VWVortex.com - How much does it cost to put on new shocks and struts usually?
    Results 1 to 9 of 9
    Thread: How much does it cost to put on new shocks and struts usually?
    1. 07-26-2002 03:19 PM #1
      How much does it cost to put on new shocks and struts usually? I already bought the parts. What is the labor usually? How long does it take?
    2. Member kidsdo@yahoo.com's Avatar
      Aug 3rd, 2000
      Tualatin, OR
      2010 A4 Avant, 2013 S4
      07-26-2002 03:26 PM #2
      One local VW dealer did one of my cars, and a different local dealer did the other. Each charged about 2.5 to 3 hours labor (around $200). There was a recall going on my Passat Wagon that included a no-charge front alignment at the time, so I figured it was a good time to do springs/dampers. Make sure if you go this route that you discuss and agree ahead of time on price, and you should do fine--I worked with the service managers. Hope this helps.
    3. 07-26-2002 03:34 PM #3
      Thanks. That's what I needed.
    4. 07-26-2002 03:42 PM #4
      you'll get the best deal if you install them yourself.
    5. Member mattdesmond's Avatar
      Jun 12th, 2002
      Gaudy side of town, MN
      328i, Crosstrek, M1100, FLHX, FXDB, X300, Zuma
      07-26-2002 03:58 PM #5
      I have ben quoted from $160 to $400 for different shops.
      One other thing, if you have a MKIV, your car may not need an alignment after suspension install. Mine did not, these cars are engineered nicely.
    6. 07-26-2002 04:07 PM #6
      Mine had an allignment, install, and front sway install for 365.00
      Seemed a little hefty but since that had to drop the subframe for the sway install it was costly
    7. 07-26-2002 04:43 PM #7
      How can I do it myself? It there a list of instructions somewhere? What do I need? Thanks
    8. 07-26-2002 04:50 PM #8
      the rear shocks and springs literally take 15 minutes- The fronts are more complicated but can be done as long as you have the right tools. try this link
      http://www.mkivresource.com/mods.html
    9. Former Advertiser
      May 1st, 2002
      07-26-2002 05:47 PM #9
      160 for a MK4 suspension install...... I would be woried. $300 is about the range you should be in. Plus $70 if you do the front sway (Major pain in the Ass). We get alot of "Can you fix my suspension" jobs in here. Much more worth your time to go to a good, experienced VW shop.... (No Honda tuner shops!)
