Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 36 to 70 of 108
Thread: BFI - Motor Mounts - Polyurethane and Delrin MK3 and Rado VR6
  1. 07-09-2010 10:43 AM #36
    Quote Originally Posted by dubbinmk2 View Post
    how much for vr6 mk3 mounts? got like stage 3 mounts? best of the best? i could care less about ride quality i'm going vrt in 2 months and i need something to lay down the power to my LSD tranny
    Best of the best, huh?.... Then you want these: BFI Stage 2 Delrin Complete Motor Mount Kit
  2. 08-28-2010 07:42 PM #38
    i had a question. On my z28 and other muscle cars, all of the motor and tranny mounts available had a metal linkage inside so that in the event of breakage, the linkage would catch and the mount would at least keep your motor/trans from going anywhere. Is there a similar design available for a mk4 12v VR6? I'd like to replace my mounts with poly and I was just curious.
    Thanks
  3. 08-30-2010 12:48 PM #39
    Quote Originally Posted by aestheticcataclysm View Post
    ...Is there a similar design available for a mk4 12v VR6? I'd like to replace my mounts with poly and I was just curious.
    Thanks
    Though we have little basis for comparison to American Muscle, we believe that even during/after a catastrophic failure (which is highly unlikely, mind you), that a VW drivetrain will remain within the engine compartment and not need any sort of supplemental linkage tethering it to the vehicle. Solid German engineering is all you really need in this case - our BFI Engine Mounts are no exception and will perform as well or better under similar circumstances
  4. Member euro2nur's Avatar
    Apr 23rd, 2006
    PINES,FL /QUEENS,NY
    mk3 golf(sold),mk3 vr6 Gti(sold),mk3 vr6 Jetta(sold)mk6 GLI
    10-01-2010 12:58 AM #40
    any chance of these mounts going on sale soon
    instagram SurGeInMIA
  5. 10-05-2010 12:19 PM #41
    Quote Originally Posted by euro2nur View Post
    Sorry not at the moment.
  6. Member simonize25's Avatar
    Oct 26th, 2008
    The Fort, IN
    63 Crew Cab, 84 GTI, 91 B3 Wagon, 97 GLX
    10-23-2010 03:41 PM #42
    I had purchased the stealth kit for my vr. It is my daily driver with some mild mods, (cam, chip, intake, exhaust, 11:1 cr, P&P) i wanted a nice comfortable ride. They were nice for a while but i still had some engine movement. Just my luck my buddy had just installed the Derlin kit on his ABA and was killing him self for doing so. We ended up swaping rear mounts, his Derlin for my stealth, and i have never been happier. it has almost no vibration and under accel the engine doesnt move at all.
    Killer product
    Life's a joke... Be the punchline
    63 Crew Cab Rat Rod Build
    http://forums.vwvortex.com/showthrea...7#post63671387
  7. Junior Member
    Feb 16th, 2009
    Danevang
    11-01-2010 06:02 AM #43
    Are you still only shipping to the US?
  8. 11-01-2010 11:28 AM #44
    Quote Originally Posted by Lindahl View Post
    That is correct. We do not provide any shipping outside of the U.S. at the moment.
  9. Member Wompa's Avatar
    Oct 30th, 2009
    Sweden
    Corrado VR6, Golf MK2 Syncro
    12-10-2010 01:35 PM #45
    Are you thinking about starting to send international?
    I would love a kit!!!!
  10. Member Titan VR6's Avatar
    Nov 18th, 2009
    MN
    98 GTI and a 2012 Mazda 2 RIP vovlo 240
    01-07-2011 05:49 PM #46
    OMG, I am so psyched, just got my stage 1 kit and super excited. cant wait till the weekend. Only downfall about this is that I dont have a garage, I live in Minnesota and the high temp for the weekend is 10F with out the windchill factor. SO basically, I will be doing this in 0F weather... nothing is gonna stop me from doing this. not even the cold.
    P.S, is the trany mount hard to do?? I have never done this before.
  11. 01-10-2011 11:05 AM #47
    Quote Originally Posted by Titan VR6 View Post
    The installation guide can be found here: MK3 Motor Mounts
    Best of luck in those frigid conditions!
  12. n00b bamartin03's Avatar
    Jan 24th, 2011
    Davenport
    95 jetta gls, 01 chevy cavalier
    01-26-2011 01:32 AM #48
    i've had the stage1 kit for about a year on my 2.0 and it rattles everything to pieces (literally having problems with the intake bolts coming out). i do plan on using it for the vr6 when that goes in. the problem is, the front mount upper bolt ripped out ... i also noticed the kit never had washers?i think that may be the heavy vibration problems. i'm not sure what happened, but expect me to order another one soon as well as lots of goodies for the vr6
    95 2.slow gls jetta... obd2 vr6t swap in the works
  13. Member TDI Driver's Avatar
    Jan 17th, 2006
    Harford County, Maryland
    1993 Corrado SLC, 2009 CC 2.0T Sport
    02-11-2011 10:45 AM #49
    Just installed a set of the .5 mounts in my 'rado this weekend. They definitely improved the overall feel of the car. Decreased engine movement a lot compared to the stock mounts, and it shifts much smoother now.
  14. Member Titan VR6's Avatar
    Nov 18th, 2009
    MN
    02-19-2011 03:49 AM #50
    how bad of a vibration does the stage 1 give. My car shakes super bad, is that normal
    ALSO, should I remove the rubber cap that fits over the front mount? other guys in their vr's said that removing the cap made a lot of difference
  15. 02-21-2011 11:29 AM #51
    There should be a significant amount of increased vibration with the stage 1 mounts compared to the factory mounts you had in there previously. You can try removing the cap but to our knowledge it should not make much of a difference if at all since it's actually a heat shield.
  16. Member Titan VR6's Avatar
    Nov 18th, 2009
    MN
    02-21-2011 06:25 PM #52
    sweet, well i just though i would check 1st. its not like i can drive my car anyway, its leaking coolant and since she is sitting low and there is 18 inches of snow since last night i cant do jack.
  17. Junior Member VR6(:'s Avatar
    Jan 11th, 2011
    Kent/Federal way
    (1996 VW GTI)
    02-22-2011 03:49 PM #53
    Just ordered my .5 mounts...Cant wait to get my f*ckin oil pan from dragging on the ground!!
  18. Junior Member VR6(:'s Avatar
    Jan 11th, 2011
    Kent/Federal way
    (1996 VW GTI)
    03-02-2011 12:43 AM #54
    Quote Originally Posted by VR6(: View Post
    I got them! But no stickers lol
  19. Member 95vrsixjetta's Avatar
    Jul 7th, 2010
    CT
    95 jetta vr6, 97 2.0 golf (sold)
    03-03-2011 02:54 AM #55
    Thinking about getting the stage 1 mounts...
    MOAR LOW
    VRSociety #292
  20. Member
    Oct 18th, 2001
    CT
    '90 Corrado vr
    03-12-2011 03:43 AM #56
    Just ordered full stg2 kit
  21. 04-08-2011 10:36 AM #57
    Quote Originally Posted by Nuzzi View Post
    Thanks for the order! I hope you enjoy
  22. Member Titan VR6's Avatar
    Nov 18th, 2009
    MN
    04-12-2011 07:46 PM #58
    the stage one mounts are amazing. they are a bit stiff at 1st but I've put on about 200 miles so far and they seem to be breaking in slowly. The ride quality is a bit scary at 1st but Ive gotten use to the vibrations and after a while the car seem to drive like it was stock.
    you can really feel the mounts working when you open her up on the HWY.
    I am very happy with the mounts!
    thanks BFI!!!!!!
    Just one more question guys, should i torque the mount nuts again after about 500 miles or am i good to go. ?
  23. Member
    Aug 11th, 2010
    SoCally
    97 Jetta GLX
    04-12-2011 08:48 PM #59
    stage 2's are going in this weekend ! cant wait. I've ridden in a stage 1 vrt and there are no ridiculous vibrations whatsoever. though the mounts have been broken in months ago. idk what's wrong with everyonelse's stage 1
  24. Member Titan VR6's Avatar
    Nov 18th, 2009
    MN
    04-12-2011 11:07 PM #60
    nothing wrong with the mounts man. It is just a little disturbing/ scary at 1st when you drive it for the 1st time because the car just feels different than what you were use too before the upgrade.
    lots of new noises and rattles.
  25. 04-13-2011 10:02 AM #61
    thanks BFI!!!!!!
    It definitely wouldn't hurt to check the torque on the nuts after the break in period but we don't deem it necessary. Thanks for the feedback!
  26. 05-05-2011 06:11 AM #62
    I've got a Stage 1 front engine mount on my VRT.
    I’m a bit concerned about the bottom bolt as I seem to be getting some engine lift under power. I guess it may be the threads inside the cross member letting go?
    Is it possible for me to use a single long bolt’n’nut to hold the top and bottom mounts together securely?
    M10 x1.5?
  27. 05-13-2011 10:52 AM #63
    Quote Originally Posted by Poll250 View Post
    M10 x1.5?
    Are the rest of your mounts upgraded as well? You should also double check the torque on the bolt and feel free to use loctite if you feel necessary.
  28. 07-31-2011 09:22 PM #64
    Shame ur not shipping overseas...
  29. 08-02-2011 10:25 AM #65
    Quote Originally Posted by tymoteo View Post
    Unfortunately we do not offer shipping internationally but we have dealers that do. Please refer to our list of dealers here: http://blackforestindustries.com/blog/dealers/ You might also want to try contacting http://www.usrallyteam.com/.
  30. 08-02-2011 03:17 PM #66
    Cheers for that!
  31. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    08-26-2011 10:27 AM #67
  32. Member MikeWire's Avatar
    Oct 20th, 2003
    Montana
    Air and water
    08-26-2011 01:07 PM #68
    Hey guys, I went to buy a stage 1 dogbone bushing kit for my MKIV VR6 and a snub mount for my Audi Avant B6, and in checkout I see that shipping is over $17 to ship to 59044. I'm in the lower 48, is there an option to ship USPS? I think both those item could fit in a flat rate $5 box...
    Love the product, but man, I don't want to get beat up on shipping costs for two very small items.
    -Mike | BigSkyEuro
    2003 A4 1.8TQT Atlas Avant | REVO 2 | Podi P1 Stepper
    1980 VW Lago Caddy 1.8 JH Hybrid swap
    1972 Bay Window 9 Passenger Deluxe Transporter w/ 2.0L F.I. VWAC
  33. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    08-26-2011 01:31 PM #69
    Mike,
    Currently, we only ship with UPS. Our website is directly linked with UPS which is how the site is able to provide a shipping amount during checkout. As a supplement, all of our packages go out fully insured when shipped via UPS ground.
    As well, shipping and freight costs can be more depending on destination. For example, if you live an excessive distance from the nearest UPS hub, their system recognizes this and raises quote costs accordingly to accommodate the distance. This may have been the case with your order.
  34. Member MikeWire's Avatar
    Oct 20th, 2003
    Montana
    Air and water
    08-26-2011 02:05 PM #70
    Thanks Pete, I appreciate the reply. I suppose the real answer is tough sh*t for me, and I need to pay to play, and it's just a matter of a few bucks. But I don't live off the beaten path...there's a big UPS distro shop here in town, and anything under $100 is automatically insured with no additional cost.
    I'm not usually a big proponent of using USPS, but they do pick up and deliver 6 days a week, plus have lower costs for standard and flat rate items. I don't control anything with BFI, but you should consider diversifying your shipping methods to include another carrier, or at the minimum negotiate with UPS for lower rates based on volume or carrier exclusivity (single carrier company). Especially because your business plan and income model is direct manufacturing, with online based sales and direct shipping to all your customers.
    If UPS decided to go on strike again, what's your continuity plan? (I don't need an answer, it's a hypothetical)
    Anyway, when I get sick of hearing my motors clunk around, I'll pony up, because BFI truly makes great products. Till then, at least consider my suggestion. Thanks.
    -Mike | BigSkyEuro
