#7106
Hi, i need some help, in my 1993 vr, one relay is missing but i don´t know the purpose of it and the relay number needed, this is a picture of it:
Located near this area:
Lots of red/white cables... i guess something is not working right but i am not sure what is it
#7108
#7109
And another dumb question of mine. Why does my car have a distributor engine? I thought the updated interior 93's should have a coilpack, though mine does not. Is this normal?
#7110
Normal. Early 93's with distributor have the interior, and no Secondary Air Injection, or Coilpack (Obviously). Old Faithful because col packs are indeed the devil.
Easy enough to take the cap off the strut, lift the car and drop the strut out of the tower to check the mounts. The Bearings will require removal of the struts.
No the Coil on the Dizzy cars just bolt through the fire wall. But this is something else. I'd need to look it up in the Bentley. Or you could look at yours because I got s*** to do.![]()
#7111
#7112
#7113
#7114
Just opened up my supercharger and found this waiting for mei have the parts to rebuild the charger is this going to affect it?
#7116
#7118
#7119
Its possible - you can even buy it brand new ....
http://www.bar-tek-tuning.com/lshop,...080321201,.htm
...^^don't count on it tho![]()
#7121
I am moving away for college in a few weeks my plan was to get my car done before i leave, but with this charger issue i am wondering if there is a way to bypass the charger and run it without it.
#7123
#7125
Hello I need help trying to get a link to source me some good new or almost new door handles for my G60 corrado, links to where to buy them would be awesome
#7127
hmm dealer sells them Still I might have to swing by my dealer see if they have any, I know original German folk sell handles also but without locks and that's something I don't have... Also I heard Passat door handles work what year of Passat??? Any other handles I could try?
#7129
#7131
Can someone tell where's this sound coming from? It's coming from the passenger side and seems to get louder as I go under the car.
#7132
[B] INSTAGRAM: europeein
Facebook: facebook.com/addmichael
#7133
So I'm getting my hands on some staggered 16x7 front and 16x8 rears Porsche phone dials ... And I want to know if anyone has had this set up before on there rides and what size adapters were used make them sit flush or a lil tucked in... Any info would be awesome thank you
#7134
#7135
whats the best strut tower bar for vr6 and still keep the engine bay looking clean. do they make that big of a difference?
this is my sport themed car. all others were low and slow.
#7136
#7137
#7139
I cant figure out whats going on! when i speed up around 3000rpms if i push in the clutch and let go of the gas it starts going on its own? and also if i let go at around 3000 i feel a big jerk kinda like the pressure is building up but not being released properly?
you can hear the jerk noise when i let go at 3000 in it and also at the end you can hear how it starts going on its own when i let go at 4000 and I have to push the gas again to make it stop rising
I did just fill it up for the first time since I got it and put in just normal gas not any of that high octane stuff... could that be doing it?
#7140
So, i just finished working on my g60 it has not been used for over a year i bought it in dallas and drove it back and parked and started to tare it apart. When i bought it from the guy it was running all right not that great but not to bad. when i got home took around 4 hours it stared to load up and run reallly rich and started to die on me since then i have done alot of work on it i have replaced all cooling hoses, radiator, plugs,wires, cooling sensors and allot more. finally today it we cranked it over. it is running terrible. It can not idle at all i cleaned the Idle Stabilizer Valve with carb cleaner nothing i have found some vacume leaks on the MAP sensor running to the ECU we cut the bad part off some were i heard it must be 1m long is this true? I took it out around my block and it was terrible i was cutting in and out jerking and would barely run it was dark and i had my lights on the whole dash panel was flickering on and off and it was jerking and sputtering. there is a amp connected in the back so i wondered if that is drawing to much power maybe fuel interjection is messed up? i thought i would post on here see if i can get any advise. I also bypassed the supercharger as it is cracked and i am saving up for a used one in good condition.
