Are you guys working on .5 for mkiv?
#1
We are proud to offer our complete line of performance motor mounts for all MkIV 1.8T/2.0L/1.9TDi and most VR6 applications. Our line of mounts is unlike any other poly options available. They are produced from a two part liquid cast system in several durometers. This results in both a more uniform product as well as a more durable one.
Though MkIV's tolerate performance mounts better than older VW chassis, it should be noted that different motors will react differently to the stages. The 1.8T/2.0L/1.9TDi engines both weighs less and are positioned differently than the VR6's. In general, the 4-cylinder engines will experience more vibration than the VR6's with the same mounts. Please check the descriptions on our website for our recommendations.
To see our entire portfolio of Mk4 engine mounts,.
Please post here, PM, or email us at: sales@blackforestindustries.com with any questions.
#2
From a buyer:
Items for sale: http://forums.vwvortex.com/showthrea...V-and-B5-Parts
#3
Quote, originally posted by Jettakid825 » Are you guys working on .5 for mkiv? Actually, our Stage 1 for the Mk4 is basically the same durometer as our Stage .5 for Mk3's. We just decided to change the nomenclature for Mk4's to make it simpler.
We do however, plan on offering a Stealth material for Mk4 applications that will be softer than their Stage 1 brethren, 50a for the Stealth as opposed to the 65a for Stage 1.
Stay tuned by joining our newsletter
Sign up on our website
#4
Quote, originally posted by black forest ind » Actually, our Stage 1 for the Mk4 is basically the same durometer as our Stage .5 for Mk3's. We just decided to change the nomenclature for Mk4's to make it simpler.
Sweet, i have the stage one dogbone, didnt like it at first but it has been in for a about a month now and im loving it now.
My buddy just threw the .5 is his vr and it felt stock but the engine still didnt move which is what i will prolly be in the market for soon, but im always checking the website!
From a buyer:
#5
i tried to order some stage 2 dogbone inserts lastnight and they say their unavailable. when will they be back in stock?
#6
Quote, originally posted by pDUBc » i tried to order some stage 2 dogbone inserts lastnight and they say their unavailable. when will they be back in stock? We estimate all out-of-stock poly will be available within a weeks time
Hang in there for us!
#7
Quote, originally posted by black forest ind » We estimate all out-of-stock poly will be available within a weeks time
i guess ill be checking back next week
#8
so do the motor mounts raise the engine at all?
"complaining is silly, either act or forget."
MKII GTI build:
http://forums.vwvortex.com/showthrea...-GTI-build!...
#9
Quote, originally posted by jrhthree1.8T » so do the motor mounts raise the engine at all? If our Poly mounts raise your engine at all, it will be because it has sagged over time due to deterioration of the factory rubber mounts
#10
still no dogbone inserts?
#11
Quote, originally posted by pDUBc » still no dogbone inserts? Sorry, we are still workin' on it
#12
bump for great products!![]()
broke status
#13
Quote, originally posted by vwantihero » bump for great products!
#14
oh the wonderful things i need
#15
How is the vibration from the stage 1 drop in poly mounts?
#16
Quote, originally posted by warmstew » How is the vibration from the stage 1 drop in poly mounts? Can you please be more specific about which mount(s) and what vehicle you are asking about?
Stage 1 are fairly conservative by themselves, but do get more noticeable when used together
#17
1.8t jetta passenger and driver.
#18
Quote, originally posted by warmstew » 1.8t jetta passenger and driver. Vibes are noticeable upon startup and during idling with a full Mk4 BFI Stage 1 setup. Slight resonance is felt through the RPM range but is not obnoxious.
#19
#20
got them dogbone inserts in yet?
#21
Quote, originally posted by pDUBc » got them dogbone inserts in yet? Still workin on it - we are close! We will post in here as soon as they are available ~ Thanks for your patience everyone
#23
stage 1 vr6 in stock yet??
#24
Quote, originally posted by jdubb531 » stage 1 vr6 in stock yet?? Sorry, not yet - hang in there! we will post in all of our threads as soon as they are available
#25
is there any benefit to getting the full dogbone over just the insert?
#26
Quote, originally posted by Turbo Turkey » is there any benefit to getting the full dogbone over just the insert? The Assembled Dogbones offer a brand new OE mount with a new rubber trans bushing and our already-installed BFI Poly Dogbone bushings. The assembled mounts take the hassle out of dealing with the insert install and offer a cleaner, newer, and easier way to take advantage of our Polyurethane
#27
Quote, originally posted by black forest ind » The Assembled Dogbones offer a brand new OE mount with a new rubber trans bushing and our already-installed BFI Poly Dogbone bushings. The assembled mounts take the hassle out of dealing with the insert install and offer a cleaner, newer, and easier way to take advantage of our Polyurethane
perfect thanks
#29
great products here by BFI. I have all three stage 2 mounts and it makes a huge difference the motor doesnt move the trans is solid with the trans mount and dog bone. good stuff![]()
#30
Quote, originally posted by adema69 » great products here by BFI. I have all three stage 2 mounts and it makes a huge difference the motor doesnt move the trans is solid with the trans mount and dog bone. good stuff ![]()
Awesome
#31
I run the dog bone and trans mounts. Love them Smooth as glass stage 2. Now if you offered the VR6 engine mount I'd be all over it.
#32
When are the Mk4 Stage 1 engine mounts going to be back in stock?Last one I need to complete the trifecta.
#33
Quote, originally posted by Minimum40 » When are the Mk4 Stage 1 engine mounts going to be back in stock? Last one I need to complete the trifecta.
We hope to have those finished by the end of next week
#34
