VWVortex.com - K-Jet turbo setup
    Page 2 of 15 FirstFirst 12345612 ... LastLast
    Results 26 to 50 of 353
    Thread: K-Jet turbo setup
    1. Member John Milner's Avatar
      Jul 20th, 2005
      The Land Down Under
      76 Swallowtail K-Jet turbo
      09-24-2009 06:31 AM #26
      Well I've been flatout here lately, with car shows/event's & other general service stuff, but a big shipment has finally come in & everything has been going full steam ahead.
      Heres the latest shipment of part's. Mainly the main part's I've been waiting on to get things going
      I decided to get a Tial BOV with V-Band, as it matchs a Tial Wastegate I've got here for another engine build later on
      Internal Wastegate assembly which transfers into a 3" V-Band
      BIG difference to the standard Saab exhaust/wastegate assembly & the "whopping" great big 2" dump pipe! Very restrictive too!
      The all important 8V cast exhaust manifold
      Various gasket's, adapters & oil fittings
      Some new brakes, as the old ones are, well old & warped!
      ATE POwer disc's front & rear. I got some 280mm for the big wheels & some standard 239mm Ive I ever decide to put smaller wheel's on to drag it
      Yeah, well I'm not surprised, drivin' a field car!
      K-Jet Turbo build
    2. Member John Milner's Avatar
      Jul 20th, 2005
      The Land Down Under
      09-24-2009 06:45 AM #27
      So with nearly all the major parts in hand, it was time to get thing's moving along as fast as possible
      Before Engine bay shots
      Didn't take too long to strip it all down & start mocking everything up & then came across some trouble! All this kit is for a LHD car! DOH!
      There will be a few mod's here & there to get everything to fit O.K.!
      But after scrounging through some various nut's, bolt & studs & even having to make different bolt's with the help of Dom, I finally got there
      Fitted up the ATP 3" wastegate V-Band adapter in the process
      I painted all the cast exhaust manifold, turbo housing in VHT High temp Matt Black . Awesome stuff & the rest of the dump pipe will get the same treatment
      It's a bloody tight fit! It's less than 5mm off resting on the steering shaft boot! Ah well. The old extractor's rested on it anyway!
      Assembly mocked up on the bench with a few more part's fitted
      Mocking up a new Wastegate actuator.
      I can see why company's such as Callaway etc all ran external WG. There is bugger all room down there for them. But I've come this far not to turn around, so I'll stick at it & make it work
      Then the die grinder had to be broken out again due to clearance issues with the G60 intake!
      This took quiet some time & alot of fitting & refitting to get it right
      K-Jet Turbo build
    3. Member John Milner's Avatar
      Jul 20th, 2005
      The Land Down Under
      09-24-2009 07:04 AM #28
      With some of the stuff off getting finished welded & a few other part's I'm waiting on, I decided to tackle some other part's incl. modifying the dizzy.
      Early "twin port" vac canister
      Stock GTI vac advance canister
      To enable more boost retard, I drilled out the vac pot stop
      All mounted up after drilling some new mounting holes
      I also fitted a set of MK4 GTI 20vt spark plugs too. This should finish off the ignition system with only a couple of minor timing adjustments during tuning
      I also decided to have another play around with the Audi Warm Up reg after some long thinking sessions.
      The more I played around with it, the more I learned about it & decided to apply the boost pressure to the other chamber of the warm up (not the barbed fitting side) & put it to the test. I wound down the compressore to 10psi & put it to the test. It worked spot on & I played around with different pressure setting's & compared them to some old porsche K-Jet turbo spec's & were right on the money.
      I no longer need the one-way valve my friend made for me.
      During my thinking stage, I also wanted to try & add more fuel enrichment for higher boost level's, but didn't want to go down the programmable extra injector(s), as this basically defeats the purpose of building a K-Jet turbo. If you've got one or two extra injectors that can be programmed the way you want to supply the fuel, you might as well go to a full standalone ECU like Microtech, Autronic etc.
      So I've had a flat plate of alloy welded to the face of the intake plenum & have drilled & tapped holes for an extra 2 cold start valves run off an adjustable hobbs switch.
      Because the G60 intake doesn't have a cold start valve, I can put them where I want. The stock GTI spot isn't efficient enough to mix up the right mixture under boost anyway, as you've got say 10psi blowing right at the face of the valve, which will just blow the fuel right up against the No1 plenum wall & force it all into cyl. 1, causing the other cyl's to run lean.
      So I've placed one of them between cyl 1 & 2, & the other between cyl 3 & 4. Hopefully setup like this, it should mix it up nice & supply an even amount of fuel to all cyl's.
      Even if this setup runs rich as buggery on boost. It's better than running lean! Running rich can also drown out the piston melting pinging! We'll see how it goes. If it does run on the rich side under boost, I'll screw some more boost into it & see what happens.
      My friend is also good with setting up water/meth injection kits as well, so theres another option too.
      I plan on starting off tuning on Wastegate spring pressure which is roughly 7psi & work my way up.
      In the event of it melting a piston, I've got some 20vt spare piston's & rods, I'll throw in along with a G60 metal head gasket, which should be more than enough for the little 8v
      I'll put up some pic's when I get the intake back which should be very soon.
      Modified by Mk1-20V at 10:36 PM 9-24-2009
      Modified by Mk1-20V at 10:47 PM 9-24-2009
      Modified by Mk1-20V at 10:52 PM 9-24-2009
    4. 09-24-2009 05:00 PM #29
      Quote »
      http://i287.photobucket.com/albums/ll148/golfworx/IMGP3094.jpg
      I love my ATP Vband wastegate... curious... what is the red stuff? rtv?
      my oil stain is bigger than yours
      the Race Dasher Project is now on Facebook, 180hp and 188tq... while miss-firing BADLY
      the Dasher Owners Group is now on Facebook
    5. Member John Milner's Avatar
      Jul 20th, 2005
      The Land Down Under
      09-24-2009 07:46 PM #30
      Quote, originally posted by Southcross »
      Spot on.
      It's Permatex Ultra Copper gasket goo.
      The factory wastegate housing didn't have a gasket as it places the wastegate flap too foo away from the exhaust housing & can cause it to leak
      More pics
      Various silicone hoses of different sizes & shapes. (What ever doesn't get used will get put away for the next turbo build) I't shard to judge what you might need when building these sort's of things without having most of the stuff already fitted.
      Various mild steel mandrel's & piping.
      A couple of my friend's came down & built the dump pipe while I was at work & also installed the oxy. sensor bung. They done an awesome job too smoothing off the welds & making it flow nice & smooth. They'll also be helping with the intercooler piping.
      I'll drive it to my friend's exhaust place like this & he'll rig up the rest of the exhaust. It will just be a 2.5" with a resonator & turbo rear muffler. Don't want it too loud as I travel 200km a day in it. So no drone for me!
      In case your all wondering, this is my everyday car & travel 700+km a week in it, not a weekend warrior.
      Hobb's switch & Mk4 GTI 20vt (AGU engine code) spark plugs
      A good friend of mine also gave me this.
      A factory 1977 Mk1 GLS Radio.
      Modified by Mk1-20V at 10:48 AM 9-25-2009
      Modified by Mk1-20V at 10:49 AM 9-25-2009
      K-Jet Turbo build
    6. 09-24-2009 11:24 PM #31
      Quote, originally posted by Mk1-20V »
      Spot on.
      uhm.... every 5-bolt turbo I have seen has been metal to metal, I don't run any kind of seal and I haven't ever had any kind of exhaust leak. I give the RTV one full heat cycle
    7. 09-25-2009 01:20 AM #32
      who can weld cast iron to mild steel? i never have but ive done plenty of aluminum
    8. Member John Milner's Avatar
      Jul 20th, 2005
      The Land Down Under
      09-25-2009 08:36 AM #33
      Ah well. I'll have to see how it goes. If it does melt it/spit it out, it's me that has to fix it.
      Quote, originally posted by bunnyhopin »
      You can weld cast to mild steel, but you have to heat the cast up first. My friend has done it before.
      K-Jet Turbo build
    9. Member John Milner's Avatar
      Jul 20th, 2005
      The Land Down Under
      09-25-2009 08:37 AM #34
      Well, I finally got my intake manifold & intercooler back!
      These were the last piece's in the puzzle from stopping my progress.
      Now on with some more work
      My friends tackled the dump pipe, so it was my turn to do the rest of the pipe work. Good fun!
      Intake with it's modded twin aux. injector (cold start valves) plate
      Hopefully it should work ok. If not, the weber throttle body has another mounting for a 3rd cold start valve.
      Intercooler with all it's mounting brackets on
      Mounted up the intercooler & then installed the radiator to start mocking up all the piping
      There is still alittle bit of room between the intercooler & radiator. They aren't hard up against each other.
      I also mounted it using scrivet's (pop rivet nut's) Work awesome!
      Various silicone hose joiner slugs
      Had to get the turbo intake pipe stretched to fit snugly in the volvo intake boot.
      Turbo intake pipe all done & mocked up. I'll get some more pics of this when it's back out of the car along with all the pipes
      Then started mocking up the intercooler to throttle body piping
      Finished pipe
      Then mocked up the Tial BOV mounting position & then the Hobb's switch as well
      Then started in the turbo outlet piping. Sorry but I forgot to get a pic of this out of the car
      Working out intercooler piping position
      I wanted both pipes to run parallel with each other & make it a clean fitment.
      Everything appears to clear everything, but only a test drive & time will tell. Hopefully I'll be fine with engine movement
      Progress will slow down this weekend, as I've got a 2 day training course over the weekend, but I'll try & get in some work during the night's & back on it on Mon.
      K-Jet Turbo build
    10. 09-25-2009 11:21 AM #35
      Dual (or tripple) cold start valves???????????? I'm super lost
      well... I don't know exactly what it will do... if its copper based it might stand up to the temps *shrug*
      Just be prepared that it might burn up and turn into a giant cloud of nasty smoke the first time the turbo gets hot. I don't know if you have a CAT or anything right down stream from it, but burning chunks may wind up going through your exhaust
      its a very interesting build... and way overdone on the photos, way to go!
    11. Member DaBeeterEater's Avatar
      Aug 17th, 2007
      ocala fl
      81 vr rocco, 99 turbo f150
      09-25-2009 12:33 PM #36
      dam nice build man looks great
    12. Member John Milner's Avatar
      Jul 20th, 2005
      The Land Down Under
      09-25-2009 04:46 PM #37
      I'm starting off with twin cold start valves but as I said, if its not enough, there is another mounting point for a 3rd cold start valve in the weber throttle body.
      This is a MY76, so I don't have to run a CAT. or any kind of pollution gear here in OZ
      Sorry about all the pics. I'm just trying to help people see what goes into a build project like this or any kind of build, instead of a before & after shot & alot of kept secrets.
      If it's too many, I'll cut it right back & just give you a before & after shot & keep all the little helpful bit's of info to myself.
      K-Jet Turbo build
    13. 09-25-2009 05:26 PM #38
      is that for fuel enrichment under boost??
    14. Member John Milner's Avatar
      Jul 20th, 2005
      The Land Down Under
      09-26-2009 01:22 AM #39
      Yeah. It will be set off by an adjustable Hobb's Switch.
      I'll set it at 7psi initially & see how it all goes with the tune. I may have to bring it in sooner, or may leave it later. But I just need a starting point.
      K-Jet Turbo build
    15. Member John Milner's Avatar
      Jul 20th, 2005
      The Land Down Under
      09-27-2009 07:04 AM #40
      Well this weekend was alittle disappointing & not really happy with the progress. Crappy weather put a stop to painting & a so called dash -4 fitting decided to strip an oil supply adapter! Mmmmmmm.
      But I did get some stuff done.
      I finished welding all the pipe work, smooth & blended everything which took quite some time. Especially around the BOV. But the extra effort was worth it
      All the piping ready for paint tomorrow
      Dropped the sump & fitting the oil drain fitting
      I also decided to fit a VW Motorsport Windage tray I've had here for a long time. What better time to use it than now.
      Made up the oil return line & oil supply line For interest sake the supply is dash -4 & return is dash -10
      I also got time to modify the wastegate mounting bracket, due to how the turbo housing's are clocked, the original bracket jammed the wastegate pot against the intake manifold. I also had to mod the swing/push rod end too.
      So out came some scrap metal, the hacksaw, linisher & welder.
      My welds are slowly getting better.
      I'll be ordering some more part's tomorrow which broke, painting the piping & hopefully start reassembly tomorrow night!
      K-Jet Turbo build
    16. Member John Milner's Avatar
      Jul 20th, 2005
      The Land Down Under
      09-28-2009 05:20 AM #41
      Got another good day in of work today.
      Decided to set up a makeshift booth in the shed as it was crap weather all day again & line it with old massive blanket's & got the patio heater going! Crap I know, but it all didn't turn out half bad.
      Managed to etch & spray all component's & then fit everything up.
      Just waiting on an oil supply fitting & then onto the wiring which shouldn't take all that long & then brake booster pipe, exhaust & aux. injector fuel line
      On with the pics. Very pleased with the final product. Almost look's factory apart from the Tial BOV.
      K-Jet Turbo build
    17. Member John Milner's Avatar
      Jul 20th, 2005
      The Land Down Under
      09-28-2009 08:43 AM #42
      Before & after shot's.
      Engine look's alittle cleaner now with all the aux. air valve supply hoses deleted & the Warm up reg hoses/pressure gauge tucked away too.
      K-Jet Turbo build
    18. Member John Milner's Avatar
      Jul 20th, 2005
      The Land Down Under
      09-29-2009 09:21 AM #43
      Got a chance when I got home to wire up the A/F meter, calibrate it & fit the boost gauge. These will only be fitted temporarily for tuning. Once I'm happy with it all, it will all get removed & back to stock interior.
      Anyway I can safely say it runs!
      Cranked over on the 2nd revolution & fired into life. Although alittle noisey & once all the gasket goo & exhaust paint had settled, it idled perfectly as before at 1000rpm.
      I'll get a chance tomorrow arvo to drive it & see how it all goes.
      K-Jet Turbo build
    19. Member Holden McNeil's Avatar
      Jul 26th, 2004
      Morris County, NJ
      2013 Fiat 500 Turbo
      09-29-2009 10:40 AM #44
      Fantastic job!!! I love all the hands-on fab work you did!
      Something about this photo makes me want to turbocharge a lawnmower
    20. Member John Milner's Avatar
      Jul 20th, 2005
      The Land Down Under
      09-30-2009 08:26 AM #45
      Well with the car still without an exhaust, test driving has been kept to a minimum.
      I did get a chance to drive it though & initially boost was kept as 5psi. The turbo isn't even working!
      The A/F ratio is spot on at idle & cruise. approx 14.6-14.9:1, but under boost it richen's upto low 10's:1! That's without the Extra injectors even hooked up!
      But after a few goes & alittle bit of playing around, I wound it up to 10-12psi & the surge starts to come in. Its still running rich as under boost, so there is sill some playing around to do yet with adjustment's etc.
      I'll get more tuning in, once the exhaust is fitted which should be tomorrow.
      But it's slowly getting there.
      No leak's, no fires & everything is smooth.
      K-Jet Turbo build
    21. Member LA7VJetta's Avatar
      Jul 21st, 2009
      1985 Mercedes 190D
      09-30-2009 08:31 AM #46
      thats surprising, good to know that i wont really need do any manifold modifying when i get to turboing mine
    22. Member John Milner's Avatar
      Jul 20th, 2005
      The Land Down Under
      09-30-2009 08:50 AM #47
      Quote, originally posted by nickzom »
      You may still have to clearance the intake & exhaust manifolds to fit flush.
      K-Jet Turbo build
    23. Member DaBeeterEater's Avatar
      Aug 17th, 2007
      ocala fl
      09-30-2009 08:51 AM #48
      a/f in the 10's, man crank that boost up lol your good to go lol, crank that baby up t0 20 lol
    24. Member John Milner's Avatar
      Jul 20th, 2005
      The Land Down Under
      09-30-2009 09:01 AM #49
      Quote, originally posted by DaBeeterEater »
      Haha.
      Yeah tried that already. spiked at over 15psi & popped & farted!
      It's looks like it's going to be a juggling act of boost & timing.
      I was surprised about the A/F. I thought it would lean out. That's why I installed the extra injectors. Haven't even hooked then up yet!
      K-Jet Turbo build
    25. Member DaBeeterEater's Avatar
      Aug 17th, 2007
      ocala fl
      09-30-2009 10:16 AM #50
      what plugs you have in there and what are they gapped at??
      that could be why its popping,
      this is not much of a comparrison but my 600 hp car i run iridium plugs in it and we run it rich like 10.2's in boost to keep it safe and it does not brake up, i was very very supprised at the iridium plugs
