VWVortex.com - DIY/FAQ: Trunk / Hatch Interior Trim [Partial] Removal
    Results 1 to 18 of 18
    Thread: DIY/FAQ: Trunk / Hatch Interior Trim [Partial] Removal
    1. Senior Member BHB's Avatar
      Oct 26th, 2004
      Southern California
      '11 Grand Cherokee
      06-22-2009 08:11 PM #1
      This DIY/FAQ is for the partial removal of the interior trim in the trunk/hatch of a GTI/Rabbit.
      As always, any work you do on your car is at your own risk. Myself, and this website cannot be help accountable for anything that goes wrong while working on your car. Please undertake at your own risk.
      Tools Needed:
      Flathead Screwdriver
      Torx T25 driver / bit
      Torx T30 driver / bit
      Steps
      1) Remove the trunk storage trays, trunk floor, and hatch cover. You do not need to remove the spare tire unless you want to.
      2) Use your flathead screwdriver to pop open the trim cover directly underneath the seatbelt.
      3) Under this cover, there are two T25 screws. One is all the way inside the trim, against the body. A magnetic bit driver is VERY useful for this step. Keep in mind, for step 4, that the front piece of trim (that the seatbelt rests on, does not need to be removed. You can push is forward a bit, and slide the "12V / Trunk Light" trim piece out without removal.
      4) There is one last T25 (Three in total) screw, hiding under the trunk latch trim piece. Peal back the top of the trim, to access the screw. The trunk latch trim is held on be metal clips. To remove the carpet trim, you will also need to pop out the black "plug" bellow the screw. You might as well do that now.
      5) Then the trim piece will litterly just pull off. There are no more screw holding it on, just plastic "clips" unlike every other VW trim removal I've done, I somehow didnt break any clips. They seem pretty sturdy.
      6) Here, you can see the clips (in red circles) that hold the trim piece on. I had to pull pretty hard, but sure enough, it does pop off. Before you can remove it completly, you will need to unclip TWO harnesses (red arrows) - one for the 12V plug, and the other for the hatch light.
      7) To remove the carpet trim, you'll then need to remove the "tie down" hook. Here is where you will use your T30 bit/driver.
      8) Peel back the trunk latch trim. I only need access to the right hand side, so I only pealed back enough to remove the right carpet trim. The trunk latch trim is held on with metal clips.
      9) To fully remove the carpet, you will need to remove the seats, or cut the carpet. I didnt want to do either, so I will just keep it pulled back for this project. (seen here)
      10) Here is a view of the body with the trim removed/pulled back.
      11) When you put everything together, don't be an idiot like me and forget to reinstall stuff. Oh well, who needs a hatch light when you have a 10,000 candlepower flashlight back there?
      12) Put the trunk storage, floor, and hatch cover back together.
      Edit: Added additional photos
      Modified by bhb399mm at 9:01 PM 6-22-2009
      Current: 2011 Jeep Grand Cherokee 5.7 Hemi 4x4, 2015 BMW R1200GS, 2016 Mazda CX-5 GT AWD (Wife)
      Gone: 2010 Audi S4; 2008 GTI; 2007 Audi A6; 2004 Audi allroad 2.7T; 2001 Audi A6 2.7T; 1999.5 Mk4 Jetta VR6; 1991 Jeep Cherokee 4.0 4x4
    2. Member VdubVSHonda's Avatar
      May 4th, 2008
      Boston, MA
      2008 VW GTI
      06-22-2009 08:15 PM #2
    3. Member goldn's Avatar
      Jul 10th, 2007
      Collingwood, ON
      MK7 SportWagen TSI
      06-22-2009 09:44 PM #3
      what about removing the plastic cover off the hatch door... anyone done it?
    4. Senior Member Ducky 2.0T's Avatar
      Jun 4th, 2001
      Lehigh Valley
      Japanese Toaster
      06-23-2009 11:40 AM #4
      That's easy. undue screws.. Pull down like a mother *******.. proceed to break clips and curse when you crack your face on the plastic.
      Jan 7th, 2003
      Long Island, NY
      09 GTI : 88 GLI
      03-26-2010 09:31 AM #5
      BUMP
      Quote, originally posted by goldn »
      ...seriously tho, I need info to access the panel from the back side... got a minor ding mysteriously in the hatch.
    6. 12-04-2010 02:31 AM #6
      pics are dead--still floating around somewhere?
    7. Senior Member BHB's Avatar
      Oct 26th, 2004
      Southern California
      '11 Grand Cherokee
      12-11-2010 06:04 PM #7
      i will have to re upload.
      Aug 13th, 2010
      OK
      '06 Jetta 2.0T 6sp
      01-31-2011 12:12 AM #8
      Any chance we could get pics up?
    9. Senior Member BHB's Avatar
      Oct 26th, 2004
      Southern California
      '11 Grand Cherokee
      01-31-2011 12:22 AM #9
      yes... might take a few days, but i will get them re-hosted.
    10. Member fruitbat03's Avatar
      Mar 3rd, 2004
      Charlotte, NC
      2012 Audi A3, 1980 Scirocco track car, 1951 Chevy Bel Air (literally Mom's first car)
      03-11-2011 04:19 PM #10
      Trying to remove my rear wiper, the only screws I see are in the handles on the hatch to remove the plastic piece to gain access to the wiper motor. Are there more than these two?
    11. Member vortexn's Avatar
      May 22nd, 2010
      Canandaigua, NY (585)
      1999 Audi A4 Quattro
      03-11-2011 04:23 PM #11
      yo BHB any luck on getting pictures? i got a rattle i need to get taken care of and would like to use this DIY!
    12. Member JetTurbo's Avatar
      Sep 17th, 2001
      Cincinnati, OH USA
      2012 Golf R, 2008 b6 Passat 4-Motion
      03-11-2011 10:06 PM #12
      Quote Originally Posted by goldn View Post
      Quote Originally Posted by Ducky 2.0T View Post
      Quote Originally Posted by fruitbat03 View Post
      Nope, just those two screws and ten very stubborn trim clips.
      The ten metal trim clips snap into the ten oval slots in the metal inner section.
      2102 US Golf R, 2008 US b6 Passat 4-motion - sold 2006 US Mk V bmp GTI mt (230,000 miles/ 7 yrs)
    13. Member vortexn's Avatar
      May 22nd, 2010
      03-11-2011 10:56 PM #13
      something inside there is rattling and driving me nuts
    14. Member MkvMikeD's Avatar
      May 3rd, 2012
      New Bedford, MA
      15 Audi A3 2.0T, 08 VW Jetta 2.5, 07 VW Rabbit
      05-27-2012 10:24 PM #14
      Quote Originally Posted by vortexn View Post
      Same problem
      Also the pics in the DIY at the top are still dead. Any chance we can get that fixed?
      Thanks!
      Instagram @mikedfromnb
      Quote Originally Posted by kevin FaKiN spLits View Post
      Ya if I drove that I'd expect a cop to pull me over, taze me, night stick the living piss out of me, then throw me in prison to be raped
    15. Senior Member BHB's Avatar
      Oct 26th, 2004
      Southern California
      '11 Grand Cherokee
      05-27-2012 11:17 PM #15
      let me see if i can dig these up tonight, folks.
    16. Member dub_life91's Avatar
      May 8th, 2013
      Mukilteo, WA
      2007 VW Rabbit(Kara), 2010 VW Jetta TDI wagon(dad's car)
      10-21-2013 12:16 AM #16
      i cannot see these pictures, is it just me? i really need to see them haha
    17. Member babydubz's Avatar
      Dec 12th, 2007
      The Great White North
      MKV GTI
      10-22-2013 02:38 AM #17
      ^ not just you. I can't see them either and I, too, need them
    18. 01-03-2014 05:03 PM #18
      Another hopeful bloke that would love to see how to do this DIY.
      Al
