VWVortex.com - Lugtronic 16v Update = 582 whp 430 wtq on E85 fuel
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 30
    Thread: Lugtronic 16v Update = 582 whp 430 wtq on E85 fuel
    1. 06-27-2009 12:48 AM #1
      Todd (turbodub)'s MK3 Street GTI is now running on E85 fuel, Bosch 1680cc Injectors, still daily driven on the Lugtronic ecu.
      Dyno runs here at ForceFed yesterday yielded 582 whp and 430 wtq:
      Same boost as before (35 dropping to 32 psi), and this is with a badly damaged turbo compressor wheel.
      Now running a T3 .82ar housing on the GT35R turbo. (*thanks Aaron)
    2. 06-27-2009 02:18 AM #2
      Amazing........
      I'm sure it could hit 600 on a colder day.........
    3. Member sp_golf's Avatar
      Nov 28th, 2007
      Toronto
      88 Golf 16vT
      06-27-2009 04:55 AM #3
      Doing it right [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      It's still peaky though, but I bet it will be fun to drive down the track. Can't wait to see some #s
      Just outta curiosity, how's the timing map compared to C16?
    4. 06-27-2009 07:29 AM #4
      Thanks for the words. As you know, this is the car that was reeeeally gutless before with the T4 hotside. The combination of the T3 .82 and the E85 has really helped wake up the midrange, this dyno makes 40-50-50-50 whp more than the last setup at 5k to 6.5k, a significant improvement.
      This car has Schrick 276 cams, which are big for this power level.
      The cams could use some internal tweaking to optimize the powerband.
      We are waiting for a fresh turbo for the car so this was just to get by for this weekend, and to play with the E85.
      As with about every car that I tune, I'm sure there is more in it.
      We were about tapped with the boost, it was starting to fall pretty good to redline. But the timing was not pushed hard at all. We basically unstrapped the car without hitting any kind of wall.
    5. Member 05JettaGLXVR6's Avatar
      Jan 24th, 2006
      Annapolis, MD/Stockblocks, NJ
      06-27-2009 08:39 AM #5
      Hows the idle with 1600cc's?
    6. Member turbodub's Avatar
      Jul 6th, 2000
      garden state
      94 golf
      06-27-2009 10:30 AM #6
      haha what took you so long?
      Quote, originally posted by 05JettaGLXVR6 »
      idle is good, bounces around a little. but still better than my friends a4 with tapp software
    7. 06-27-2009 10:46 AM #7
      Quote, originally posted by turbodub »
    8. Member turbodub's Avatar
      Jul 6th, 2000
      garden state
      94 golf
      06-27-2009 01:31 PM #8
      heres my brand new chra. does this make it a custom turbo now?
    9. 06-27-2009 03:36 PM #9
      ive been waiting for you to do an E85 car......Kevin u know iam next.
      Racing Improves the breed..
      "I have fought the good fight, I have finished the race, I have kept the faith"- 2 Timothy 4:7
      CrossroadsLI
      MY ALL MOTOR BUILD THREAD
    10. Member obd2vr6's Avatar
      Jul 6th, 2006
      97 jetta 3.0 VRT
      06-27-2009 04:57 PM #10
      nice numbers
      cant wait to get my PnP Ecu
      97 3.0 VRT
      THE BEAST
    11. Member Daskoupe's Avatar
      Oct 9th, 2006
      Sarasota, Fl
      mk2 coupe,15 A3 Tdi
      06-27-2009 06:00 PM #11
      second my area gets e85 i'll be on the band wagon
    12. 06-27-2009 10:38 PM #12
      The idle is helped by the E85's need for more fuel flow.
      The Bosch 1680's idle fairly well, the problem area with these injectors is actually off-idle, low load low rpm cruising. The engines need for fuel drops and the injectors go into the range where they are very very non-linear, and the a/f is very inconsistent. Once thru this part, the engine runs very very well.
    13. 06-27-2009 11:29 PM #13
      So its not that great for daily,but on the track is the boombap ???
      Eny vids of this monster ??
      oh,forgot,great job [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    14. Member turbodub's Avatar
      Jul 6th, 2000
      garden state
      94 golf
      06-28-2009 12:58 AM #14
      Quote, originally posted by mcdub »
      unless youre used to driving a cadillac for a daily driver its nothing a vw owner cant get used to!
    15. 06-28-2009 11:17 AM #15
      Quote, originally posted by Kevin@ForceFed »
      WOOT!!!! you know where it goes when you'ns are done with it. glad to help, like always.
    16. 06-28-2009 03:15 PM #16
      cadillac ftw,have you ever driven one of those ????
      lol
      sounds allot like my old build.well snail and head wise
      again [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    17. 06-28-2009 05:13 PM #17
      That things an effin street carr!!!
    18. Member turbodub's Avatar
      Jul 6th, 2000
      garden state
      94 golf
      06-29-2009 07:48 AM #18
      sure is full interior, may get a/c back in the future
    19. Member DWI_gti's Avatar
      Jan 11th, 2004
      NJ
      06-29-2009 10:38 AM #19
      Which A4 you talking about? Cause I dont have a massive air leak now so im idle is fine,
      but you did say "my friend" so I assume your talking about Paul
      Modified by DWI_gti at 10:41 AM 6-29-2009
    20. Member turbodub's Avatar
      Jul 6th, 2000
      garden state
      94 golf
      06-29-2009 10:57 AM #20
      Quote, originally posted by DWI_gti »
      no pretty sure its you! the same dik that left all the cluck u food open in the outside garbage for the raccoons to feast on last night and make a mess outside the house!
    21. 06-29-2009 11:07 AM #21
      you will clean that crap off of our lawn as soon as you get off of work or I will kindly transfer into the interior of your choppy idling A4
    22. Member
      Dec 14th, 2001
      Greensburg, PA
      06-30-2009 12:57 PM #22
      Sissy!
      Life begins at 101 kpa ...and so does poverty--Lugnuts Calhoun
    23. Member turbodub's Avatar
      Jul 6th, 2000
      garden state
      94 golf
      06-30-2009 06:51 PM #23
      Quote, originally posted by Mark Morris »
      Sissy!
      get it right a sissy with no trans!
    24. Member
      Dec 14th, 2001
      Greensburg, PA
      07-01-2009 09:10 AM #24
      Do I have to come over there and fix it for you in a parking lot?
    25. Member
      Nov 26th, 2000
      New Jersey
      A2 GTI,B5A4,B6A4, 2.7t
      07-01-2009 10:27 AM #25
      Not me, i no longer have that problem, and change your fuel filter
