VWVortex.com - Best way to fix mk1 Death Cancer on STRUT tower
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 38
    Thread: Best way to fix mk1 Death Cancer on STRUT tower
    1. Member MicroCADDY's Avatar
      Jul 21st, 2008
      Georgetown, KY
      ALL VAG garage. mk1 slammed CADDY, mk1 slammed JETTA, slammed THING, mk6 Jetta & 01 Audi Avant
      07-04-2009 05:10 PM #1
      I have a PROB. My dear 82 Caddy
      has got mk1 Death Cancer ( rust ) all the way around the passenger side strut tower.
      What would you do ?
      UPDATE BELOW
    2. Senior Member vdubspeed's Avatar
      Jul 18th, 2002
      Valdosta, GA
      I quit counting.
      07-04-2009 05:23 PM #2
      1. buy a welder
      2. buy steel or get a donor
      3. weld it in.
      Good luck [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Built > Bought
      58 Beetle | 79 Rabbit 20vT | 84 GTI TDI |84 GTI 16vT |12 Golf TDI ----89 325i | 99 QCSB Ram Cummins | 02 Burb 4x4 2500
    3. Member MicroCADDY's Avatar
      Jul 21st, 2008
      Georgetown, KY
      07-04-2009 05:27 PM #3
      Quote, originally posted by vdubspeed »
      1. buy a welder
      3. weld it in.
      Yea i know i'm going to have to do some welding here BUT if i get a donor HOW do i keep lined up so that my Caddy rides right. Hell the rust is all the way to the fire wall.
    4. 07-04-2009 06:09 PM #4
      a lot of the front end is spot welded togather.. if you get a complete donor car and take your time it shouldnt be too bad..
    5. Member gogogadget's Avatar
      Apr 13th, 2007
      In an Igloo
      a TT
      07-04-2009 06:10 PM #5
      Quote, originally posted by ToddA1 »
      Cut the repair panels to body lines that will act as reference marks. The Bently gives a ton of body measurements.
      You drive that thing, like that?
      -Todd
      I sure hope not
    6. Member MicroCADDY's Avatar
      Jul 21st, 2008
      Georgetown, KY
      07-04-2009 06:11 PM #6
      I drove it when it had some rust. Kept a very very close eye on it. The day after MIDWEST VOLKSFEST i saw the tower moving & put it into my garage to start work ASAP.
      I was hoping it would hold in there till winter when i was going to do a single round front swap & a 2.0 16v swap.
      STUCK doing it all NOW
      Modified by VWcaddy_LouEville at 3:13 PM 7-4-2009
    7. Member wantacad's Avatar
      Apr 3rd, 2003
      Belleville,Ill
      I haz a bunnah
      07-04-2009 06:20 PM #7
      A very good example of how the outside can look oh so perfect but underneath rot city.
      damm VW
      Quote Originally Posted by WackyWabbitRacer View Post
      You're new here but don't be a DORK.....
      Cheers, WWR.
      Quote Originally Posted by rte7x9 View Post
      Don't swap if you can't weld or fabricate. It's not a trivial task just to bolt everything up. There's a lot of nut-scratching involved. Take your time and do it right.
    8. Member MicroCADDY's Avatar
      Jul 21st, 2008
      Georgetown, KY
      07-04-2009 06:48 PM #8
      I know. I got to fix it before all my fellow Vdubbers notice that you can't judge a book by it's cover
      May 24th, 2009
      RVA
      07-04-2009 09:17 PM #9
      my caddy is headed in the same direction...and in the exact same place on the same tower. It isn't nearly as bad as yours though.
      Right now I'm looking for a donor car to cut the tower from. You might be better cutting the whole passenger side of the front clip off and taking it with you. If it were just a hole, I'd say you could weld in some metal plate but that's practically the whole right side of the front clip.
    10. Member MicroCADDY's Avatar
      Jul 21st, 2008
      Georgetown, KY
      07-04-2009 09:40 PM #10
      yea i agree with you on replacing the whole pass side. I think i'm going to head to my local J-yard & see whats there.
      Still need to figure out where to cut donor & where to fit it on my Caddy
    11. Member
      May 24th, 2009
      RVA
      07-05-2009 07:42 AM #11
      Quote, originally posted by VWcaddy_LouEville »
      if you're really unsure, you could take the whole right side with you and then "dry fit it" to your caddy to see where you should cut
    12. 07-05-2009 10:46 AM #12
      I would scrap that car.
      Fixing rust like that is for people up north.
    13. Member MicroCADDY's Avatar
      Jul 21st, 2008
      Georgetown, KY
      07-05-2009 11:19 AM #13
      Quote, originally posted by deathhare. »
      WHAT are you for real ? SCRAP YOUR CAR budy. I moved to KY from New Jersey & i don't care where you live anytime you can save a mk1 it's should be your duty to do so. Especially when it's a Caddy
    14. Member
      May 24th, 2009
      RVA
      07-05-2009 11:21 AM #14
      ok i love mk1's (caddies) too but to say it's your duty to save one is a bit over the top. after all, you're going to end up cutting up a rabbit to fix your caddy anyway right?
    15. Member MicroCADDY's Avatar
      Jul 21st, 2008
      Georgetown, KY
      07-05-2009 11:27 AM #15
      I'll be getting a donor part from a totaled already in a scrap yard mk1.
      Does anyone else agree with him scrapping my Caddy ?
      Modified by VWcaddy_LouEville at 8:37 AM 7-5-2009
    16. Member tobiwonkonobi's Avatar
      Nov 17th, 2002
      PVD
      mk1 coupe mk2 coupe
      07-05-2009 11:28 AM #16
      ignore Shannon...hes just a miserable basard
      VW Fiends German Speed Society Banchwerks PVW 4/08 & 7/12
      Nothing leaves Stock Creep Customz Brokestatus Get Low Unix Performance Gengstout
    17. Member
      May 24th, 2009
      RVA
      07-05-2009 11:52 AM #17
      your caddy looks great and I'm sure he was just bustin' your balls. Fix the rust and drive it
    18. Member MicroCADDY's Avatar
      Jul 21st, 2008
      Georgetown, KY
      07-05-2009 12:02 PM #18
      After fixing the rust & putting in the worked 2.0 16v i'm going to drive it like i stole it.
    19. Member RabbitJockey's Avatar
      Nov 25th, 2004
      York, Pennsylvania
      97 Trek, 81 Jetta, 81 Rabbit
      07-05-2009 03:20 PM #19
      ha it'd be a good candidate for a 4 door caddy.
      ..........___..................___..............._ __
      ......._//_|_\__........._//_|_\__........//|_|_\__
      ......|_@_|_|@|..O0o|_@_|_|@|..O0o|@_|_|@|
    20. Member MicroCADDY's Avatar
      Jul 21st, 2008
      Georgetown, KY
      07-05-2009 04:04 PM #20
      Quote, originally posted by Trev0rBr »
      uummmmmm NO
      BUT extended cab would be nice
    21. Member alec stensaa's Avatar
      Jan 9th, 2008
      Stanwood WA
      1983 vw rabbit
      07-05-2009 05:08 PM #21
      make an ex from the other apron, check bently. Drill out the spot welds, dont just hack the **** out of it.
    22. 07-05-2009 06:09 PM #22
      hey i was atpull a part and asked about a buying a rabbit shell, i was told about 150 for the whole shell with no interior, there are a few rabbits out there, your best shot is one of the two in the far back left corner, very little strut rust if any
    23. 07-05-2009 06:19 PM #23
      Yeah I was serious.
      My car doesnt need scrapping...it doesnt have any rust.
      I suggest getting another car and cutting out what you need or yeah, scrapping that one and moving on.
    24. Member 2mAn's Avatar
      Oct 15th, 2006
      Culver City
      changes daily...
      07-05-2009 06:35 PM #24
      ... extended cab would be nice
    25. Junior Member caddy freak's Avatar
      Apr 27th, 2009
      bangor me
      81 82 83 caddys 88 cabby 91 92 eco diesel jettas /many parts cars to finish parting
      07-06-2009 05:18 PM #25
      if u can find a doner rabbit just clip the doner car 2 door and 4 door floorpans are the same lot easier and less costly !!!
