VWVortex.com - Parasitic Battery Drain
    Results 1 to 17 of 17
    Thread: Parasitic Battery Drain
    1. Member Pottery_Pal's Avatar
      Jul 13th, 2009
      Houston, TX
      '07 Rabbit, '08 Rabbit
      08-25-2009 11:27 PM #1
      Ok. I have been reading the forums and gaining a wealth of information. I purchased this '90 Corrado and I have been working through a few small issues with the car.
      One issue is the all too common battery drain. I followed the advice of several threads and began the task of connecting an ammeter in-series off the negative terminal.
      An to my surprise I was drawing ~95mA with everything off. So, I proceeded to enlist the help of my son while I pulled the fuses one at a time until I removed a 20AMP Fuse located next to Relay #90. The current draw immediately dropped to ~12mA. I then proceeded to insert then remove the fuse and could hear a clicking sound. I couldn't tell where it was coming from in the short time I fiddled with it. But it is clear, something is pulling a small load.
      When I referenced the Bentley Fuse Panel Diagram I could not determine what this 20AMP Fuse is operating.
      Anyone got any ideas. This is the bulk of my drain issue. Once I fix it I can move on to the next lil project
      Thanks in advance.
      [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Modified by Pottery_Pal at 7:30 PM 8-25-2009
      Modified by Pottery_Pal at 6:14 AM 8-26-2009
    2. Member Prof315's Avatar
      Jan 5th, 2009
      Melbourne, FL
      1992 Corrado ABA-T and MS3-Pro powered, 84 Honda V65 Sabre
      08-26-2009 08:09 AM #2
      The auto seatbelt retractors are infamous for causing a drain...
      The Professor
      Melbourne, FL
      92 Corrado OBD2 ABA-T (BW EFR 6258) Powered by MS3Pro
      Linfert Performance: The Megasquirt guy in central Florida Like my Facebook page....
      Sandy Linfert 11/4/1991 - 5/13/2013
    3. Member Pottery_Pal's Avatar
      Jul 13th, 2009
      Houston, TX
      08-26-2009 10:10 AM #3
      Is that what that yellow fuse powers? Or are you just making a blanket statement about a common battery drain issue.
      I just want to be certain I understand your comments.
    4. Member YellowZonker's Avatar
      Jun 17th, 2006
      Gilbert, AZ
      87 16V Scirocco, 90 G60 Corrado
      08-26-2009 05:31 PM #4
      Everyone knows that if there is a very weird problem that shouldn't be happening, that would be in my car.
      I disconnected the seatbelt crap, pulled the fuse, pulled the bulb in the rear hatch, and the glove compartment, and I still have a draw somewhere. After about 6 months of fiddling with the damn thing I went to Harbor Freight and got a kill switch, for 2 reasons. Where I work they are notorious for car break-ins, even though we have a few kids patrol the lot at night, and 2 because I got tired of chasing power drawing ghosts.
      I put the kill switch on the negative side and ran one bypass wire so that the clock will still have power. That way I know if I still have some sort of draw the instrument cluster needs replacing, and I still have a clock. Everything else, why would you need power to it? The windows are already up, and the doors are already locked by the time you kill the power.
      I got the switch at Harbor Freight for about $6
    5. Member Pottery_Pal's Avatar
      Jul 13th, 2009
      Houston, TX
      08-26-2009 05:40 PM #5
      I'll take that advice. If I can get this drain thing under control I will do just as you suggested.
    6. Member Pottery_Pal's Avatar
      Jul 13th, 2009
      Houston, TX
      08-26-2009 05:50 PM #6
      Please send me a pic of your setup. I would like to see were you located it.
    7. 08-26-2009 06:18 PM #7
      I never thought of it before, but there's a TSB on some wires rubbing against the chassis causing a short, in fact a recall.... maybe the two are connected
    8. Member Pottery_Pal's Avatar
      Jul 13th, 2009
      Houston, TX
      08-26-2009 06:24 PM #8
      Quote, originally posted by Freerevving »
      Dumb question: What is a TSB?
    9. Member NoCYet's Avatar
      Feb 10th, 2001
      Watertown, MA
      '94 Corrado, '13 S5
      08-26-2009 06:45 PM #9
      You could always pull that 20a fuse, and then try out everything to see what stopped working.
      I do not understand why some coupes make the grade and others do not. Everyone knows, for instance, that the Corrado was as tasty as an East End prize fighter with the looks of a Benetti super-yacht. The four-cylinder was good, but the VR6 was about as close as you could get to Ferraridom without buying a Ferrari. And what happened? You all went to the pub instead. -Jeremy Clarkson-
    10. 08-26-2009 06:55 PM #10
      Quote, originally posted by Pottery_Pal »
      Technical Service Bulletin
    11. Member FlyersFn32's Avatar
      May 14th, 2004
      Ephrata PA
      1991 Corrado VR6, 2004 Jetta 1.8t
      08-26-2009 10:40 PM #11
      power windows maybe?
    12. Member Pottery_Pal's Avatar
      Jul 13th, 2009
      Houston, TX
      08-26-2009 10:45 PM #12
      Quote, originally posted by NoCYet »
      I have pulled the fuse and I have connected a battery charger to the car. It will take ~18 hours to fully charge.
      Once the battery is fully charged I am going to fire it up and see what doesn't work just to be certain. I believe it's the power windows.
      After that I am going to install this cool product I just purchased call the PriorityStart. This will help me from killing the battery with the parasitic drain issues while I continue to troubleshoot the problem.
    13. 08-27-2009 01:56 AM #13
      i also have a power drain....
      so once you've determined, lets just assume that its the power windows, then what? how would someone go about fixing a known power drain? its not like finding the drain fixes the problem so, then what, harness replacement, window motor replacement, where does one start? i have never dealt with a power drain before and i dont know where mine is yet but it would be nice to know what the best steps are once i find out what the cause is....
      Quote Originally Posted by BlueVR View Post
      yes i am still into Vag...
    14. Member dogger's Avatar
      Jul 29th, 2005
      Pasadena, CA
      1990 Corrado 2L 16V, 2004 Audi TT 3.2 Quattro S-Line
      08-27-2009 02:03 AM #14
      If wires were rubbing against the chassis the only way they could cause battery drain would be if they were wires that need to see ground in order to trigger something that will power up. If those wires were positive voltage wires they would either pop a fuse or melt the wiring possibly causing a fire.
    15. Member
      Feb 16th, 2001
      Crooklyn
      92 Corrado VRT 6 Speed, 04 Passat B5.5 1.8T 4Mo MT 5 speed
      08-27-2009 07:27 AM #15
      Get a test light and start pulling fuses one by one. Once that sucker lights up nice and bright your on track to your battery drain [IMG]http://*****************.com/smile/emthup.gif[/IMG] A notorious place for drain is also the truck light
    16. Member Pottery_Pal's Avatar
      Jul 13th, 2009
      Houston, TX
      08-27-2009 09:54 AM #16
      Quote, originally posted by hubbell »
      In the instance of power window circuit battery drain I will start by reviewing the electrical schematic in the bentley manual. I will make a running list of all the components in the circuit, ie. switches, modules, relays any thing that could be pulling a load. I will then begin removing each load in a systematic way.
      When the current draw drops near zero then you have found the leg within the circuit causing the problem. Then you have to trace it to a wiring issue or component within that leg.
    17. 08-27-2009 10:39 AM #17
      Check if the clicking sound comes from the rear left panel, if it does, then the problem is the power window control module.
      if the problem is the power window control module (I think it is) here is what I did, and solved my problem.
      http://forums.vwvortex.com/zerothread?id=4084448
      Good Luck
