| Quote, originally posted by prodigy_g60 » |
Since I knew that anwser was coming what is needed to do it? Is there a write up on ISV removal? I just wasnt sure what the best stuff to use was WD-40 or brake cleaner? |
actually to clean it use Brakleen GREEN can ONLY and spray and let it fall out till the Brakleen falling back out is clear again... spray it in from any possible angle as possible... i also use the straw provided... if you want to then follow it up with WD-40 to keep it lubed up after all the Brakleen has dried out, sure, but i never have. oil flows through the ISV so i never worried about it, but i guess it's not a bad idea...
removing it completely makes the car run alot more like a Carb'd car in the sense you have to spend alot of time setting the idle and changing it for different types of weather... i deleted one for about a month or two. drove me nuts if the weather changed too much so i had to buy a new one... just my opinon on deleting it though...
EDIT: removing the ISV on your G60 is killer easy... unscrew or obliterate your crimp clamp from your ISV at the manifold connection, then do the same to the other hose exiting from the driver side of the ISV. unplug the harness from the passenger side. then slide the ISV w/ the rubber grommet attached off of the hook... just comes straight up and then your ISV is out...
Modified by vdubCorrado at 6:06 PM 6-15-2009
