VWVortex.com - MKIV Jetta & Golf Front Seat Removal
    Results 1 to 18 of 18
    Thread: MKIV Jetta & Golf Front Seat Removal
    1. Member Justin Lane's Avatar
      Aug 4th, 2006
      Sumter, South Carolina
      2009 GMC Sierra
      08-09-2009 11:56 PM #1
      So you want to remove your from seats. Some people might do this cause its dirty, so they want to clean. Others might be swapping out seats like me. I am going to try to explain this the best way I can so, hope you figure it out. I took pictures of me removing the passenger seat. But everything else applies to the driver seat too. This is for educational purposes only. Don't blame me if something goes wrong.
      first slide your seat all the way back until you can see this part up front. If you have a golf there should be bolts like this. If you have a jetta there will be a torx screw.
      Here is the torx screw that came from my jetta seats. The black seats came out of a 4 door golf, so thats why i have bolts on it now.
      once you have taken those to bolts or screws out slide the seat all the way forward until you can see this section in your back seat.
      you going to need something thin so you can pry the little cap off. underneath is this a philips head screw. (cross tip)
      once you take the screws out from it, they should just come right off.
      The final step is a little tricky. You have to slide your seat all the way back and sort of tilt it backwards too. This will allow the wheels to get off the track so you can pull the seat right out. Now I had some basic seats with no features. But you might have to flip the seat upside down to unhook a few cables. I pulled the airbag one right out. For those of you who have seat warmers and what not, you should just unhook them then pull the seat out. I found it easier to have all the doors open then pull it out from the front door.
      Now putting them back is just as easy as taking them out.
      Finished.
      Here are my new black seats
      Jun 12th, 2009
      PA
      B7 A4 3.2q 6MT
      08-10-2009 12:52 AM #2
    3. Member fancy sauce's Avatar
      Jan 27th, 2009
      California
      B5/30v/Quattro
      08-10-2009 01:42 AM #3
      cool [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    4. Member granmas 1.8t's Avatar
      Mar 21st, 2008
      San Diego
      2003 1.8T Jetta 1990 Jetta VR6
      08-10-2009 06:41 AM #4
      all that work and no GLI seats?
      Janky Garage Air suspension(Air Lift) Hard Lines, VAGcom,Frame notch, Fender Rolling, Detailing, Tires & wheels, Suspension works and more.
    5. Member Justin Lane's Avatar
      Aug 4th, 2006
      2009 GMC Sierra
      08-10-2009 12:21 PM #5
      if only i could afford them. i picked these up for 100 bucks. I always wanted black seats
      Modified by Justin Lane at 2:36 PM 8-10-2009
    6. Member JayZ235's Avatar
      May 12th, 2008
      Minnesnowta
      '03 PG GLi
      08-10-2009 12:46 PM #6
      Good info! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      And THANK YOU for making it a title that actually makes sense and search-able
      |||Eurowerks5||| ***The Midwest's Premiere European Car Show*** |||June 25, 2011|||
      "I need the life version of Icy-Hot"
      Flickr
    7. Member Justin Lane's Avatar
      Aug 4th, 2006
      2009 GMC Sierra
      08-10-2009 02:36 PM #7
      Hopefully they can put this in the faq. I noticed there is a rear seat removal but not a front seat one with pictures.
    8. Member euro_verrückt's Avatar
      Jun 4th, 2010
      Bologna
      04 Jetta 2.slow
      07-02-2010 05:05 PM #8
      very good DIY. prying those little caps off were a pain though
    9. n00b
      Jan 30th, 2011
      Port Union / 401
      2001 GTI jetta loaded
      02-01-2011 06:20 PM #9
      Thanks for taking the time to make this post.
      VERY helpful.
      Cheers
    10. Member 5i1verbu11et's Avatar
      Nov 3rd, 2009
      Clayton Heights, BC CA
      static 2004 mkivwagon 1.8t - eurospec
      04-04-2011 04:02 PM #10
      Great simple thread. Now I can pull out my front seats without breaking anything!
      Thanks
      Seat swap is now done!
      VELOCITY UPHOLSTERY - Surrey BC Canada ph#604.341.9314 www.velocityupholstery.com http://forums.vwvortex.com/showthrea...terior-Project
    11. Member veedubora's Avatar
      Jan 25th, 2010
      Austin, Tx
      2002 VW Jetta 1.8t, 2014 VW GTI 2.0 TSI
      06-07-2012 02:32 AM #11
      Fly exterior very
    12. 10-27-2012 09:41 PM #12
      I like your seats I scored the exact same set for my grey interior Jetta as well!
    13. 03-20-2014 10:02 PM #13
      What was the size of the torx bolt that came out of the jetta?
    14. Member im_lower's Avatar
      Feb 25th, 2011
      Destin, FL
      2013 Mustang GT 5.0, 11 Tacoma TRD, 1981 Benz
      03-20-2014 10:05 PM #14
      Nice, I would just recommend disconnecting the battery.
      How old would you be, if you didn't know how old you were?
      Alaskan Green build thread.
    15. Member
      Oct 1st, 2007
      2002 VW GTI 1.8L, 2007 New Beetle Convertible 2.5L
      12-13-2014 12:41 PM #15
      Quote Originally Posted by im_lower View Post
      Absolutely! Anything regarding airbags means a battery disconnect.
    16. n00b
      Dec 20th, 2014
      Leicester, UK
      VW Golf 1.9TDi Estate mkIV
      12-20-2014 06:24 PM #16
      Damn, I wish I'd read the bit about disconnecting the battery before unplugging the airbag Any suggestions as to how I can remove the dash light without taking it to a garage?
    17. Member Miller7204's Avatar
      Jul 25th, 2011
      Upstate New York
      2004 Jetta GLS 2.0L R.I.P. - 2002 Jetta GLS 2.0L
      12-20-2014 09:55 PM #17
      Quote Originally Posted by Smith1.9 View Post
      Find someone with VagCom to turn it off for you.
      Quote Originally Posted by boradie sucht View Post
      im running bbs rs, but thats just because im a boss
    18. n00b
      Dec 20th, 2014
      Leicester, UK
      12-24-2014 03:21 AM #18
      Quote Originally Posted by Miller7204 View Post
      I took the car in for a service yesterday, so got them to turn it off.
