VWVortex.com - AC/Heater blower doesn't work
    Results 1 to 8 of 8
    Thread: AC/Heater blower doesn't work
    1. 06-09-2009 05:57 PM #1
      Hi all, Thanks in advance for any assistance that can be provided!
      When I try to turn the fan (1-4 selection) on for the AC or heater, nothing happens. No air comes out at all. This just happened one day and I am not sure what to check. There is dead silence as well. I believe I have checked the fuse, but the fuse card is a little confusing so I am not 100% sure I checked the right one. Does anyone have any suggestions? I am hoping this is something I can fix at home without having to pay high repair costs. I have a 99 Jetta, new body style.
      Thank you
      Modified by kjasso at 2:14 PM 6-9-2009
    2. 06-12-2009 06:50 PM #2
      bump for same problem!
    3. 06-12-2009 07:07 PM #3
      I have to admit I am probably an idiot asking this, but that diagram is extremely helpful, except I dont know what part of the car that is?
    4. 06-12-2009 07:09 PM #4
      So a quick swap and it should be working? All fuses are good, a/c system is working/new minus the blower...just checking before I drop the cash for the resistor.
    5. 06-12-2009 07:21 PM #5
      Got 'em cheap on ebay ftr.
    6. 10-01-2009 07:25 PM #6
      How the !@#$ do you remove the insulation pad covering the plenum??? I got two screws out, but there is a strap that extends WAY up one side, and behind a sharp edge on the other, with no apparent way to unhook it. Am I supposed to CUT the thing off???
