Quote, originally posted by sec914 » just picked up a 86 cabriolet with a trans that is puking fluid out of the vent port. happened after the previous owner changed the fluid and cleaned the screen any ideas? original problem was leaking pan gasket. WHen the seals between the torque converter section and the diff section fail it can send the converter charge oil into the diff overfilling it.
VCDS Hex-Can, if you need help.
