VWVortex.com - How to check & fill the manual transmission fluid level 1998 VW Cabrio
    Results 1 to 15 of 15
    Thread: How to check & fill the manual transmission fluid level 1998 VW Cabrio
    1. 07-26-2009 02:28 PM #1
      I desperately need your help!
      I need to know how to check & fill the fluid level in my 1998 VW Cabrio...it is a manual transmission?
      Ive located what appears to be the drain plug; which is located on the rear of the transmission housing. the plug is on an angled surface near the bottom.
      You all are my best hope of learning how to do this...
    2. Member SnubbedMK3's Avatar
      Aug 27th, 2004
      Houston, TX
      1995 GTI VR6 - Mulberry
      07-26-2009 02:54 PM #2
      There is a plug, a giant allen key, on the driver side of the transmission.
      That's where you can check/fill the fluid. But on a 5spd, the transmission is normally completely sealed..
      And don't ask if it's a manual transmission.
      Is it 5spd or auto!!
      Modified by SnubbedMK3 at 1:01 PM 7-26-2009
    3. Member Harris_Teeter's Avatar
      May 30th, 2008
      Stool Bend
      Blackish Green
      07-26-2009 03:00 PM #3
      you'll need a 17mm allen socket
    4. 07-26-2009 03:18 PM #4
      5 speed manual... I've never heard of a "sealed transmission" ... should any maintenance ever be performed?http://forums.vwvortex.com/zeropost?cmd=reply&id=59358504#
    5. Banned
      Feb 19th, 2005
      Huntsville, TX
      07-26-2009 03:26 PM #5
      The only time i have replaced my fluid in the trans was when i replaced it, but it was shipped dry so i kinda had to.
      Are you having a problem with the trans? it is making noise?
    6. 07-26-2009 03:47 PM #6
      not having problems... I've just purchased it and was wanting to check it ... the car has 167K on it. The CV joint boot is in bad shape and I'm gonna replace it this afternoon.
      any tips you have would be appreciated...
    7. Member Old Windy's Avatar
      Apr 1st, 2009
      Someplace where there is no snow
      2.15678L 16V ABA, SN 95 Mustang V8, 2013 Frontier V6
      07-26-2009 04:06 PM #7
      You drain it on the bottom by the center of the trans. It looks like a giant 17mm allen bolt.
      If the trans is out of a car and you have not installed it yet; remove the speed sensor (it is on the top and it uses if I do remember a 24 hex key); turn it upside down and let it drain that way and refill it the same way then re-install the speed sensor and you are done.
      Also just to make sure replace the seal on the side (A big green one).
      Have fun it is easier than what it sounds.
      PS use two jugs of fully synthetic grease.
      Quote Originally Posted by Time for a GTI View Post
      Banging a hooker will make the wasps go away? I'm off to find a bee's nest. BRB.
      Quote Originally Posted by 88c900t View Post
      You mean CalDeRoo?
    8. 07-26-2009 04:19 PM #8
      I drained mine via that plug in the back that you noticed first.
      Then I had to go to NAPA and but that 17mm Allen wrench which cost about $13.
      Filled it up with some synthetic heavy weight ****, put that 17mm nut back in and called it a day.
      Seems to gear a little smoother now.
    9. Junior Member ProjeKT PistolWhip's Avatar
      Jan 31st, 2008
      Vancouver, wa.
      1997 Jetta GT
      04-08-2011 11:04 PM #9
      threads a little old, but just a helpful hint to anyone else who looks it up: instead of buying a 17mm allen, just pop one of your lug nuts off (most of which are 17mm) and use that and a wrench to get the plugs out. if ur cheap or broke like me this is the way to go.
    10. Member
      Jan 29th, 2011
      SE PDX
      mk3 golf (jolf)
      04-12-2011 10:02 AM #10
      sub
    11. 03-16-2013 08:13 PM #11
      Still talking about a 98 cabrio, 5 spd manual. Next to the speed sensor, there's a plug/cap/something. It's on a hump on the transmission where the shifter linkage links to the transmission. It's a pretty big cap, I didn't have a metric socket that big, but a 15/16 socket fit it fine. I took it off and peered in, all I see is more metal. Can you fill the transmission from there, or is that a separate, sealed chamber of its own? Seems easier than taking off the speed sensor.
    12. Geriatric Member VDub2625's Avatar
      Jan 3rd, 2003
      Fall River, MA
      12 Golf 2.5, 90 Jetta GLI 16v, 99.5 Cabrio Highline, 92 Golf GL
      03-16-2013 08:34 PM #12
      Put that back in and don't touch another thing on your trans without knowing what you're doing first.
      Some of those bolts hold internal parts that need the case split open to re-set.
      Do it by the Speedo hole. It's incredibly easy, it's an electronic sensor, not even a cable to worry about.
      You don't really need to check the fluid level, if it's original to the car, just replace it, it's cheaper than an engine oil change.
      Take the 17mm hex drain plug of the bottom to drain, take off the side 17mm hex to set the level (~2 qt/ltr is that fits there, when it starts to drain out the side fill hole it's done).
      Make sure to get GL 4 compatible fluid, there is yellow metal (brass synchros) inside and some other spec oils (including some GL5 exclusive oils) eat away at it. They do name GL 4/5 compatible oils. Spec is 75w90 but I used 70w80? I think it was (redline mtl, the redline mt-90 is factory spec and the only difference is the weight), trans is smooth as butter fresh after a rebuild.
      Sent from my LG-LS970 using Tapatalk 2
    13. Member
      Nov 8th, 2011
      98-VR6 96-tdi 05-Impreza 04-Tundra
      03-16-2013 08:44 PM #13
      make sure you can get the side 17mm bolt out (fill hole) before you remove the (drain) bottom 17mm.
      it sure would be schitty if you drained the fluid only to find out that the side (fill hole) is seized.
      Quote Originally Posted by germancarnut51 View Post
      Harbor Freight makes some decent tools
      Quote Originally Posted by VT-MKJett View Post
      I would question if that is a productive goal to have.
    14. Banned LöW N SLö's Avatar
      Jan 15th, 2013
      My house
      MK3 Jetta 2.ö
      03-16-2013 09:11 PM #14
      Best DIY out there:
      http://brokevw.com/020oil.html
      Thanks to BROKE for this.
    15. Geriatric Member VDub2625's Avatar
      Jan 3rd, 2003
      Fall River, MA
      03-17-2013 01:56 AM #15
      Quote Originally Posted by Svën Höek View Post
      The side hole doesn't matter much. It's just for a perfect fill but if you drain, just re fill with 2qt or liters (they're both approx. the same).
