Page 1 of 5 1 2 3 ... LastLast
Results 1 to 35 of 170
Thread: MOGTG Cruise to Dubs on the Deleware. Its on the way off rt 80!!!!
  1. 07-21-2009 12:16 PM #1
    Aug. 2nd Dubs on the Deleware show. This cruise will start at the MOGTG spot which located right next to rt. 80 so even all NYC and CT folk can meet here and roll out together (good spot to stop for pee break for you guys to ) in one nice sized cruise.
    Lets do this big
    here is the location of the mogtg spot for those that dont know. http://www.google.com/maps?hl=...image
    From southern Route:
    Take 287N to exit 22B 206N. Take this all the way up to Mt. Olive to International Drive make left onto International Drive. it is a good 15-20 mins on 206 before international drive depending on lights. But reffer to the address in the link you can expanpd it for full info of address.
    From East NYC Area and other points:
    Take Rt.80 to exit 27B Drive less than a mile and International Drive is on your right. Bare right onto international drive Make left at Mcdonalds at the light. You will see us in the lot.
    Here is the MOGTG address.
    50 International Dr S # C
    Flanders, NJ 07836
    Ok got meet up time established. We will be meeting up @ 9am and then rolling out of the lot around 9:20 -9:30. This will put us at the venue @ 10:00- 10:10.
    Remember its a cruise and nto crazy time. The cops are a little more onedge out in west jersey cause ther eaint crap to do. My very good friend is a state trooper so I know .
    Modified by NastyJettaNza at 1:45 PM 7-27-2009
  2. Member Nolig23's Avatar
    Apr 22nd, 2005
    CNJ
    98 GTI S/C
    07-21-2009 12:20 PM #2
    Broke.Ballerz
    256whp 236wtq on a mustang dyno.
  3. 07-21-2009 05:21 PM #3
    Quote, originally posted by Nolig23 »
    dubs on the Delaware?
  4. Member Nolig23's Avatar
    Apr 22nd, 2005
    CNJ
    98 GTI S/C
    07-21-2009 05:27 PM #4
    Broke.Ballerz
  5. Member A2jettafreak's Avatar
    Apr 24th, 2002
    908<---- NEW JERSEY
    83 Rabbit Gti(baby), 97 Jetta vr6 (Daily beater)
    07-21-2009 06:01 PM #5
    damn id roll out if i wasnt leaving friday for sturgis south dakota
    COOLWATER VW
    Repping "908" all day!
    FS: Full set of Mk3 jetta/golf Leather door cards $ 100
    FS: Mk2 OEM Roof rack bar,feet,and roof basket $300
  6. 07-21-2009 06:19 PM #6
    BUUUUURRRRRRRP
  7. 07-21-2009 06:20 PM #7
    Quote, originally posted by A2jettafreak »
    you partying with bikers awesome!
    you better bring back sweet pics brah.
    edited first post.
    Modified by NastyJettaNza at 3:27 PM 7-21-2009
  8. 07-21-2009 06:30 PM #8
    im gonna try and make this...if i can get that lug removed without too much damage to the wheel
    Drive low, park lower...
  9. 07-21-2009 07:05 PM #9
    split it with a small chisel, from the outside. insert flat blade screw driver, or impact driver. heat with propane if necessary. remove. replace.
    enjoy
  10. 07-21-2009 07:06 PM #10
    wheres the actual event? MOAR GOOGLE MAPPPS!!!
  11. 07-21-2009 07:07 PM #11
    ta ta shots.
  12. Member Crubb3d Rymz's Avatar
    Dec 25th, 2006
    exit 19
    90 Jetta 07 Rabbit
    07-21-2009 07:13 PM #12
    Quote, originally posted by mikebbugn »
    whats wrong with it?
    i may or may not be going...depends if this sunday is nice or not
    coolwaterNORTH
    1990 Jetta VR6...money pit extraordinaire
    2007 Rabbit...why did i buy this again?
  13. 07-21-2009 07:53 PM #13
    that lugnut can not be remove d unless a master of the air chisel works at it. torch witll ruin the aluminum wheel. i could do it myself if i had an aircompressor at my house but i dont so bleh.
    Oversquare the event is just over the border in PA litterally 30 mins from this cruise spot.
  14. 07-21-2009 08:06 PM #14
    Quote, originally posted by Crubb3d Rymz »
    it was crubbed at a 24 flat fix shop in the bx..
    so if i fix it, i will consider going...
  15. 07-21-2009 08:10 PM #15
    baby jesus tear.
  16. 07-21-2009 08:36 PM #16
    where in pa? what town/park etc??
    that lugnut...well...since its so deep...you dont need a chisel. that would be suicide. you need a cardboard sleeve (from like tp or somthing), a can of PB blaster, and a nice cheap tool called an easy out. it requires a drill, and a drill bit. attach drill bit, use rubber hose/cardboard/etc in a short section around it, lube the inside with a LOT of PB, center on lug, cram hose/etc into the deep well that used to house the lug (in the rim,to protect it from the bit skipping), drill, and push. it will take a minute. then, insert the easy out (instructions on package). its reverse threaded, so then you turn it with a socket wrench (ratchet or spanner) and it should come out. if not, drill the damned head off,(with large drill bit) and remove the rest of the lugs, pull wheel, and extract via the stub thats in there with a small torch and vise grips. and patience. this will work just fine if you do it without flipping out and smashing things.
    or i can do it for $75 bucks
    Modified by OverSquare at 8:37 PM 7-21-2009
  17. 07-21-2009 08:48 PM #17
    can you meet me halfway? i would gladly pay you 75 bucks....since i have said to hell with the wheel already. but if you can save it from too much damage that'll be great.
    maybe i can go after all.
  18. 07-21-2009 11:56 PM #18
    Quote, originally posted by OverSquare »
    GPS Coordinates:
    • Latitude: 41° 00' 22'' North
    • Longitude: 75° 06' 38'' West
    OFFICIAL POST:
    http://forums.vwvortex.com/zerothread?id=4386330
  19. 07-22-2009 06:30 AM #19
    thats cake son.....about 40 mins south of where im at.
  20. Member PoppaCW's Avatar
    Aug 25th, 2002
    NJ
    02 1.8t...96 GLX
    07-22-2009 06:26 PM #20
    i'm going..most likely hung over but i'll be there
    COOLWATER
  21. Member redpnc-dubaholic's Avatar
    Aug 2nd, 2002
    93 corrado slc
    07-23-2009 12:03 AM #21
    Quote, originally posted by Poppa18T »
    already acting old and crotchety tim come you old man
    i catch cases just to beat them cause im just that baller
  22. Member Terrified1's Avatar
    Oct 7th, 2007
    Hillsborough, NJ
    07-23-2009 01:43 AM #22
    same
  23. Member SudZero's Avatar
    Jun 2nd, 2008
    clean part of dirty JerZ
    2010 White Wolf Turbo
    07-23-2009 12:02 PM #23
    the brown guy will be there!
    "60% of the time...it works every time."
  24. 07-23-2009 01:24 PM #24
    can i join with a few peoples
  25. 07-23-2009 01:26 PM #25
    Quote, originally posted by X02gtiX »
    Yes! The more the better. We can roll huge... I wanna make it a huge cruise only cause its easy to get there and not lose people
  26. 07-23-2009 02:45 PM #26
    keep this up there.
  27. Member SudZero's Avatar
    Jun 2nd, 2008
    07-23-2009 04:45 PM #27
  28. Member eudorrra's Avatar
    Jun 20th, 2006
    North Jersey, South Florida
    1995 Jetta VR6 (show/daily), #3882 (baby), 1993 Cabriolet (brat)
    07-23-2009 05:18 PM #28
    Quote, originally posted by SudZero »
    bwahahahhaha
    COOLWATER // I'm a loner, Dottie.. a rebel.
    Your lady needs a VW >>> *MINT* Auto MK4 GTI FS
  29. Member PoppaCW's Avatar
    Aug 25th, 2002
    NJ
    02 1.8t...96 GLX
    07-23-2009 07:27 PM #29
    i used to have a corolla like that..but mine was red and buffalo free
    COOLWATER
  30. Member Nolig23's Avatar
    Apr 22nd, 2005
    CNJ
    98 GTI S/C
    07-23-2009 07:42 PM #30
    i'll ride that buffalo! can i show it as a mk3 though?
    Broke.Ballerz
  31. 07-23-2009 09:42 PM #31
  32. Member dubbin_boho's Avatar
    Dec 3rd, 2007
    Long Valley, NJ
    IY 20th
    07-23-2009 09:46 PM #32
    in for this.. just registered for the show
  33. 07-23-2009 09:52 PM #33
    good deal. get all the people you know to roll.
  34. Member MKV.RABBIT's Avatar
    Jun 18th, 2007
    Mount Arlington, NJ
    07 VW Rabbit 4-Door
    07-24-2009 12:28 AM #34
    I'm in
  35. Member Nolig23's Avatar
    Apr 22nd, 2005
    CNJ
    98 GTI S/C
    07-24-2009 05:19 AM #35
    Broke.Ballerz
