. Member punchbug's Avatar
    Jul 15th, 2000
    03-20-2012 07:49 PM #15132
    Quote Originally Posted by gamblinfool View Post
    Ruh-roh...
    Sigh, I will have a fresh hone too (get yer minds out of the gutter) but mine will be on my strut housing, the one with that lovely seal (?) above...
    And there are some lovely shiny things in that picture that are very distracting. It always seems a shame to me that it is all sealed up. but the the (EDIT) smiles will come and it is all good again.
  13. Member scirocco*joe's Avatar
    Feb 23rd, 2002
    Roughly
    things broken
    03-20-2012 11:30 PM #15133
    ^^ Dat dere's purrrty, Jeff. Is it going in the CE or the ragtop?
    Quote Originally Posted by sin bar View Post
    i don't even understand everything that's going on. i'm simply impressed.
    Philadelphia, PA
    1981 Scirocco
    2010 Sportwagen TDI
  14. Member vwdaun's Avatar
    Oct 6th, 2001
    Dayton OH
    03-21-2012 12:25 AM #15134
    Check the update in the Blue Plate Special thread.
  15. Member California 16v's Avatar
    Jul 20th, 2008
    Gulf Coast of Florida
    2 Sciroccos with 16v's in them, both from California : 1978 & 1988
    03-21-2012 05:28 AM #15135
    Ruh-roh...
    glad this is going into the ragtop
    Pura Vida
    Surf to Surf Tomorrow
  16. 03-21-2012 08:45 AM #15136
    Ruh-roh...
    2 Liter Bubbles are my favorite. I wouldn't mind getting a little grease under my nails when the time comes...
  17. Member punchbug's Avatar
    Jul 15th, 2000
    03-21-2012 05:47 PM #15137
    Why is this so close to the bottom????? I just washed my Scirocco and she got a new bauble today, so she should be good to go. she does like her baubles, that one. So tell me what is wrong with this picture...not worried about salt in March, got caught in the worst snowstorm of the whole winter in October..... She seems to have had a goodwinter's sleep. Gotta vaccuum her and check the tire pressure and good to go...I hope. I never trust a 16v...they are very sneaky wabbit
    Edit: Okay, she is lighter now, apparently the area under the shift boot is a good place to store dog chow. Who knew?
  18. Member type53b_gtd's Avatar
    Feb 27th, 2006
    MidWestern
    84 Scirocco GTD (Carrots), 77 Scirocco (Inga), 81 Scirocco S (Delilah)
    03-21-2012 10:02 PM #15138
    Apparently the mice knew, and the cat didn't. And from what I've seen of your dog... yeah, don't even go there...
    Safe drive eh?
    PS I got the wires pulled into the hatch and the harness completed - just need to splice it into the rear connector and move on to the next one on the list.
  19. Member vwdaun's Avatar
    Oct 6th, 2001
    Dayton OH
    03-22-2012 04:08 PM #15139
    How could it be that nobody has posted in here today??
    I'm at Cincy Ground-Zero today, and am expecting the arrival of a certain Silver 16v with Ontario plates on it before long. Aaaaand I heard from a couple other out-of-town Scirocco owners that will also be in Dayton this weekend, so it's officially looking like a party Saturday afternoon.
  20. 03-22-2012 04:26 PM #15140
    Well, Daun- I was busy.
    - Lost cell Phone found (discovered) in my friend's pocket, good to have friends. (And it needs charging, but "I didn't make any calls..." huh. ok.) This after tearing up the house and calling it while hovering near the trashcan outside, Hilarity ensued...
    - Oh, and I had a phone interview, might be gainfully employed starting Wednesday. (Don't count chickens, ...).
    Other than that, it's been uneventful...
    It's been hard to campain a Scirocco when you like to eat too. Gotta do something about that.
  21. Senior Member Chris16vRocco's Avatar
    Apr 29th, 2006
    W123
    03-22-2012 06:46 PM #15141
    I drove the 80 to work today and got one of the fine chaps to weld up an exhaust pipe for it. It's now much much quieter.
    Deal with it.
  22. Member mk3vrdub6's Avatar
    Nov 4th, 2008
    hanover,pa
    03-22-2012 08:08 PM #15142
    Visited the 82 today
    Anyone know where the paint code is located, I'll be honest when I say I didn't even try to look yet.
    Sent from my LG-P925 using Tapatalk
  23. Member cuppie's Avatar
    May 3rd, 2005
    Redford, MI
    88 Scirocco 16v (Wilda); 86 QSW (still unnamed); 90 325iX (Nina - kid's car)
    03-22-2012 08:47 PM #15143
    Sticker in the spare tire well.
    Or (maybe) on the floor back there. But, definitely in the cargo bay.
    - Cup
    '88 Scirocco 16v, 'tastefully' modified.
    things currently broken (Scirocco): 5
    things currently broken (QSW): too many; but, slowly getting better
  24. Member California 16v's Avatar
    Jul 20th, 2008
    03-22-2012 09:21 PM #15144
    cool photos
    this 82 is Cedar Green Metallic (LK6Y)
    also the sticker you'e looking for looks like this, also as the VIN sticker : http://website.lineone.net/~dr.dub/vin_sticker.htm
    Pura Vida
  25. Member mk3vrdub6's Avatar
    Nov 4th, 2008
    hanover,pa
    03-22-2012 09:34 PM #15145
    Thank you
    Planning on respraying it the same color...
    Maybe mk1 bumpers?
  26. Member Neptuno's Avatar
    Jul 16th, 2003
    DE 202 Concord Pike
    03-22-2012 10:19 PM #15146
    Thank you
    Maybe mk1 bumpers?
    If you have them look up the color code....have the painters do a small can as a tester and see 1st if it is even close....the mixes change. There is a current tread for Cirrus Gray (what my car is) that explained how paint recipes change over the years.
    Cedar Green is one of my favorite colors....BTW your interior is special. 82-83 and maybe some 84's had 4 color plaids in the US red ( have most of them), blue (Randal is looking for most of them), brown/beige and black...that be you and upoo2 (trevor).... I'm sure many more, but I'm just saying.... don't just toss the interior out before noting if it is salvageable,
    I went to Canada (just 45 minutes into Windsor) to pick up a complete (extra) red interior for mine. Front, rear seats, all door cards and rear cards..and have an extra 2 piece parcel rear shelf in read...Yours should be black....special these are.. I'm telling you special
  27. Member TheTimob's Avatar
    Sep 13th, 2003
    Glenside, PA
    84 Scirocco on Megasquirt
    03-22-2012 10:25 PM #15147
    Status: All sciroccos broken. Again for a second time this month.
    My car: starter. Luckily it's under warranty.
    Becky's car: Fuel pumps, and the clutch too for fun.
    Electric scooter: needs batteries
    Bicycle: needs air in the tires
    Legs: cramped. Needs bananas.
    Vintage Watercooled Technotes:
    http://www.vintagewatercooleds.com/tech/
  28. Member 0dd_j0b's Avatar
    Sep 22nd, 2007
    San Diego CA
    87' Cabriolet-Sold, 87' Scirocco now 16v, 87' Scirocco 16v-Sold, 85' Scirocco 8v, 13' Jetta
    03-22-2012 10:27 PM #15148
    Quote Originally Posted by TheTimob View Post
    Yikes! that is no bueno. Good thing starter is an easy fix, and it was warrantied.
    Insert witty comment here.
  29. Member Neptuno's Avatar
    Jul 16th, 2003
    DE 202 Concord Pike
    03-22-2012 10:30 PM #15149
    so that the grasshopper sees it!
    Dude....black cloud go away from the timbos!
  30. Member mk3vrdub6's Avatar
    Nov 4th, 2008
    hanover,pa
    03-22-2012 10:31 PM #15150
    These seats are here to stay for sure. I have a guy that might be able to "refresh" them a bit. He does good work.
    Thanks for the heads up about the paint, I will definitely do that first.
  31. Member Neptuno's Avatar
    Jul 16th, 2003
    DE 202 Concord Pike
    03-22-2012 10:34 PM #15151
    Im willing to bet I'll see this car in person one day
  32. Member mk3vrdub6's Avatar
    Nov 4th, 2008
    hanover,pa
    03-22-2012 11:35 PM #15152
    It will be at h20i and waterfest for sure.
  33. Member punchbug's Avatar
    Jul 15th, 2000
    03-23-2012 12:20 AM #15153
    Okay, I am here in Dayton, and have learned a few things. for example, if you are running on the same tank of fuel in Columbus as you were in Ontario, you should stop for fuel on one side of Columbus. THAT would NOT be the distant side. I had enough to make it through, but failed to account for the huge parking lot that turned a fifteen minute drive into an hour and a half. I had enough fuel for the fifteen minutes.....
    And of course during this, my car suddenly went into a panic attack AND remembered all that stuff she'd read on the Vortex about 16Vs and how unreliable they are...so she decided that her glassy smooth idle was outta there...may as well hunt wildly for an idle somewhere between like 4000 rpm and 4 rpm. The 4 rpm wasn't quite enough so I was doing the good old clutch/gas/ebrake/look for cell phone idiots in SUVs....and stressing about how low into the red was the end of my fuel pumps...and did I mention that supposedly Obama was in town...and there was construction?
    So I did what any red blooded Canadian girl is a sundress would do. yup, hit the nearest off ramp into the heart of downtown Columbus in search of gas. And I knew I was not going to find that easily, but there were a lot of real "nice" looking shops with partly disassembled cars in the lots.....it was beautiful.
    Amyway, after asking someone, I found some gas before running out, but I felt pretty stupid....luckily the people in the sketchy neighborhoods are always really nice. I was just glad it was a sunny day, and I had a really nice drive otherwise.Tonight the idle has returned to glassy smooth. I wonder if it was just some cruddy gas from the bottom of the tank? (but I will test the O2 sensor too, funny how the things you "just changed" get really old after years and years.....) It was good to get her out on the road, and she still makes that satisfying roar when the loud pedal is pushed towards the floorboards. God I love a happy 16V!
  34. Member California 16v's Avatar
    Jul 20th, 2008
    03-23-2012 12:43 AM #15154
    glad you made to Dayton safely Cathy, despite a few minor problems
    Pura Vida
  35. Member TheTimob's Avatar
    Sep 13th, 2003
    Glenside, PA
    03-23-2012 08:00 AM #15155
    My coworkers have boxed me
