Page 1 of 2 1 2 LastLast
Results 1 to 35 of 37
Thread: Brakes are rock hard and ABS/parking brake lights are on!
  1. Member ALLROAD VR's Avatar
    Jan 22nd, 2006
    Scarborough
    08-10-2009 08:56 PM #1
    Car in question is a '93 Corrado VR6. Haven't driven the car in 3-4 weeks and all of a sudden, the brakes are rock hard and hard to stop! The ABS lights are on and the parking brake lights stays on. Any ideas what it could be??
    Poortex.
  2. 08-10-2009 08:57 PM #2
    abs relay
    Up and Live >>> www.Herbys53.com <<< sick of the BS , check it out :thumb:
    860-798-5227 TEXT anytime
    Herbys53 VW/Audi Corral May 29th Lime Rock Park Ct.
    53Motorsports-Koni/APR/TT/Bilsteins/Oem+/Service:clap:
  3. Member ALLROAD VR's Avatar
    Jan 22nd, 2006
    Scarborough
    08-10-2009 09:17 PM #3
    Do you know what number it is on the fuse box?
    Poortex.
  4. 08-10-2009 09:30 PM #4
    check the abs ecu in the side panel under the dash by the driver side door.
  5. Member ALLROAD VR's Avatar
    Jan 22nd, 2006
    Scarborough
    08-11-2009 08:49 AM #5
    Poortex.
  6. 08-11-2009 11:15 AM #6
    I was in the same boat, freaking out thinking it was going to be crazy expensive. I let it sit for a while until I could dive into it & when that time came the battery was dead. When I went to charge the battery I noticed that a bolt for a wire was loose on the terminal. Tightened it up, brakes softened, lights off...danced jig.
    Good luck.
  7. Member ALLROAD VR's Avatar
    Jan 22nd, 2006
    Scarborough
    08-11-2009 07:55 PM #7
    Naw, still doing the same thing!
    Anyone know where the ABS relay is?
    Poortex.
  8. 08-11-2009 08:57 PM #8
    Behind the cluster marked 78 and 79 abs and pump relays
    can you blink out your codes and look them up?
  9. Member ALLROAD VR's Avatar
    Jan 22nd, 2006
    Scarborough
    08-13-2009 08:42 AM #9
    Thanks! Yeah, we blinked out the codes but it went on again.
    We'll check the relays, maybe that's the cause of the light coming on.
    Poortex.
  10. Member sal16v's Avatar
    Mar 15th, 2003
    02 GTI 337, 07 B7 S4, corrados gone and missed!!
    08-13-2009 09:06 AM #10
    Remove D/S kick panel and locate ABS computer! Once you find it, remove the 2 or 3 ten mm nuts holding it in, Then proceed to throw it in the trash! Best move you will ever make. No Light's, no abs trying to kill you Win Win!
    H,T,F,U.....
  11. 08-13-2009 11:39 AM #11
    Quote, originally posted by S4Bi-T »
    Did you write down the codes? They tell you exactly what is wrong unless it is like a dozen codes then it's just something unplugged. How many codes was it?
  12. Member ALLROAD VR's Avatar
    Jan 22nd, 2006
    Scarborough
    08-13-2009 10:15 PM #12
    Quote, originally posted by sal16v »
    Tried unplugging it, ABS light and brakes are still hard!
    Quote, originally posted by fredhogarth »
    Forgot to write down the codes, but those ABS relays are hard to pull out! I can't even get them out to re-seat them.
    Poortex.
  13. 08-14-2009 05:50 AM #13
    I had the same problem in my corrado and I was able to verify the problem. The brakes feel like they require a ton of force to work, I tracked the problem down to the ABS Pressure switch. This switch triggers one of the relays which drives the Brake Pump. If you have ever tried to change the brake fluid and not had the car on (ACC. only) you would notice that it takes 5x longer because the pump is not working. This Pressure switch in the wiring diagrams also goes to the ABS control module, which if it reads a high or low pressure will not activate the ABS and give a check ABS light. On my corrado, I mis-took this relay as another and could not get it out (it was stuck in there good), when I tried to use a tool to pry it out I shorted two of the pins, the (+) to the ABS Pressure switch pin and the brakes from then on required a HUGE amount of force to use. So I figured it was either I fried the relay or fried the switch, so I had a spare relay laying around and I replaced it. This however did not solve the problem, so I just jumpered the (85) & (86) pins on the relay completing the circut without the need for the trigger of the ABS Pressure Switch and it solved my problem. I then tracked down a new ABS Pressure switch and it solved my problem. This would be a good place to look for the source of your error.
  14. Member ALLROAD VR's Avatar
    Jan 22nd, 2006
    Scarborough
    08-14-2009 08:20 AM #14
    Yeah, the ABS pressure switch was my next guess...I heard they're expensive!
    Here's the codes that came up.
    Address 03: ABS Brakes
    Control Module Part Number: 535 907 379 F
    Component and/or Version: ABS/EDS TEVES 02
    Software Coding:
    Work Shop Code:
    4 Faults Found
    00285 - ABS Wheel Speed Sensor; Front Right (G45)
    35-00 - -
    00290 - ABS Wheel Speed Sensor; Rear Left (G46)
    04-00 - Mechanical Malfunction
    00287 - ABS Wheel Speed Sensor; Rear Right (G44)
    00599 - Plausibility of Pressure/Brake Light Switch
    Poortex.
  15. 08-14-2009 02:08 PM #15
    Yea I don't know if the ABS worked before this, those codes you gave would indicate that the ABS was non-operational before the brakes got heavy. The heavy brakes is because of the Pressure switch, however the ABS not working (my guess) is because of the speed sensors being bad. Or it could be that the last code (that is last), is the latest error. Which is the ABS/Brake Pressure Switch and if the ABS was working, it sometimes can error out and give a code, but next time you started the car it was working ok, but left the code in memory. Make sure you clear them and try reading the error codes again.
  16. 08-14-2009 06:21 PM #16
    Too much or too little brake fluid will also create the same symptoms.
  17. Member ALLROAD VR's Avatar
    Jan 22nd, 2006
    Scarborough
    08-18-2009 07:06 PM #17
    Brake fluid is on level.
    It seems like it's the pressure switch judging by the last code.
    Poortex.
  18. Member ALLROAD VR's Avatar
    Jan 22nd, 2006
    Scarborough
    08-24-2009 07:12 AM #18
    TTT.
    Poortex.
  19. 09-03-2009 10:21 AM #19
    this happened to my Corrado this morning. googled "corrado ABS relay" and found your thread. i was driving to work and after i exited the highway, i noticed my ABS light was on. brakes were fine until i reached my work and then the pedal was stiff requiring a lot of force on the pedal.
    where exactly are the ABS relays/fuses located? above the normal relay/fuse box?
  20. 09-03-2009 12:40 PM #20
    check out my car during lunch and found out that the connection for the small wires on the positive battery terminal was loose. tightened it up and brakes are back to normal. good luck with yours
  21. Member Eric D's Avatar
    Feb 16th, 1999
    Tragic Kingdom, CA
    1943 Flugkreisel, 1945 VRIL-7
    09-03-2009 01:26 PM #21
    I have a new pressure switch if you need it, they are pricey and I'll let it go cheap.
    The problem with these is that buried inside are 3 micro switches. The toggle mechanism breaks and the switch is stuck.
    The pressure switch controls the warning lights and also the pump.
    Its the lime green part in this pic (borrowed pic). Mine is new, but was threaded in to test the switch functions. Turned out my problem was a bad check valve in the pumps valve block.
    I want to point out that there was a service bulletin years ago for 93 Corrados and Passats.
    It stated the ABS warnings lights may be on due to a faulty ignition switch not returning from the start postion (terminal 50) to the run position (terminal 15).
    If the switch doesn't return to the run position, circuits controlled by terminal X (headlights, dash blower or ABS) will not function.
    If you don't have a Bentley, search the net for ATE TEVES ABS as used in your Corrado. Hopefully you find a site that show how the system works and how to troubleshoot it.
    Modified by Eric D at 9:14 AM 11-5-2009
    The original Dub and Dubber.
    Manche VWs sind einfach schneller als andere.
  22. Member sdezego's Avatar
    Apr 23rd, 2004
    Hurricane Central FL
    '90 Corrado | '62 Harley Panhead
    09-03-2009 02:11 PM #22
    Glad to see I am not the only one that shelled out high$ for this switch. Luckily it was truly the problem with mine. $110 is a steal if you want to keep the ABS.
    Build: Project sc2020
    My G60 now on MS3 | 4Cyl Torque Plate Rental | 02M Mounts
  23. 09-24-2009 11:05 AM #23
    Do you still have the pressure switch?
  24. Member
    Sep 16th, 2007
    2001 Audi TT 225Q
    09-24-2009 02:28 PM #24
    I dont know if you have the issue still, because I am too busy to read the whole post but I had this issue too. Brakes were hard as a rock and the brake light was on (ebrake light).
    It ended up being that when I disconnected my battery I failed to reattach the power wire for the abs pump to the terminal upon reconnecting the battery. Check this first
  25. Member Eric D's Avatar
    Feb 16th, 1999
    Tragic Kingdom, CA
    09-24-2009 02:29 PM #25
    Yes I do have.
    Wow low post count. Have you been lurking for awhile?
  26. 09-25-2009 08:03 AM #26
    No, I haven't been lurking. I just bought a '90 G60 a few days ago and started "fixing all the problems" and I thought I should start with the brakes first.
  27. 09-28-2009 05:34 PM #27
    Found the part locally, thanks anyway.
  28. Member Eric D's Avatar
    Feb 16th, 1999
    Tragic Kingdom, CA
    09-28-2009 10:42 PM #28
    Pressure switch I mentioned earlier.
    Genuine ATE brand, VW part.
  29. Member
    Sep 16th, 2007
    2001 Audi TT 225Q
    09-28-2009 11:02 PM #29
    trust this guy ^
  30. Member Eric D's Avatar
    Feb 16th, 1999
    Tragic Kingdom, CA
    09-28-2009 11:22 PM #30
    Quote, originally posted by corradojohnt »
    trust this guy ^
    Thank you!
  31. Member Moneybags's Avatar
    Apr 21st, 2009
    'Nooga
    12-04-2009 05:35 PM #31
    Still have this switch?
    93 SLC 24v S&P Original
  32. 12-07-2009 04:13 PM #32
    Hi,im new to this forum and i wondered if anyone can shed some light on a problem i have,to save a bit of time,i will just copy and paste the text i posted on another forum!
    Has anyone every had any problems with abs on a mk2 G60? This is what i got! My rear pads were on their way out a while back so i took the car out of the garage to bring it to work and put new discs and pads on the back.I drove about 300yds from the the garage door til i had to brake for a stop sign,now this car doesnt get used often,infact it was the 1st time for a couple of mths that it came out.When i braked for the stop sign i instantly noticed the brakes weren`t what they usually were and my instinct told me to just press a bit harded on the brake pedal.Straight away from that point the pedal went rock hard and the ABS light came on,and has never gone off since.i took it to our VW dealer,and a local vW `specialist` and it turns out i know more about golfs than the pair of them.The `head man` at the dealers was even in there looking for the servo and m/cylinder and couldnt believe it didnt have one!Anyway,i set too and had a bit of an investigation myself,i took out the rear pads and pumped the pedal,only to find that there isnt any braking power whatsoever to the rear calipers!Although when u drive the car and u hit the pedal the car stops(the brakes are really crap and the abs light is on).Does anyone know what the problem could be?Then i found another problem.I thought it may be the rear sensors,maybe some metal shavings had got to the sensor magnet and was playing up,so i started to take out the sensors,only to find they were siezed in the hubs.By this point im getting really annoyed so took off the rear discs and hammeded them out.I realised i would never get new ones in so dismantled the whole rear end and took out the axle.Stripped it,blasted it and painted the thing.Ive been building it up with brand new everything inc stainless nuts/bolts/washers for the past couple of weeks.Everything is back together,and ready for the new abs sensors(pt number191 927 807 B).So off i go to the dealers,gave them the number and guess what,obsolete without a replacement!!! Ive searched everywhere,all i can find is sensors with the same number but with a `D` on the end instead of `B`.Does anyone know what i can do for-
    a, Trying to find out what originally caused the brake pedal to go solid and the abs light to come on.
    b,Trying to get some new rear abs sensors.Would 191 927 807 D work???
  33. 10-09-2012 06:06 PM #33
    hey guys sorry for bringing up an old post but im having the same issues.. i checked the battery wire, i checked the fluid level, i checked the kick plate connection on the driver side, and i pulled the fuzes to see what they look like. they where a PITA to get out with big hands... anyway the fuze labeled "78" has a black mark around the " large SILVER" prong, and the other relay "79" seems loose in its housing... im hoping these can replaced quickly ( if stores carry them) and it solves the problem, if not i guess its that greenish gold sensor??
  34. Member IanJ3VR6's Avatar
    Apr 2nd, 2003
    Burke, Va
    07 GTI, 92 SLC, 06 RAV4
    10-09-2012 07:21 PM #34
    I am having the same issue. Both warning lamps are on yet I am throwing no ABS codes, fluid level is correct, wheel sensors and all relays/fuses are new. I'm just going to swap out my old ABS block with a known working unit and see what I get.
  35. 10-11-2012 11:38 PM #35
    TTT
