VWVortex.com - 2.0 8v (2E) rough idle and slight jerking
    Results 1 to 17 of 17
    Thread: 2.0 8v (2E) rough idle and slight jerking
    1. 06-24-2009 07:03 PM #1
      The car is 1993 Volkswagen Vento(Jetta III), with 2.0 8v (2E) engine.
      The problem is, that some time ago, the idle went a bit rough, at first it didn't bother me much, but then it got worse, and now today it started to jerk a bit even when accelerating.
      When idling, occasionally the rpm drops down to like 350 rpm for a sec, and at other times just keeps jumping up and down between like 600-700 rpm really fast.
      The problem occurs both when the engine is cold and when it's warm.
      It did appear before, that there was some sort of loss of power, when the engine got to working temperature, but now, it seems kinda "weaker" all the time.
      I've replaced the distributor cap, distributor rotor, temperature sensor, air filter, vacum hoses, and spark plugs, but the problem just seems to get worse every day. The old spark plugs seemed to be of very strange color also.
      Anyone got any ideas what to do/check?
      Picture of old spark plugs:
      Modified by Mr47 at 2:32 AM 6-25-2009
    2. Member mk4slow8v's Avatar
      Sep 21st, 2008
      03 jetta 2.0 04 saab 2.0t
      06-24-2009 09:44 PM #2
      bump i wanna know too
      Jul 31st, 2002
      '74 Bug (yard), '96 Jetta 255K (yard), '02 Cabrio 104K (sold), '06 Rabbit 127K BGP, '08 Jetta 55K
      06-24-2009 10:03 PM #3
      Wires and coil. Check 'em out. Look under the hood at night to see if you can see sparks.
    4. 06-24-2009 11:08 PM #4
      Excerpt from automedia...
      "Normal, but with red coating: The red coating is a result of the additives in lower-quality unleaded fuel and will be visible on the plug's ceramic insulation. The red coating is not an indication of any engine problems."
    5. 06-25-2009 01:23 AM #5
      Have you checked for vacuum leaks?
    6. 06-25-2009 06:48 AM #6
      Well, i'll check the wires when it gets dark( it's midday here at the moment.
      I doupt there's a vacum leak, if i replaced all the vacum hoses?
      Also, about fuel, i've only taken fuel from the two major companies around here, and used the "better fuel", here we got 95 and 98, i've been using 98, almost all the time, though, i haven't had the car for all too long, i have no clue whatkinda fuel the previous owner might of used.
      I'll check how the new spark plugs look now
    7. 06-25-2009 07:30 AM #7
      So, i checked the new spark plugs... not a sign of anything red on them, but the engine still works same badly. Will update my findings in the evening, about the spark plug wires. How do i check the ignition coil?
      Also there appears to be strong vibration starting from like 2000 rpm, gets stronger up to 2400 rpm (being the strongest) and then gets weaker again as you rev higher
      Picture of the new spark plugs (which have driven like 50 km)
      Modified by Mr47 at 2:46 PM 6-25-2009
    8. 06-25-2009 04:58 PM #8
      Okay, in the dark, i sprayed some water on/over the spark plug wires... not a single spark or anything whatsoever, no impact on engine work either.
      Also, from this schematic, i cleaned #1 (control valve for idling stabilization) with carb cleaner... still no effect .
      I am curious what is #15 on the scheme and what's the thing, that #11 connects to?
    9. 06-25-2009 09:00 PM #9
      I guess it's down to the coil now... or could it maybe be MAF?
    10. Member alixjg's Avatar
      May 3rd, 2008
      East Butler, PA
      '06 GLI
      06-25-2009 09:19 PM #10
      Sounds to me like a MAF issue... I would def. try some MAF cleaner. That really helped me out when my engine was chugging and I had a rough idle. Although... it was a few days later... my transmission ate sh*t.
    11. Member
      Jul 31st, 2002
      06-25-2009 10:30 PM #11
      Scan it and you won't have to guess or waste more money. Those plugs look like mine did when my coil went.
    12. 06-26-2009 10:02 AM #12
      Well, i was going to buy me the vag-com cable, i do have the software... but it's not so easy to get the cable, as no shops actually sell it, through the local volkswagen club forums some guy was sellin' those, but he has disappeared... so... Going to a diagnostics place costs more than the coil itself
      But i'll try cleanin' the MAF. I suppose some carb cleaner would be suitable?
    13. Junior Member aa2p's Avatar
      May 25th, 2009
      Nashville, TN
      2003 VW Golf
      07-03-2009 05:20 AM #13
      Actually my golf was doing the exact same thing rpms fluctuating like crazy. It's like it had a mind of its own. It threw me a coolant temp sensor code. I replaced it and I have not had a prob yet
    14. 07-05-2009 07:38 PM #14
      yeah idk if my plugs are red but my car occasionally wont wanna start and it revs real crazy all by itself....turns out i got 3 CEL codes and one is the Engine Coolant Temperature sensor ...youd never think that a coolant sensor would make your car rev so spazzy but i guess it can really do a number on it...must be thats why these sensors are so cheap...they must go bad quite often..
      Modified by dopeheadonmoped at 4:40 PM 7-5-2009
    15. Member rednecksavage's Avatar
      Mar 11th, 2002
      Alabama
      2011 VW CC, 1997 VW Golf, 73 Fastback
      07-06-2009 01:09 PM #15
      I am curious about this. My sons car has the same issue. Where is the coolant temp sensor? Is this the blue one with 2 wires coming off of it?
      Thanks
      "There is no great genius without a mixture of madness."
      Aristotle
    16. Junior Member
      Dec 10th, 2011
      Hansen
      Golf 2 2.0 8V carb
      05-09-2012 12:24 PM #16
      Ok...i got the same issue right nw. I have a 2E carb. If i tune my timing on th CAM (standard) to 0. It runs okay. But has almost no power or kick in it. If i tune the timing on the CAM to th front 1, its got power, but it has that uneven idle. I tried changing the plug cables, it was fine for a day thn back to it again. Carb cleaner didn help at al. Im stuck man.
      Vdub 4 live
    17. 10-18-2013 01:59 AM #17
      Good morning every one tell me is there anyone with a golf mk2 with 2e engine carb conversion
