VWVortex.com - symptoms of a bad cam position sensor
    Results 1 to 8 of 8
    Thread: symptoms of a bad cam position sensor
    1. Member GLI_jetta's Avatar
      Jan 2nd, 2006
      Stroudsburg pa
      04 GLI
      06-29-2009 03:11 PM #1
      whats up guys.. having a horrible vac problem and the car tripped a cam position sensor code... jsut wondering what are the symptoms of the car if that goes bad?
      STROKED 35r
    2. Member racin2redline's Avatar
      Sep 24th, 2008
      Long Island NY
      audiTT225Q, Stg3 6MT swapped allroad
      06-29-2009 03:34 PM #2
      hard to start... its pretty easy to replace its 2, 8 or 10mm bolts( cant remember )and a plug right under the plastic timing cover the sensor is like 80-120 bucks
    3. Member GLI_jetta's Avatar
      Jan 2nd, 2006
      Stroudsburg pa
      04 GLI
      06-29-2009 03:45 PM #3
      its tripping... I have been told its because my crank and cams arent in sync...
      STROKED 35r
    4. Member
      May 7th, 2009
      A car plant somewhere in Aladamnbama
      01 TT225(daily) 01 TT225(project) 03 GTI 20AE (daily) Occasionally a new model Acura/Honda lol
      06-29-2009 04:13 PM #4
      Need the exact code. It could be incorrect correlation, or implausible signal.
    5. Member GLI_jetta's Avatar
      Jan 2nd, 2006
      Stroudsburg pa
      04 GLI
      06-29-2009 06:02 PM #5
      i believe its 16725... or 4...... it is implausible signal though. i do konw that
      STROKED 35r
    6. Member
      May 7th, 2009
      06-29-2009 09:17 PM #6
      Check the wiring. You're using your AWP trigger wheel on the AEB head right?
    7. Member GLI_jetta's Avatar
      Jan 2nd, 2006
      Stroudsburg pa
      04 GLI
      06-29-2009 10:58 PM #7
      yeah i am, the funny thing is... everything is sound... and didnt have this problem until i started this new motor...
      STROKED 35r
    8. Member a4maine's Avatar
      Dec 13th, 2009
      Greater Bangor Area
      97' Audi A4 1.8t q 04' a4 avant MK3 gti
      03-02-2010 08:55 PM #8
      Hey, I think I have a similar problem. After I did some minor work it died while driving and then would start and sputter, making a click noise every now and then. All i did before the issue was remove the fuel fuel rail, coilpacks, valve cover, IM, and Throttle body. I had to remove the hall sensor pigtail to remove the fuel rail. I also removed my pcv system to check all the valves.
      I don't have VAG available to me. I think its either the hall sensor pigtail/wire, or somehow the TB idle setting is out of whack. I'd drive to a shop but I can't make it but a few feet before sputtering out.
      Please give me any advice!
      Club Grim Water
      k04 97 audi a4
      62 beetle volks-rod
