Got me some of these. With EDM hole.
#1
1.8T I-Beam Forged FPO Rods with Forged Piston SetMade from Cr. Mo.Ni.Steel (SAE 4340) forgings. Heat treated to ensure internal as well as external strength and to facilitate uniformity of strength throughout the entire rod. All rods come complete w/ ARP2000 Fasteners. Wrist pin oiling Rifle drilled.
Brute Connecting Rods utilize forced pin oiling to facilitate a more reliable bottom end. We have found that under normal operation, dry pin bushings that rely on oil squirters and windage require a rebush far sooner then is acceptable to us. Ensuring that the pins recieve adequate pressurized lubrication can more then double the life expectancy. Since rebushing a tapered rod is an extremely complicated process, the added peace of mind is a good thing.
WE DO NOT DRILL OUT STANDARD RODS. THESE RODS ARE MANUFACTURED TO ACCEPT DRILLING TO KEEP STRENGTH
ASK ABOUT OUR ENGINE PACKAGES
Applications:
1.8T Custom and Off-The-Shelf Wiseco Piston Sets
1.8T OEM AEB Piston Sets
Modified by AL@PagParts.com at 8:34 AM 11-30-2009
Pag Parts
Turbocharger Systems, OEM Parts / Fabrication
Garrett / PTE / BW / TiAL / Clutchmasters / Southbend / Brute Con Rods / Wiseco / CP Pistons / Supertech / Ferrea / CatCams / Walbro / EV14 Injectors / Eurodyne Software / Much More... Pag Parts Facebook
#2
'12 CSG GTI - |DSG|LUX|TECH|SERRON|STG 2 APR|
#3
wish I ordered these from you arnold. Ordered a set of rods and have been waiting for almost half a year.![]()
#4
No worries Omar, I want to see your car rip w/ the setup![]()
Pag Parts
#5
Quote, originally posted by 20aeman » Ordered a set of rods and have been waiting for almost half a year. Made of gold ? Why half a year wait
#6
Quote, originally posted by 16plus4v » Made of gold ? Why half a year wait
Looooooong story, so I won't divert this thread...
But I will say that Arnold has been the one of the most reliable and trustworthy vendor I've dealt with on the forums. These Brutes come with the edm standard, and as such, you won't have to wait for edm machining (which has been one of my issues for why it's taken so damn long to get a set of rods)
#7
Sweet, do you have a good supply of these for me to buy up Arnold?![]()
2001 Golf mid-engine RWD Allroad 01E 2.7T TVS1320 BW S374 twincharged (long title, I know)
2004 A4 Ultrasport 2.0T 3076R built to the hilt all the way around (daily sleeper status)
#8
Of course Jake. Have them in stock
Pag Parts
#10
Thanks J.
Pag Parts
#11
wish these were out when i bought my rods. i will just have to get them when i need mine rebushed.
#12
Hey, nice rods... Need some CP's to go with them![]()
STROKED 35r
#13
for PC & AL
These rods are INA Approved!![]()
INA Engineering Inc.
Email | Facebook
INA Billet | 034 EFI | Mahle Powerpak | DM Forged | Ferrea | Supertech | ARP | South Bend | HTA Turbochargers | Mocal Oil control | DBW Throttle Body Upgrades
#14
can't wait to get mine![]()
Arnold has been great to deal with. I'm really looking forward to working with him for more of my build.![]()
#15
Im looking for a set of rods and pistons along with rigs and pins.
Email me with a price please.
iwearpro@aol.com
Brian
#16
responded. All PM's replied. BTW, Brutes are manufactured w/ rifle drilling in mind. They are not standard rods pulled and drilled. Keep it together guys![]()
Pag Parts
#18
19mm would be for the awp motor in h-beam config
Pag Parts
#20
#21
are there any HP estimates for 19mm ones? you should pack up some rod swap kit, with all gaskets and stuff![]()
#22
my buddy just picked up the I-beams and some Wisecos, The Ibeams are tits. definently nicer than my Scats are![]()
Take a second and thank a Veteran.
#23
Quote, originally posted by mescaline » are there any HP estimates for 19mm ones? you should pack up some rod swap kit, with all gaskets and stuff They are rated at 500hp but I wouldnt hesitate to throw more at them. The beauty of the tapered rods is the forced pin oiling. The thin section up top is adequately lubed and cooled which keeps heat down and the bushing intact. Tapered rods are engineered to eliminate as much reciprocating weight as possible under revs to keep the engine quiet. Perhaps its one of the reasons why we can use high comp pistons under revs and dont make the knock sensors go crazy... Knowing this throughout the years and the nature of bushing replacement on tapered rods, why not make them as reliable as possible?
As for engine packages, just ask. I've been doing it for years.
Quote, originally posted by boosted b5 » my buddy just picked up the I-beams and some Wisecos, The Ibeams are tits. definently nicer than my Scats are ![]()
I know, they are beautiful rods. I'll stack them up to Pauter any day.
Modified by AL@PagParts.com at 7:15 AM 8-18-2009
Pag Parts
#24
Do I have to build a spare motor now Al?
#25
Quote, originally posted by 18T_BT » Do I have to build a spare motor now Al? Of course you do Val
Pag Parts
#27
Quote, originally posted by yumann » Are these shot peened? Yes, they are heat treated and shot peened after the forging process
Pag Parts
#28
Pag Parts
#29
are these made in china like the other company that makes rods that are compatible with 19mm pistons?also are there only 2 companies that are made for the 19mm's?
#30
Quote, originally posted by 50trim S » are these made in china like the other company that makes rods that are compatible with 19mm pistons? also are there only 2 companies that are made for the 19mm's?
No, these arent
Pag Parts
#31
Are brutes made in the USA? where are they made?
There are a handful of people on this forum keeping it real and are intelligent enough to build proper cars. Everyone else, keep wasting your money and time running around in circles following the herd.
#32
what kind of power are the 20mm I Beam rods rated to? Im debating on replacing my eurospec rods with these.
Force Fed Engineering
Best Turbo Kits around.
565whp 60-1'ed 2.0 20v
Billet 67mm True Street Build in Progress
#33
Quote, originally posted by 20thAEGti1009 » what kind of power are the 20mm I Beam rods rated to? Im debating on replacing my eurospec rods with these. Lets just say I would rate them up there w/ Pauter. I wouldnt hesitate using these on a very high hp project
Pag Parts
#34
thats awesome.. cause im really not to sure if trust the eurospec's up at 565whp
#35
Quote, originally posted by 20thAEGti1009 » thats awesome.. cause im really not to sure if trust the eurospec's up at 565whp These are very beefy rods. Has everything that you might want to throw at it like the edms... in short, these things are fully load
Pag Parts
