Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 71 to 105 of 171
Thread: BFI - Motor Mounts - Polyurethane solutions for your MkV 2.0T, 2.5L, and VR6
    Nov 15th, 2004
    somewhereville,NJ
    06 Passat APR K04
    11-16-2010 11:51 AM #71
    Well, are the stealth mounts ready for MK5 based cars?
  2. 11-17-2010 10:55 AM #72
    Quote Originally Posted by lour32 View Post
    Unfortunately they are still not available and until further notice they will remain unavailable for an indefinite amount of time. We will definitely keep the forums up to date on any progress made.
  3. Junior Member
    Jun 17th, 2008
    Sydney lad, Singapore-based
    11-19-2010 08:55 PM #73
    Quote Originally Posted by black forest ind View Post
    Unfortunately we will not have the OE mounting point you are referring to... You might want to consider finding a different mounting point as an alternate solution.
    Is there a solution you guys can recommend?
    I just installed the mounts yesterday (trouble-free, and first impressions are good) but the charcoal canister is kinda hangin' out there now (held on in pretty tenuous manner by just a couple of bolts). Is there a solution you can recommend (other than cobbling something together with bits of wire & rusty old bolts from the bottom of the toolkit)?
    Also, FYI the RHS mount (timing belt end) where the plate afixes to the body (i.e. body side; not engine), the front screw (OEM) is a little too long, and use of a washer was required. Rear one no issue as you include a space in the kit.
    What are the torque specs for these bolts (both sides)? That kinda info would be useful as a packing insert with the kit BTW.
    MY07 GTI | 5-dr TR | DSG/roof/leather/Xenon | APR K04 v2.0 | IE rods | S3 injectors | APR HPFP | THS IC | AWE 2.5" DP | VWR CAI | Quaife LSD | Öhlins/Driver Gear | KW RSB | WALK | Stasis/Alcon 355mm 4-piston front | S3 rear | 18" BBS CO ET44 | Pivot XV/Osir Monopod | BFI Stage 1 | BSH TAI/dogbone | DTM tips | Sepang
  4. 11-22-2010 11:04 AM #74
    Nick,
    Just sent you a PM to see if we can help you out!
  5. Junior Member
    Jun 17th, 2008
    11-24-2010 03:36 AM #75
    Quote Originally Posted by joe@blackforest View Post
    Nick,
    Thanks Joe, just replied with some shots - take a look & let me know your thoughts. Cheers.
  6. Junior Member
    Jun 17th, 2008
    12-07-2010 02:21 AM #76
    With 1,000kms and a good hard thrash down some awesome B-roads under my belt since installation, it’s timely to share impressions of the Whiteline Anti-lift Kit (WALK) and BFI “Stage 1” engine & transmission mounts. I’m providing feedback jointly as they were installed jointly – and as vibration can be a key negative byproduct of both products.
    My motivations in installing these were:
    • Mounts: With more than 400Nm, I could feel the relatively soft OEM mounts allowing the drivetrain to cant under power; I also could feel it shifting around during cornering/braking. I’d installed a torque arm insert earlier in an effort to quell this “sloppy” feeling, but it didn’t deliver the result I was after.
    • Arms: I'm very particular about handling – I’d much rather weave through corners than drive flat-out in a straight line – so anything that promised to improve responses while dialing out understeer was going to be of interest; and WALK has received rave reviews elsewhere. These replaced some S3 control arms which frankly were pretty underwhelming.
    Vibration is the big worry for anyone installing things like this – and everyone is different, so reading reviews really doesn’t help. One guy’s “OK vibes” is another's nightmare. So it was a relief when upon initial start-up after install I felt less vibes than expected. Aircon on… and still not atrocious (though certainly more noticeable than stock). Moving off, no huge shudders. Revving, a much more “earthy” thrum; same at steady presence during cruising. Not objectionable, but noticeable.
    And over the next 1,000kms it pretty much stayed that way, gradually reducing with time to the point that it now feels barely any different (vibe-wise) from stock. Though to be clear, there were vibes – in fact, things I didn’t even know existed were vibrating. And when they’d stop… other things took over. It was a symphony of vibration – but eventually it settled. Given I'm particular about NVH, for me to be OK with it says a lot. I still feel/hear the more guttural thrum of the car under acceleration – and I like it.
    The feeling of the car is fantastic – very dialed-in and “planted” thanks to a combination of less engine movement and more precise front steering/suspension control + geometry (caster) change. Turn-in feels razor-sharp, with minimal lost movement, after which the car tracks straight & true with no feeling of the nose washing wide. Power can be applied earlier & harder when pushing out of bends, with less wheel scrabble.
    Given the very reasonable pricing on these products, and the benefit they deliver, I can absolutely recommend them to fellow enthusiasts. Re. WALK, I can totally see what the hype is about. Re. the BFI mounts, I’m pleased I selected their “Stage 1” set-up, which at 65 duro is harder than their “Stealth” product (50 duro) but not so hard as VF, BSH, etc. (80-90 duro) For comparison, stock is 45 duro.
    Install of both can be done by a capable mechanic, though you will need replacement OEM bolts (as these are one-time-use “stretch” bolts) and the correct torque specs. If you don’t want your old control arms, it’s possible to whack them off without needing to loosen the subframe. A post-install alignment is required either way.
  7. Member GLI 808's Avatar
    Dec 28th, 2008
    Mililani
    MKV GLI
    12-10-2010 12:10 PM #77
    Stage 1 is a waste of your time. If anyone is thinking about getting them go for stage 2. I got mine and I love it. Thanks
  8. Member eatmorice's Avatar
    May 8th, 2009
    MIAMI, FL
    5 Liter 'Merica **** yeah Mobile
    12-11-2010 12:53 PM #78
    My stock mounts are crap now, so im saving up for these babies.
    Nov 15th, 2004
    somewhereville,NJ
    06 Passat APR K04
    12-13-2010 03:01 PM #79
    Get those Stealth mounts back in stock
  10. Senior Member MFZERO's Avatar
    Mar 13th, 2002
    Haverhill, Ma.
    2011 Kink Gap Xl, 2000 Haro Blammo,'08 Gti
    01-07-2011 12:01 PM #80
    thinking about ordering some stealth or stage 1 mounts for the girlfriend's car and painting or powder-coating the metal bits.
  11. Member
    Nov 15th, 2004
    somewhereville,NJ
    06 Passat APR K04
    01-12-2011 12:46 PM #81
    Will the Stealth mounts be made again?
  12. 01-12-2011 01:47 PM #82
    At this time we are not planning on offering the Stealth mounts for this application as we feel that they are not a viable option between stock and our Stage 1 mounts.
  13. Member
    Nov 15th, 2004
    somewhereville,NJ
    06 Passat APR K04
    01-12-2011 08:05 PM #83
    That's what I thought since you guys did not have them for a while already. That sucks I really wanted the stealth mounts over all others. Stage1 will cause cabin vibration, correct. I will pm you guys.
  14. Member brekdown29's Avatar
    Jun 25th, 2007
    Phoenix
    2014 Forester XT
    02-01-2011 01:30 PM #84
    THIS
  15. Member VR6 GLX Man's Avatar
    May 19th, 2008
    El Centro, CA
    1992/VW/JETTA/GLI 2.0 2006/ACURA/TL
    03-16-2011 03:35 AM #85
    I ordered the stg.2, supposed be here sometime this week, my engine moves a lot. Cant wait to get these in
    I have the dogbone right now I put that one in myslef, but was a pian in the ass, these Im going to a shop
    to have the put in, unless im able to do this. Im waiting on the side and tranny. If there preasembled, how hard is it to get them installed.
  16. 03-16-2011 10:23 AM #86
    Quote Originally Posted by VR6 GLX Man View Post
    Feel free to take a look at our install guides, which can be found here: http://blackforestindustries.com/ser...l#instructions to see the steps necessary for the installation of your mounts.
  17. Member apollosfury's Avatar
    Oct 13th, 2005
    2007 GTI
    04-27-2011 03:45 PM #87
    just installed my stg 2 mounts and they're outstanding. link to my review thread....
    http://forums.vwvortex.com/showthrea...nd-of-a-review
  18. Member VR6 GLX Man's Avatar
    May 19th, 2008
    El Centro, CA
    05-07-2011 08:12 PM #88
    Ive had these for like 2 months now, at first I thought man the vibration is pretty extreme, but thats because I drive an hour to and from work, but they have broken in and it still vibrates, but it feels more rugged and like a race car, shifts are better, I find myself driving the car hard more than before. On the freeway from 60 an up there's a rumble from the engine and mounts its really deep its not bad, depends on the person. I recommend these mounts to anyone that doesn't mind a more rugged ride.
  19. Member apollosfury's Avatar
    Oct 13th, 2005
    2007 GTI
    05-07-2011 11:02 PM #89
    i spend more time in the higher rpm ranges since i got mine. the car/exhaust sounds so much meaner now!
  20. 05-10-2011 11:04 AM #90
    Thanks for the reviews!
  21. Senior Member MFZERO's Avatar
    Mar 13th, 2002
    Haverhill, Ma.
    05-19-2011 10:19 AM #91
    I've had my stage 2 mounts installed since July. Still loving them!
  22. 05-19-2011 11:16 AM #92
    Quote Originally Posted by MFZERO View Post
    Glad you like them!
  23. Banned
    Nov 7th, 2008
    Raleigh
    MKII & a Wookie
    05-23-2011 03:54 PM #93
    All their mounts are of the highest quality. I highly recommend them!
  24. 05-26-2011 11:04 AM #94
    Thanks for the words!
    Quote Originally Posted by Paint_By_Numbers View Post
  25. 06-21-2011 10:54 PM #95
    Any comments about cabin vibrations in cold temperatures for stage 1? (-25)
  26. 06-22-2011 10:40 AM #96
    Quote Originally Posted by canadaTDi View Post
    I don't believe any of us have had first hand experience with that temperature, but I'd imagine the mount would stiffen up a bit.
  27. Member Bill6211789's Avatar
    Dec 11th, 2009
    Clifton Park, NY
    2006 VW BT Passat
    07-30-2011 07:24 AM #97
    Just installed my stage 2 mounts super easy job took me about n hr to do. currently have stage 2 motor, tranny, and dogbone insert.
    The car feels great. Vibration increases really only at idle. Been about 1,000 mi since install. And the motor sounds much happier
    BFI makes awesome stuff!
    Sent from my EVO
    Unitronic Stage III w/ PT5558BB Turbo (What a difference UNI is from APR!!)Unitronic.ca,HPFP Upgrade Stage 1 pump, 3in.TBE, BSH throttle pipe/27mm RSB/Endlinks , Forge 007 DV , RalcoRC SS, 42Draft Design CNC Shifter bushings, N2MB WOT box, BFI stage 2 motor/tranny mounts, 034 Dogbone, Koni FSD shocks, Neuspeed springs/25mm FSB, Whiteline Anti-lift kit/Front control arm bushings, 18x8.5 VMR VB3s, JBL stereo, CTS Turbo 2.0t FSI Big turbo kit!
  28. 08-02-2011 10:26 AM #98
    Quote Originally Posted by Bill6211789 View Post
    Sent from my EVO
    We really appreciate the feedback and support.
  29. 08-09-2011 02:52 PM #99
    Are these worthwhile for a stock car or are they really only needed if you're running stage 2 and up mods? Thinking of chipping my car and possibly getting some aftermarket engine mounts to cut down on the sloppy feeling it has off the line.
  30. 08-09-2011 04:34 PM #100
    Quote Originally Posted by Lpforte View Post
    Regardless of what performance upgrades you have or plan on having, you will notice vast improvements in feel and shifting when upgrading any of your motor mounts. You should consider the torque arm insert as one of your initial upgrades due to it's ease of installation and affordability. More info can be found on our site here: http://store.blackforestindustries.c...oarmin091.html
  31. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    09-09-2011 09:57 AM #101
  32. Member moltonboron's Avatar
    Dec 18th, 2008
    Dirty Jersey
    2007 MKV GTI
    09-09-2011 11:01 AM #102
    this may be a n00b / dumb question but I def. want the engine and transmission mounts... do I only need one mount for each? Is there more than 1 engine mount that would need to be replaced to be done correctly? (flame suit is on)
    Unitronic Stg II+
  33. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    09-09-2011 12:42 PM #103
    Quote Originally Posted by moltonboron View Post
    You need one of these:
    http://yhst-1918367471896.stores.yah...k4mk54cy1.html
    One of these:
    http://yhst-1918367471896.stores.yah...prtrmost1.html
    And one of these if you don't already have one:
    http://yhst-1918367471896.stores.yah...fitoarmin.html
  34. Member moltonboron's Avatar
    Dec 18th, 2008
    Dirty Jersey
    2007 MKV GTI
    09-09-2011 01:14 PM #104
    Quote Originally Posted by pete@blackforest View Post
    Unitronic Stg II+
  35. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    09-12-2011 02:06 PM #105
