VWVortex.com - 2001.5 Passat V6 Code- P1176
    Results 1 to 8 of 8
    Thread: 2001.5 Passat V6 Code- P1176
    1. Member 89VWdieselGolf's Avatar
      Feb 22nd, 2004
      Durham, Ont.
      2003 VW Jetta 1.8T race car
      07-09-2009 05:39 PM #1
      I've got an '01.5 Passat V6 (ATQ) 4 Motion
      It keeps throwing a CEL when cruising on the highway. It'll feel like a small studder then it comes on. Happens once ever other day for like 5-10 secs max.
      Vag-com reads:
      17584 P1176 035
      O2 Correction Behind Catalyst B1
      Control limit reached
      I dont want to just throw an O2 sensor in it and hope for the best.... but does that code mean it could be anything else?
      Thanks for your help,
      Jeff
      89VWdieselGolf's Autobiography
      2003 Jetta 1.8T Race car
      1990 Golf ABA Turbo -SOLD
    2. Forum Sponsor Uwe's Avatar
      Jan 16th, 2000
      Lansdale, PA
      Too Many
      07-09-2009 05:42 PM #2
      VCDS® -- Satisfaction guaranteed or double your fault codes back!
      I reserve the right to be a prick if people make unreasonable demands.
    3. Member 89VWdieselGolf's Avatar
      Feb 22nd, 2004
      Durham, Ont.
      07-09-2009 06:00 PM #3
      Checked the intake already.... didnt find leaks and the recalls have been done.
      i guess i have to test all the o2's. I'll hook it up next week at work and see what it says.
      Thanks.
    4. 07-29-2009 01:36 AM #4
      Sorry to bring back an old thread but I have identical issues and was wondering if you ever got it tracked down.
      Over the past months it has been getting worse. Under heavy load/full throttle I get an obvious surge/bucking. If I hold the gas down the bucking continues and I can even sometimes get a random cylinder misfire.
      Bucking issue doesn't happen all the time but it has been slowly increasing like I said.
      Scan with VAG-Com revealed p1176. I am currently out of town and VAG-less so I have yet to log anything.
      This is my first time getting the p1176 code. I used to have the bucking problem but never got a code for it.
      So if you got anywhere I would love to know.
    5. Member 89VWdieselGolf's Avatar
      Feb 22nd, 2004
      Durham, Ont.
      10-05-2009 08:20 PM #5
      ok so techs at work (vw dealer) suggested i change the B1 S2 O2 sensor (Passenger side rear o2)
      Did that and it came back on 2 days later (like it always does when i clear the code)
      Theres a waste of 2hrs and $160
    6. Member andyztoy's Avatar
      Jan 21st, 2006
      oshawa ontario
      92 jetta aaz td 2010 golf coupe - 2013 636 ninja
      10-07-2009 10:55 PM #6
      i suggest you fix the minimal exhaust leak
      that could very well be your problem
    7. Member 89VWdieselGolf's Avatar
      Feb 22nd, 2004
      Durham, Ont.
      10-08-2009 07:02 AM #7
      thank you , we figured that out together last night
      Jan 29th, 2001
      Ardmore, PA
      2001 Passat GLX
      01-10-2011 10:13 PM #8
      Are you saying that fixing the leak solved your problem?
