VWVortex.com - Help with Lincoln LS V8 Overheating Problem...
    The Car Lounge
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 43
    Thread: Help with Lincoln LS V8 Overheating Problem...
    1. Member Jetty!'s Avatar
      May 9th, 2006
      2007 VW GLI, 2004 Honda S2000
      08-19-2009 09:59 AM #1
      My mom's Lincoln LS V8 tends to overheat in any sort of stop/go traffic when it's hot outside. This has been happening since last summer but when the car gets moving or onto the highway, it comes back down to normal temperature. Luckily, she hasn't blown a headgasket or cracked the block yet.
      The thing is, the fan kicks in at idle, and it seems a lot of people blame the hydraulic fan unit (which was replaced with an electric unit in 03), but the fan does kick in when sitting.
      Also, from doing some quick google searches, it seems to happen to A LOT of LS owners, and no one really knows the common culprit (temp sensor, thermostat, air in the lines, or the fan unit) are all listed as a possibility. The fan unit is about $400 so we don't want to throw that kind of money at something if it's not going to fix it. Also, the V6 and V8 have the same radiator/fan apparently.
      Looking for some collective help here. Thanks in advance.
    2. Geriatric Member ByronLLN's Avatar
      Jul 29th, 2004
      Cleveland, OH
      '16 FiST, '90 Miata
      08-19-2009 10:05 AM #2
      Has the cooling system ever been flushed? Grab some appropriate antifreeze, a few gallons of distilled water, a couple good-sized catch buckets and a six pack for the downtime and give it a good purge. Has it been unusually hot these last couple summers where you are? It could be that the car is running a coolant mixture that isn't ideal for your climate.
    3. Member JTinFocus's Avatar
      Jul 14th, 2008
      2014 Focus
      08-19-2009 10:09 AM #3
      Make sure the cooling system is properly burped. I had a problem with that after picking mine up from a sway bar/ps rack replacement. Aside from that, ask over at http://lincolnvscadillac.com/. Lately it's been kind of like the MKIV forum here but there are still a few helpful individuals left there.
      Quote Originally Posted by Timothy Leary
      The universe is an intelligence test.
    4. Member Jetty!'s Avatar
      May 9th, 2006
      08-19-2009 10:10 AM #4
      Quote, originally posted by PassSedanGLX »
      Not sure. This is what happens when I let my mom take care of her own preventive maintenance. She thinks she has but I don't see a document. It's a tight fit in that engine bay... how do I go about finding the drain?
    5. Geriatric Member ByronLLN's Avatar
      Jul 29th, 2004
      Cleveland, OH
      '16 FiST, '90 Miata
      08-19-2009 10:14 AM #5
      Quote, originally posted by Jetty! »
      Should be smack dab on the center of the radiator. If it's unreachable, you could also pop the hoseclamp off the lower radiator hose and drain it that way. Just be sure to wear eye protection as that mess will splash off of everything and find its way into your face.
      As mentioned above, "burping" the system would be a good first step before you go for a full flush. There are lots of how-tos on this if you google it.
    6. Member TurboWraith's Avatar
      Sep 4th, 2004
      IL
      '13 Focus
      08-19-2009 10:16 AM #6
      Lower radiator hose, remove it.
      I would also try cleaning the radiator itself. Lots of bug guts and rocks can reduce the radiators performance. It would seem to make sense that at highway speeds it isnt a problem as there is more than enough air passing over the core, but at low speeds the fan cannot pull enough air to make up for some blockage.
    7. Senior Member patrikman's Avatar
      May 10th, 2008
      44.5 North, 88 West
      EJ251, EJ255, EZ30D(R)
      08-19-2009 10:16 AM #7
      x2 on the flush and fill. not sure where there thermostat is but, take a look at that. there might be a chunk stuck in there blocking flow and movement. a new radiator cap never hurts either.
      Igor Natan Segala...that beautiful bastard. I made out with him one time behind a Red Lobster in Mookala, Wisconsin - on a bet. Little did he know that the simple kiss and $7.48 would lead to life-changing consequences. That was before the war, before this all happened. (stares out over the nuclear wasteland)
      Support Your Local Homebrewery
    8. Member Jetty!'s Avatar
      May 9th, 2006
      08-19-2009 10:18 AM #8
      So basically you're supposed to drain the coolant, then fill it with half coolant/half distilled and then burp it? Doesn't coolant already come 50/50 as it is?
    9. Member TurboWraith's Avatar
      Sep 4th, 2004
      IL
      '13 Focus
      08-19-2009 10:21 AM #9
      Some does, some doesnt. its usually cheaper to by the 'concentrated' coolant and mix it yourself. but you can buy the 50/50 if you want.
      Might as well check the thermostat to as someone else suggested. Although I doubt there is anything wrong with it. The funcion of the thermostat is to regulate the minimum temperature that the car runs at. If it sticks open, it will have a hard time heating up, if it sticks closed it will overheat the car VERY quickly as the radiator wont be getting any coolant flow.
      It is rare for one to stick halfway. But you might as well look.
    10. Member Jetty!'s Avatar
      May 9th, 2006
      08-19-2009 10:23 AM #10
      Ok I'm going to try the flush and fill. I didn't know air pockets could form so easily in the coolant system.
      It hasn't been unusually hot here. The summer has been very mild until recently, in the 90s lately and it's become more of a problem recently. But if you get into normal stop/go if it's hot, then the needle on the temp gauage climbs pretty easily. Happened last year when I brought my mom to JFK with her LS when we got stuck in traffic, and I had to pull off and let it cool down periodically. No problems in the fall or winter.
    11. Member Jetty!'s Avatar
      May 9th, 2006
      08-19-2009 11:39 AM #11
      By the way, any idea how much coolant I'd need to fill the system?
    12. 08-19-2009 11:42 AM #12
      C4C will solve this problem.
    13. Senior Member patrikman's Avatar
      May 10th, 2008
      44.5 North, 88 West
      08-19-2009 11:43 AM #13
      you should be able to get a rough idea in the owners manual. it is usually listed under fluid capacities in the user maintenance section.
    14. Member Crispyfritter's Avatar
      Nov 21st, 2001
      SW KS
      08-19-2009 11:43 AM #14
      The car has an electric fan? There may be two settings. A high setting and a low setting. The high setting should kick on if she has the A/C going. There's a potential that the fan may not be getting the signal to kick into high mode, but it may use a different sensor to open the low mode.
      I know nothing about lincolns, though, this is only my experience with older Audis.
      Chris
      | 2017 Korean Appliance SE | 2008 Suburban LTZ | 2003 Dodge Ram | 2002 BMW 530i con mañuel | 1974 SuperBeetle x 2 | 1979 Camaro | 1975 Scout |
      The poster formerly known as 200HP4dr
    15. 08-19-2009 11:52 AM #15
      Quote, originally posted by TurboWraith »
      most are designed to stick open....
      much like what happened in my jetta....in the middle of the winter....
      Yeah, a car doesnt heat up much in -10 degree weather..
    16. 08-19-2009 11:52 AM #16
      Sounds like a typical American car to me.
    17. Senior Member patrikman's Avatar
      May 10th, 2008
      44.5 North, 88 West
      08-19-2009 11:54 AM #17
      Quote, originally posted by TabulaVicious »
      sounds like trollbait to me.
    18. Banned justanotherusername's Avatar
      May 26th, 2007
      Palm Beach, FL
      '08 135i, '00 4runner, '85 Huntsman (Toyota) RV
      08-19-2009 12:03 PM #18
      This sounds like air trapped in the system to me, and the suggestion to "burp" it is a good one. Thermostats do fail from time to time, and I've seen them stick open and closed, but it's not a very common problem. If burping doesn't help, it's not a bad place to go next because the thermostat is cheap.
      If the fan is running I wouldn't mess with that (unless it's got two fans, then it can be more complicated) . The next step is going to be the water pump.
    19. Banned WhistlerYOW's Avatar
      Oct 14th, 2004
      08-19-2009 12:04 PM #19
      Quote, originally posted by patrikman »
      Don't worry, TabulaViscious is probably the only member on here that has such a lack of a real life as to manage to post nearly 10,000 times, but still manage to contribute almost nothing worthwhile to any discussion. Search his posts if you don't believe me .
      Modified by WhistlerYOW at 12:08 PM 8-19-2009
    20. Member Jetty!'s Avatar
      May 9th, 2006
      08-19-2009 12:16 PM #20
      My sister's Jetta is at the mechanics for a cracked power steering rack, bad CV axle, faulty transmission (won't shift out of 3rd gear), and broken wiper linkage.
      But yea, typical american car.
      But no, the fan is controlled hydraulically, not electric. The electric version came in 03 and later.
    21. Senior Member ClockworkChad's Avatar
      Mar 21st, 2003
      NY
      b6 a4 stg 3+
      08-19-2009 12:34 PM #21
      my first guess is bad/sticky t stat. they are cheap, you might want to do that before you flush the coolant since it is going to make a mess as well.
    22. Member Jetty!'s Avatar
      May 9th, 2006
      08-19-2009 01:32 PM #22
      Hm ok. I've been doing some more searching and everyone's had different explanations, waterpump, thermostat, fan, air in the system.
      In fact, the other issues she's had with the car during ownership seems to be VERY common from what I've seen posted on the forums. At least they're consistent.
    23. Geriatric Member ByronLLN's Avatar
      Jul 29th, 2004
      Cleveland, OH
      '16 FiST, '90 Miata
      08-19-2009 01:35 PM #23
      How many miles on it?
      Air/blockages in the system are very cheap (or even free) fixes. T-stats are fairly cheap, but water pumps and fans can get pricey.
    24. Member Jetty!'s Avatar
      May 9th, 2006
      08-19-2009 01:42 PM #24
      It's a little over 100,000 now, maybe like 108,000 or so? Not quite sure.
      Is this a good explanation for "burping the system"?
      http://www.ehow.com/how_7369_b....html
    25. Senior Member ClockworkChad's Avatar
      Mar 21st, 2003
      NY
      b6 a4 stg 3+
      08-19-2009 02:21 PM #25
      thats why i said it, if your going to pop a hose off to change the coolant and burp it, you might as well throw the t-stat in there while you're at it.
